      11-22-2025, 01:05 PM   #1
internetlag
Drives: e86 z4m coupe / e30 325i / f30 340
Z4m front bumper
Looking to buy a z4m front bumper, my grill clips have shattered and are no longer holding in place.
      11-22-2025, 10:08 PM   #2
3002 tii
3002 tii's Avatar
2961
JB weld em
Technically you should be able to order a new one, will likely take 4-6 weeks.
Follow for latest mods
      11-23-2025, 08:36 AM   #3
B328iC
Drives: 97 328iC, 2003 Z4
3m emblem tape.
      11-23-2025, 05:27 PM   #4
GuidoK
GuidoK's Avatar
20203
Drives: Z4 3.0i ESS TS2+
Are you sure about that?
      11-23-2025, 09:39 PM   #5
3002 tii
3002 tii's Avatar
2961
Yes that was my estimate from BMW classic directly little while back. Obviously as the queue builds up that can extend the timeline.
      11-24-2025, 04:17 AM   #6
GuidoK
GuidoK's Avatar
20203
BMW classic?
Are those these guys? :
https://www.bmwgroup-classic.com/en/...are-parts.html
      11-24-2025, 01:34 PM   #7
3002 tii
3002 tii's Avatar
2961
BMW classic?
Yes I had been emailing with someone from that group in prior months. Updates were posted here:
https://www.zpost.com/forums/showthread.php?t=2180782
GuidoK20202.50
      11-24-2025, 01:45 PM   #8
maupineda
Drives: E86 Z4MC
If it was me I would buy a normal Z bumper and harvest the grill frames. It is not hard, but not straight forward either. This things are just more readily available and they are 1600 according to BMW. You can order, but there is no promised ETA
      11-24-2025, 02:35 PM   #9
3002 tii
3002 tii's Avatar
2961
Or even better, if someone 3d printed a set. One member did so little while back but was hesitant sharing the files because then were not perfect.
      11-24-2025, 04:24 PM   #10
belcom
belcom's Avatar
Drives: '18 540i, '06 Z4si, '07 Z4MC
I broke my clips too. Thinking of a 3d printed solution. Need to design something. Planning to get a 3d scanner and we'll see how fast I can learn to reverse engineer things. No promises though. From what I have seen you can probably make some sort of inserts with a new tongue/clip part that will attach with epoxy.
      11-24-2025, 05:44 PM   #11
maupineda
Drives: E86 Z4MC
If someone can get me some, I can see if I can get that done
      11-24-2025, 09:34 PM   #12
3002 tii
3002 tii's Avatar
2961
A true enthusiast would sacrifice his own for the greater good 😳
      12-02-2025, 01:53 PM   #13
internetlag
3d printing is something I would settle for, im not a big fan of tape or gluing them in place as I feel like the car doesn’t deserve a fix like that 😥.
I might harvest some from a normal z4 and have a friend 3d scan them for me. Maybe then I can mock something up or share the scans with you guys. Im not the greatest with CAD.
3002 tii2961.00
Mr. Z6.00
      12-02-2025, 06:16 PM   #14
maupineda
Drives: E86 Z4MC
I had an issue with one of the tabs and I was able to salvage it with some epoxy and a donor tab from another plastic part. will post a photo later tonight.
3002 tii2961.00
chris7197788.00
