![]() SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Thread Tools |
| 11-22-2025, 10:08 PM | #2 | |
![]() ![]() ![]() 2961
Rep 12,992
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
Technically you should be able to order a new one, will likely take 4-6 weeks. |
internetlag4.50 |
| 11-23-2025, 05:27 PM | #4 |
#buildnotbought
20203
Rep 6,451
Are you sure about that?
| 11-23-2025, 09:39 PM | #5 |
Rep 12,992
Yes that was my estimate from BMW classic directly little while back. Obviously as the queue builds up that can extend the timeline.
| 11-24-2025, 04:17 AM | #6 |
#buildnotbought
20203
Rep 6,451
| 11-24-2025, 01:34 PM | #7 | |
Rep 12,992
https://www.zpost.com/forums/showthread.php?t=2180782 |
GuidoK20202.50 |
| 11-24-2025, 01:45 PM | #8 |
Rep 1,150
If it was me I would buy a normal Z bumper and harvest the grill frames. It is not hard, but not straight forward either. This things are just more readily available and they are 1600 according to BMW. You can order, but there is no promised ETA
| 11-24-2025, 02:35 PM | #9 |
Rep 12,992
Or even better, if someone 3d printed a set. One member did so little while back but was hesitant sharing the files because then were not perfect.
| 11-24-2025, 04:24 PM | #10 |
Rep 506
I broke my clips too. Thinking of a 3d printed solution. Need to design something. Planning to get a 3d scanner and we'll see how fast I can learn to reverse engineer things. No promises though. From what I have seen you can probably make some sort of inserts with a new tongue/clip part that will attach with epoxy.
| 11-24-2025, 05:44 PM | #11 |
Rep 1,150
| 11-24-2025, 09:34 PM | #12 |
Rep 12,992
A true enthusiast would sacrifice his own for the greater good 😳
maupineda639.00 internetlag4.50 |
| 12-02-2025, 01:53 PM | #13 |
Rep 14
3d printing is something I would settle for, im not a big fan of tape or gluing them in place as I feel like the car doesn’t deserve a fix like that 😥.
I might harvest some from a normal z4 and have a friend 3d scan them for me. Maybe then I can mock something up or share the scans with you guys. Im not the greatest with CAD. |
| 12-02-2025, 06:16 PM | #14 |
Rep 1,150
I had an issue with one of the tabs and I was able to salvage it with some epoxy and a donor tab from another plastic part. will post a photo later tonight.
| Bookmarks |
