Thread Tools |
| 04-20-2010, 04:00 PM | #1 |
![]() ![]() ![]() 29
Rep 457
I've been a lurker here for a little bit, and have posted here in there. This forum, although full of knowledge and what seems like nice respectful people, lacks a FAQ thread for simple questions.
I've been searching and can not seem to find a definitive answer for "What are the differences between 06, 07, and 08 M coupes and M roadsters?". I did come across a brief thread regarding all z's, but I'm interested in the M's in particular. I'm sure other newbies that came here before purchasing an M are too. Hopefully we can get a nice compilation of FAQ and links to threads answering the questions here. -What are the differences between 06, 07, and 08 M Coupes and Roadsters?
How about TPMS? Anything else? Particular year certain options or colors came out? Power output, emissions regs, etc? -Why does my tranny grind when I shift 1 ->2?
-What is this CDV that I keep reading about? It is a clutch delay valve. Read here: *again, will update with relevant thread links for more reading* -How rare is my z4m?
-What are common issues with my z4m?
-CPO a big deal? Worth paying the dealer to CPO my vehicle? Links to related threads... See where I'm going? Hopefully we can get a nice little guide here for all newbs, I found it SUPER helpful when I stepped into the world of Ducati's recently. I would even link that thread right now if I could to show an example of what I mean, but again I'm on my bb. Would love to get this stickied, with eventual mod clean up if needed. Thanks guys. Please add to it!!! Last edited by MIKe86; 04-23-2010 at 01:41 AM.. |
| 04-20-2010, 04:06 PM | #2 |
My favorite sign.
188
Rep 4,338
This probably doesn't help...but....
06/07 you will find if you search....I remember having this conversation in the past. 08 only changes to the car are the factory options available...like HD Radio. Also 08s are less likely to have the dreaded engine mount bolt failures based on the SIB.
| 04-20-2010, 04:33 PM | #3 |
Certified Adrenaline Junkie
44
Rep 1,325
I had started a notepad file that contains a lot of good info like you talk of. Here is a copy & paste of it. I'll try to go back later and clean it up a bit. If you see something that is incorrect please let me know. Also, If I quote you and do not put you as the source, I'm sorry, Let me know and I'll fix that. I am not trying to "steal" your work. Some of this info may be opinion based. I basically grabbed it from threads and made a little cheat sheet for myself.
AUX-in for the stereo was added in 2007 but was not in 2006 cars. 3.2L/198 HP @ RPM 330 @ 7900 Torque @ RPM 262 @ 4900 Fuel Tank 14.5 Gallons Motor Mount Bolts Issue Bolts needed are: M8X26mm with 1.25 pitch 10.9 Grade M8X35mm with 1.25 pitch 10.9 Grade M8 Hardened Washers Oem replacement bolts Part # which are 8.8 grade are: 07119905724 M8X26mm 07119905533 M8X35mm *these come with washers* McMaster-Carr Part numbers for comparable bolts are: 90854A167 M8x25mm (1mm shorter than oem) 90854A172 M8x35mm *note* they are only sold in packs of 25* 91812A230 Wedge Lock Washer (Nord-Lock SS washers that prevent loosening) *note* Sold in packs of 5 Torque to 21 N*m Realoem shows 6 of the M8X26mm & 2 M8X35mm http://www.realoem.com/bmw/showparts...64&hg=22&fg=05 Link to more info: http://www.bimmerfest.com/forums/sho...9&postcount=42 http://www.zpost.com/forums/showthre...=328626&page=2 Thanks to Ron Stygar & others for providing all this info. FAQs How to's http://www.bimmerfest.com/forums/sho...d.php?t=130986 Determining number made http://www.zpost.com/forums/showthread.php?t=235232 Coupes, Worldwide: 4,275, North America: 1,815. Roadsters, Worldwide: 5,070, North America: 3,042 Source - BMW Car magazine, Nov. 2008 issue, pp 9. Aluminum hood Stock Tires: 225/45ZR18 255/40ZR18 Stock Wheels Front 18X8.0 ET42 Rear 18X9.0 ET30 Style 224M Stock Brake Rotors Front: 13.6 x 1.10 inch Rear: 12.9 x 0.79 inch The size most of us run on the stock wheels is front:245/40-18 and rear:275/35-18. Final Drive Ratio 3.62 We have the same differential that is in the E46 M3 More info on swapping in 3.91 or 4.10: http://www.zpost.com/forums/showthread.php?t=287976 Curb Weight 3230 lbs OEM Wheel Weights Front = 24.75 lbs. Rear = 25.88 lbs. http://www.bimmerfest.com/forums/sho...d.php?t=167236 With the Z4 M, the ideal shift points are at redline with the exception of 5th to 6th, where it's 500 revs sooner http://www.bmwmregistry.com/ The gearbox is from the 3.0si rather than the E46 M3 DIY clutch stop mod http://www.m3forum.net/m3forum/showthread.php?t=179858 ZHP Knob http://www.trademotion.com/partlocat...catalogid=4462 Z4M Production and Other Interesting Info Thread http://www.zpost.com/forums/showthread.php?t=201969 Nav Tweek http://www.xoutpost.com/electronics/...avtweak-2.html http://www.m5board.com/vbulletin/e39...k-dummies.html Camber http://www.zpost.com/forums/showthread.php?t=339138 http://www.zpost.com/forums/showthread.php?t=321359 http://www.turnermotorsport.com/html..._ID=TSU3690036 Approx what can be adjusted front -1.00 camber stock with pins front -1.5-1.75 stock without pins front -2.5 with shims from turner Suspension Guide http://www.zpost.com/forums/showthread.php?t=44325 Last edited by Blind32; 04-20-2010 at 11:56 PM.. |
| 04-20-2010, 04:58 PM | #4 |
Rep 457
perfect blind 32. That is exactly the kind of info we're looking for. I was looking at an 06,would have been surprised to see no aux input!
Anyway, I will add to/edit original post. In the meantime, please add more people! And here is a link to that ducati FAQ I mentioned earlier. http://www.ducatispot.com/forums/showthread.php?t=10733 Have to drop another motor into my e30 right now, will be back later tonight to continue z4mc hunting online and editing this bad boy. ![]() |
| 04-20-2010, 05:24 PM | #5 |
Imola Lover
30
Rep 749
the best FAQ is to be found on bimmerfest http://www.bimmerfest.com/forums/sho...d.php?t=130986
| 04-20-2010, 09:51 PM | #7 |
44
Rep 1,325
| 04-20-2010, 10:29 PM | #8 |
///M'n it Up
18
Rep 344
Following thread has all of the production info (colors, options, etC) for every North American Z4M.
http://www.zpost.com/forums/showthread.php?t=302570 |
| 04-21-2010, 07:21 AM | #10 |
Rep 457
| 04-22-2010, 09:13 AM | #12 |
Imola Lover
30
Rep 749
You've missed several common issues:
| 04-23-2010, 11:53 AM | #13 |
Rep 4,365
Good idea, graet thread!
| 06-30-2011, 01:28 PM | #14 |
Rep 457
Just came across this link, lots of good stuff on here... thanks bill!
http://www.billswebspace.com/bmwmc.htm
| 01-02-2017, 09:47 PM | #16 |
![]() ![]() ![]() ![]() 249
Rep 758
Is that for the Z4MR? OM for the 3.0i and 3.0si show slightly lighter curb weights.......
Top Down 365 |
| 06-29-2024, 12:32 AM | #17 |
Rep 1
Pop Goes the Weasel
I have a repair question for the group:
I was driving my Z (2003 Z4 2.5 standard) last week when something odd happened. As I was pulling into a parking stack I heard a "pop." All of the lights on the panel illuminated as I pulled into a parking spot. Then the vehicle would not start (just a click when I turned the ignition.) The power in the vehicle would not shut off at the ignition even with the key removed. If it weren't for the electrical issue I would assume its just a blown starter. Any thoughts on what might have happened? |
| Bookmarks |
| Tags |
| fact thread, facts |
