      04-20-2010, 03:00 PM   #1
MIKe86
Drives: 90 332is
Question FAQ Thread
I've been a lurker here for a little bit, and have posted here in there. This forum, although full of knowledge and what seems like nice respectful people, lacks a FAQ thread for simple questions.
I've been searching and can not seem to find a definitive answer for "What are the differences between 06, 07, and 08 M coupes and M roadsters?". I did come across a brief thread regarding all z's, but I'm interested in the M's in particular. I'm sure other newbies that came here before purchasing an M are too.
Hopefully we can get a nice compilation of FAQ and links to threads answering the questions here.
-What are the differences between 06, 07, and 08 M Coupes and Roadsters?
  • AUX-in for the stereo was added in 2007 but was not in 2006 cars.
  • All years power output/engine is the same.
    3.2L/198
    HP @ RPM
    330 @ 7900
    Torque @ RPM
    262 @ 4900
    Fuel Tank
    14.5 Gallons
How about TPMS? Anything else? Particular year certain options or colors came out? Power output, emissions regs, etc?
-Why does my tranny grind when I shift 1 ->2?
-What is this CDV that I keep reading about?
It is a clutch delay valve. Read here: *again, will update with relevant thread links for more reading*
-How rare is my z4m?.
-What are common issues with my z4m?
  • Motor Mount Bolts Issue
    Bolts needed are:
    M8X26mm with 1.25 pitch 10.9 Grade
    M8X35mm with 1.25 pitch 10.9 Grade
    M8 Hardened Washers
    Oem replacement bolts Part # which are 8.8 grade are:
    07119905724 M8X26mm
    07119905533 M8X35mm
    *these come with washers*
    McMaster-Carr Part numbers for comparable bolts are:
    90854A167 M8x25mm (1mm shorter than oem)
    90854A172 M8x35mm
    *note* they are only sold in packs of 25*
    91812A230 Wedge Lock Washer (Nord-Lock SS washers that prevent loosening)
    *note* Sold in packs of 5
    Torque to 21 N*m
    Realoem shows 6 of the M8X26mm & 2 M8X35mm
    http://www.realoem.com/bmw/showparts...64&hg=22&fg=05
    Link to more info:
    http://www.bimmerfest.com/forums/sho...9&postcount=42
    http://www.zpost.com/forums/showthre...=328626&page=2
    Thanks to Ron Stygar & others for providing all this info.
  • Rear sway bar mounts loosen up over time.
    • Indicated by squeaking/groaning/popping from the rear (in that order of progression over time). If left unaddressed, the bolts can back themselves all the way out and the mounts can fall off. Usually affects the driver's side.
    • Solution: Re-Torque the mounting bolts. Many have replaced the OEM fastners with Nordlocks to keep the problem from coming back every 5k miles or so.
  • Front strut-to-firewall braces loosen up over time.
    • Indicated by squeaking/groaning/popping from the front (in that order of progression over time).
    • Solution: Re-Torque the strut brace nuts/bolts (Depending on the build date of your vehicle, you'll have nuts or bolts up top). This will most likely need to be repeated every 5k miles or so.
  • Windshield wiper motor starts acting sporadic while in intermittent mode.
  • BMW Assist/SOS constantly being dialed.
    • Solution: Take it to the dealer.
  • Ejector stuck inside of buffer stop units.
    • if it's stuck down, and you push it and there's zero resistance and goes in farther, then the innards of the assembly have been lost. If, however, there is resistance, it could be that the adjustment mechanism has been triggered and the pin is being held in.
    • More Detail and Picture: http://forums.bimmerforums.com/forum....php?t=1286047
    • Solution: http://forums.bimmerforums.com/forum...4#post16999814 . Also one should NEVER slam the Z4s hood or you risk damaging these parts -- Hood should be pushed down on either side after being closed enough to latch the center safety catch.
  • Wrinkles in driver's face due to joker-style perma-grin.
    • Solution: None.
-CPO a big deal? Worth paying the dealer to CPO my vehicle?
Links to related threads...
See where I'm going? Hopefully we can get a nice little guide here for all newbs, I found it SUPER helpful when I stepped into the world of Ducati's recently. I would even link that thread right now if I could to show an example of what I mean, but again I'm on my bb. Would love to get this stickied, with eventual mod clean up if needed.
Thanks guys. Please add to it!!!
      04-20-2010, 03:06 PM   #2
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
This probably doesn't help...but....
06/07 you will find if you search....I remember having this conversation in the past.
08 only changes to the car are the factory options available...like HD Radio. Also 08s are less likely to have the dreaded engine mount bolt failures based on the SIB.
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      04-20-2010, 03:33 PM   #3
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
I had started a notepad file that contains a lot of good info like you talk of. Here is a copy & paste of it. I'll try to go back later and clean it up a bit. If you see something that is incorrect please let me know. Also, If I quote you and do not put you as the source, I'm sorry, Let me know and I'll fix that. I am not trying to "steal" your work. Some of this info may be opinion based. I basically grabbed it from threads and made a little cheat sheet for myself.
3.2L/198
HP @ RPM
330 @ 7900
Torque @ RPM
262 @ 4900
Fuel Tank
14.5 Gallons
Bolts needed are:
M8 Hardened Washers
07119905724 M8X26mm
07119905533 M8X35mm
90854A172 M8x35mm
Torque to 21 N*m
Link to more info:
FAQs How to's
http://www.bimmerfest.com/forums/sho...d.php?t=130986
Determining number made
http://www.zpost.com/forums/showthread.php?t=235232
Coupes, Worldwide: 4,275, North America: 1,815.
Roadsters, Worldwide: 5,070, North America: 3,042
Source - BMW Car magazine, Nov. 2008 issue, pp 9.
Aluminum hood
Stock Tires:
225/45ZR18
255/40ZR18
Stock Wheels
Front 18X8.0 ET42
Rear 18X9.0 ET30
Style 224M
Stock Brake Rotors
Front:
13.6 x 1.10 inch
Rear:
12.9 x 0.79 inch
The size most of us run on the stock wheels is
front:245/40-18 and rear:275/35-18.
Final Drive Ratio 3.62
We have the same differential that is in the E46 M3
More info on swapping in 3.91 or 4.10:
http://www.zpost.com/forums/showthread.php?t=287976
Curb Weight 3230 lbs
OEM Wheel Weights
Front = 24.75 lbs.
Rear = 25.88 lbs.
http://www.bimmerfest.com/forums/sho...d.php?t=167236
With the Z4 M, the ideal shift points are at redline with the exception of 5th to 6th, where it's 500 revs sooner
http://www.bmwmregistry.com/
The gearbox is from the 3.0si rather than the E46 M3
DIY clutch stop mod
http://www.m3forum.net/m3forum/showthread.php?t=179858
ZHP Knob
http://www.trademotion.com/partlocat...catalogid=4462
Z4M Production and Other Interesting Info Thread
http://www.zpost.com/forums/showthread.php?t=201969
Nav Tweek
http://www.xoutpost.com/electronics/...avtweak-2.html
http://www.m5board.com/vbulletin/e39...k-dummies.html
Camber
http://www.zpost.com/forums/showthread.php?t=339138
http://www.zpost.com/forums/showthread.php?t=321359
http://www.turnermotorsport.com/html..._ID=TSU3690036
Approx what can be adjusted
front -1.00 camber stock with pins
front -1.5-1.75 stock without pins
front -2.5 with shims from turner
Suspension Guide
http://www.zpost.com/forums/showthread.php?t=44325
      04-20-2010, 03:58 PM   #4
MIKe86
Drives: 90 332is
perfect blind 32. That is exactly the kind of info we're looking for. I was looking at an 06,would have been surprised to see no aux input!
Anyway, I will add to/edit original post. In the meantime, please add more people! And here is a link to that ducati FAQ I mentioned earlier. http://www.ducatispot.com/forums/showthread.php?t=10733
Have to drop another motor into my e30 right now, will be back later tonight to continue z4mc hunting online and editing this bad boy.
      04-20-2010, 04:24 PM   #5
jragan
Imola Lover
jragan's Avatar
the best FAQ is to be found on bimmerfest http://www.bimmerfest.com/forums/sho...d.php?t=130986
Hers: 997-1 C4S: Pics
      04-20-2010, 07:42 PM   #6
dekaliber
Drives: '07 Z4MC, '11 JCW, '18 Z06
Thought the M's a final drive ratio of 3.62 rather than 2.62?
      04-20-2010, 08:51 PM   #7
Blind32
Blind32's Avatar
Drives: '07 Z4MC
You sir are correct, must of fat fingered it. FIXED!
      04-20-2010, 09:29 PM   #8
wildag
///M'n it Up
wildag's Avatar
Drives: '06 ///M Roadster
Following thread has all of the production info (colors, options, etC) for every North American Z4M.
http://www.zpost.com/forums/showthread.php?t=302570
      04-20-2010, 10:33 PM   #9
dekaliber
Someone should start a ZPost M Roadster/Coupe wiki -- seems like a more manageable solution that just updating a long forum thread...
      04-21-2010, 06:21 AM   #10
MIKe86
Drives: 90 332is
That too, but I will update this later as I got caught up last night and it's work time now.
      04-21-2010, 09:14 PM   #11
MIKe86
Drives: 90 332is
did some updating. more tomorrow.
      04-22-2010, 08:13 AM   #12
jragan
Imola Lover
jragan's Avatar
You've missed several common issues:
    • Solution: None.
      04-23-2010, 10:53 AM   #13
Hawkeye
Hawkeye's Avatar
No_Country
2070
Good idea, graet thread!
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      06-30-2011, 12:28 PM   #14
MIKe86
Drives: 90 332is
Just came across this link, lots of good stuff on here... thanks bill!
http://www.billswebspace.com/bmwmc.htm
      12-31-2016, 03:16 PM   #15
racerbruce
racerbruce's Avatar
3858
Drives: 21 X3 & 13 335is E93
Roadster Curb Weight: 3,197 lbs
Racerbruce
      01-02-2017, 08:47 PM   #16
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Is that for the Z4MR? OM for the 3.0i and 3.0si show slightly lighter curb weights.......
Top Down 365
Tags
fact thread, facts
