01-09-2010, 05:51 PM | #1 |
Rep 154
Adjusting Camber
Why cant I find a write up on how to do this?
I just got the car and want to max the neg camber front and rear. What bolts? Where? When?....etc... 2009 M coupe help thanks |
01-09-2010, 06:41 PM | #2 |
Rep 1,660
Assuming you mean a 2006 M Coupe, most pull the alignment pins, and take it to a shop to have the alignment done, and get around -1.4 (+/- 0.3) on the fronts. I pulled the pin and was only able to get -1.0 No real DIY information since most aren't going the alignments them self.
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 Last edited by 03BeastCharmer; 01-11-2010 at 12:09 PM.. |
01-09-2010, 11:11 PM | #4 | |
Imola Lover
26
Rep 749
Reposting from my reply to you on bimmerforums:
03-15-2010, 05:41 PM | #5 |
Custom User Title
142
Rep 661
Alignment pin [ item 1/2] [ ignore the arrow, pic is recycled]
Attachment 359528 Camber bolt shim kit for Z4M: http://www.turnermotorsport.com/html..._ID=TSU3690036 "you can change your camber by shimming the strut and spindle with the TMS bolt kit. " ~~$16.00 Each washer adds ~~ 0.5 degree negative camber. Locktite suggested on the bolt. Attachment 359529 Alternatively, BMW sells a thinner bolt to replace part#5, allows you to tilt knuckle before tightening it down. That's covered in other threads. Last edited by blender; 11-21-2012 at 10:33 PM.. |
06-02-2010, 07:25 AM | #6 |
Rep 11,667
ttt, instead of starting a new thread.
I'm going to pull the camber pins for a track session. (no alignment) Just wondering which way will this move the toe?
