03-09-2011, 08:56 PM | #1 |
Rep 120
IT WORKED: 3.0I to 3.0SI Conversion + Exhaust Vid
So it worked !!!!
Two things to consider: 1. The techs at the shop told me that for some reason they were unable to get the automatic transmission to work as they wanted. 2. They did not have a big fan which they said affected the readings (especially with the RPI scoop when I'm going 65+ mph) ^^ Both the above things considered he was sure the engine is actually putting out 10 more bhp then what the sheet shows. Anyways, enough of the crying and cribbing ... with 18% Drive train loss --> 270HP and 246ft-lbs List of Mods: 1. Manifold Conversion - $200 2. SS Race Muffler - USED $600 3. AA Tune - $299 4. RPI Scoop - $100 (Didn't make a difference in the dyno pulls) I think its done quite well especially when an extra 10bhp puts me at 280HP at the crank. A big thanks to -C- for the DIY. Original link: http://www.zpost.com/forums/showthread.php?t=455180
BMW Performance | SuperSprint | 17" M3 CSL Replica's | Active Autowerke | Stop Tech | RPI | 3.0I to 3.0SI Conversion
03-09-2011, 09:26 PM | #2 |
Rep 2,742
so thats just the software or did they dyno tune the car?
i cant wait to take my car to AA this spring and get her dyno tuned specifically for my car with the exhaust and such, very curiouse what it will bring! also very suprising numbers!! it would have been cool if it was a piggyback system so we could have seen it in stock form i also wonder if we unpluged the DISA valves if it make it more like a stock I.............darn you kirkpart! i cant stand it anymore i need to get it out of that darn garage! oh well just a few more weeks to go!!!!! also can you elaberate on the transmission problem they had? the only downside is we dont have sheets showing stock numbers on this dyno so the numbers we need to guage the tru HP gain is hard to do but even so you could be within 10hp give or take of the SI witch when you think about it is 45HP more than our "I" so all said and done 35HP or 45HP for 500 bucks on a NA engine! THANK YOU BMW for making this possable! hehehe Last edited by -c-; 03-09-2011 at 09:40 PM.. |
03-09-2011, 09:41 PM | #3 |
Rep 120
Just got AA to do a N52 tune. Made sure they knew I had a the SI manifold. Then waited for a week and dyno'd it today. No specific Dyno tune.
About the auto transmission, he said that on the dyno it would not want to get to the higher RPM's properly. He took it for a drive on the road and said it was perfect there. I'm not a 100% certain what he meant but I'm meeting him soon so I'll try and understand properly. But, from a stock 215 .... I'm liking the numbers ALOT !!
03-09-2011, 09:53 PM | #4 |
Rep 2,742
well i know that the tune they had was for a 325I and our cars have a few things different about them exhaust and intake as well as a few other things, hence why AA said it be best to dyno tune the car to get the best out of it.
i wonder if your transmission issues where a result of your DSC kicking in, as that would result in RPM loss or other funny things? here was another dyno sheet showing a stock SI then tuned SI, so your numbers are close, but still would have been nice to get the stock pull on the same dyno as each dyno is different. but either way can you feel a huge difference in taking off ? |
03-09-2011, 10:08 PM | #5 |
Rep 120
It was for sure something to do with DSC kicking in. That's kinda what he was saying. Wow so I'm on par with a tuned SI. That's pretty siiiiiiick .... Yeah all dyno's are different but this was the best I could find/afford ...
There is a big difference taking off. I mean BIG SQUEALING difference ... Its also a lot touchier. Flex my toe and I'm off ... I've been racing around against friends cars .... C4 corvettes .... JDM's with 65 shots of nitrous, mustang GT's and i've been wiping the smiles off their silly faces !!! Again thnx for ur help ...
03-10-2011, 12:46 AM | #6 |
Rep 2,784
I don't think the car would accelerate much at all with DSC still activated. Rear wheels spinning with the fronts stationary? Torque would be cut and the brakes applied. I doubt DSC was still ON.
03-10-2011, 12:47 AM | #7 |
Rep 2,784
Grats on the car by the way. This sounds like one of the best bang for the buck performance mods for the 3.0i.
03-10-2011, 08:49 AM | #8 |
Rep 12,635
Garage List E86 Z4 M [10.00]
Congrats!
Curious, how'd you get the AA tune for only $299? I thought it was $399... also which brand is the race muffler? |
03-10-2011, 09:00 AM | #9 | ||
Rep 120
Its a SuperSprint muffler.
03-10-2011, 09:10 AM | #10 |
Rep 2,742
03-10-2011, 09:12 AM | #11 |
Rep 120
That's what I was thinking about last night actually. Maybe he did not turn it off all the way (even though I explained that to him). But either way im pleased
03-10-2011, 09:19 AM | #12 | ||
Rep 12,635
hold it down, dsc is off |
03-10-2011, 09:25 AM | #13 |
Rep 120
I feel like i should heat bend it and center it a little bit , maybe ?
here's the vid:
03-10-2011, 12:55 PM | #14 |
Rep 2,784
There are 3 modes. DSC, DTC, and completely off. Our cars aren't like GM/Mercedes cars where "off" just means "less intrusive." Off is really off. If you were in DTC mode (a quick press of the button), you still wouldn't be able to accelerate much at all without the system kicking in. Want proof? Try and do a burnout in DSC or DTC mode. The front wheels would be stationary and rear spinning (like on the dyno), albeit only one wheel is spinning. Torque would be cut and brakes applied within a second in either mode.
I think it has something to do with the transmission or the way they performed the dyno. Maybe the auto was wanting to kick down gears?
03-10-2011, 01:12 PM | #15 |
Rep 2,742
03-10-2011, 01:31 PM | #16 |
More of this than that!
30
Rep 817
Okay...I need to be educated a bit here. Does the system start in DSC, then single push move to DTC, and then hold for "OFF"?? Silly second question...does the system reset itself to DSC after stopped (shutdown)? And is this the same for the 3.0i, 3.0si, and ///M models? Back to thread... Video sounds real nice...very low ...I was actually expecting a bit of ricer sound.
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
03-10-2011, 01:36 PM | #17 | ||
Rep 2,784
No. The M doesn't have DTC mode. You're either all in or all out.
03-10-2011, 03:10 PM | #18 |
Rep 120
Yeah I'm starting to get confident he was in DTC .... No regrets though
Thanks ..... I love the howl at the top and the bubbling on the downshifting
03-10-2011, 04:56 PM | #19 |
Rep 2,784
He wasn't in DTC.
03-10-2011, 07:06 PM | #20 |
Rep 120
Hmm, No clue why the transmission was trying to kick down gears? I mean he was in steptronic ....
03-10-2011, 08:16 PM | #21 |
Rep 2,431
wow, congrats!! that's pretty exciting gains. I'm definitely looking into it for the wifes e90 now.
On a side not I can't stress enough how much I love NA inline sixes from BMW. I've been driving my new x5 w/ the n55, albeit different cars, my wifes n52 is so much more exciting and engaging. Just solidifies my decision to go n52 over the n54 on the e90
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
03-10-2011, 08:18 PM | #22 |
Rep 12,635
Video sounds really good, I like the rasp. Yes, I'd raise if possible, just enough so it's not hanging below the lines of the bumper.
