Thread Tools |
| 01-05-2011, 01:48 AM | #1 |
Rep 331
Z4MC - Proper Hello and Mod List
Hello Everyone! I recently discovered ZPOST a few months ago, and it's an excellent forum! I wanted to repost the thread that I recently made on the bimmerfest forum because the mod list might be useful to some of you guys on ZPOST (who might not frequent bimmerfest).
I bought my Z4 M Coupe new in 2007 from a dealer in SLO, CA. It's Sapphire Black Metallic with Black Leather and Aluminum trim. The car has every option except Extended Leather, and includes factory Sirius radio (with the antenna mounted on the dash, i.e. not outside the car). Here's a picture I took of my M Coupe the other day: Since I haven't contributed much to this forum yet, here's a list of all my current modifications (including part numbers and links to websites where I purchased some stuff). Hopefully this will be helpful to some of you guys who might want to do similar mods. CDV Delete - http://www.zeckhausen.com/CDV.htm 1.5" Stubby Aluminum Antenna (didn't like) 3.0" Rubber Antenna (looked the best) - Mangowalk ebay Store: http://stores.ebay.com/Mangowalk-Inc/car.html 4" BMW Sport Short Rod Antenna - Part #: 65-20-2-179-726 BMW Navigation Software CD V32 Index "y" - Part #: 01-59-0-141-891 BMW First Aid Storage Boxes under both seats - Box part #: 52-10-7-044-958 - Bracket part #: 52-10-7-045-018 BMW Cup Holder Delete - Cover left part #: 64-22-6-963-779 - Cover right part #: 64-22-6-918-464 Ultimate Cup Holders (two) - http://www.ultimatecupholders.com/index.html Cigarette Lighter Flashlight - VW Touareg Torch part #: 7L6-947-175-A (black trim) - VM Phaeton Torch part #: 3D0-947-175-A (gray trim) - Audio Torch part #: 4F0-947-175 (doesn't fit, too tall) Key/Car Memory (set by Dealer) - One button unlock all doors and trunk - Hold unlock button to roll down windows - Triple blink turn signals - Auto lock doors when driving All Weather Rubber Floor Mats - Black part #: 82-55-0-151-191 Carpeted M Embroidered Floor Mats with Heel Pad - Black part #: 82-11-0-414-670 Rubber Trunk Mat - Part #: 82-11-0-420-508 Carpeted M Trunk Mat - Part #: 82-11-0-417-601 RPI Skid plates under front spoiler - http://shoprpi.com/product_info.php?products_id=46 RPi Ram Air Induction - http://shoprpi.com/product_info.php?products_id=47 BMW Car Cover - Part #: 82-11-0-151-198 - Cable Lock Part #: 82-11-1-467-081 BMW UV Sunshade - Part #: 82-11-0-417-516 BMW Factory Engine Strut Brace - Part #: 51-71-0-305-114 BMW Factory Aero Side Skirts Trim - Left Part #: 51-71-0-150-781 - Right Part #: 51-71-0-150-780 ABS Valve Stem Caps M Logo - Part #: 36-11-0-421-543 BMW Z4 Jack Kit - Part #: 71-106-773-536 BMW ZHP 6-Speed Weighted Shift Knob - Part #: 25-11-7-896-886 23N Hood Bumper Stop with Ejector (two) - Part #: 51-24-8-137-994 BMW M Cross Spoke (Style 163M) - ZCP Wheels - 19x8.0 front offset ET 47 - Part #: 36-11-2-282-895 - 19x9.5 rear offset ET 27 - Part #: 36-11-2-282-999 - Center hub cap - Part #: 36-13-6-768-640 Hankook Ventus V12 evo K110 - 245/35R-19 - Diameter 25.8" (vs. Stock 26.0") - 285/30R-19 - Diameter 25.7" (vs. Stock 26.0") Velocity Motorcars 12mm Spacers (used on front wheels) - http://www.velocitymotorcars.com/bmw-wheel-spacers.html RAD 36mm Locking Wheel Bolts - http://www.velocitymotorcars.com/rad...ck-silver.html BMW Motorsports 210mm 4.10 Ring and Pinion - Dan @ http://diffsonline.com/ (Gear Set) VAC by Fabspeed - S54 Performance Exhaust Header - Jet-Hot "2000" Ceramic Coating - http://store.vacmotorsports.com/vac-...z4m-p2637.aspx Stromung Exhaust - http://store.vacmotorsports.com/stro...upe-p2597.aspx Evolve-R: BMW Z4M: Evolver ECU Tune - http://www.zpost.com/forums/showthread.php?t=694589 - http://www.evolvetuning.us/bmw/z-ser...-ecu-tune.html - jamie@rkautowerks.com - 1. Select MSS70 - 2. Read the entire DME and calibration area, E46M guys read just the calibrations... BMW Clutch Stop Z4 - pickyeater334 ebay store: http://www.ebay.com/sch/pickyeater334/m.html Beltronics GX65 Radar Detector - https://www.beltronics.com/store/gx-65.html Beltronics Direct Wire Cord - https://www.beltronics.com/store/direct-wire-cord.html Add-A-Circuit (tap into fuse box at fuse #2) Intravee II iPod Interface - http://www.intravention.co.uk/ - http://www.bimmernav.com/ Alpine KCA-420i iPod Interface - http://www.crutchfield.com/ Interface cable that goes from the 12-pin slave port of the factory Sirius unit to both a 3-pin and a 6-pin cable for the Intravee - http://www.bimmernav.com/ - http://www.europeanautosource.com/pr...roducts_id=235 Ridax iPod charge adapter - http://home.swipnet.se/ridax/connector.htm?connipod.htm - http://www.scosche.com/passport DKF Hangers - http://www.zpost.com/forums/showthread.php?t=687396 - http://www.dkfperformance.com/products.html AutoSolutions SSK (short shifter kit) - http://www.zpost.com/forums/showthread.php?t=719169 - http://www.autosolutions.net Vibra-Technics Engine Mounts - http://www.zpost.com/forums/showthread.php?t=783544 - http://www.vibra-technics.co.uk/bmw/..._engine_mount_ BMW Motorsport Engine Mount Bolts - (6) M8x25 10.9: 07-11-9-913-653 - (2) M8x35 10.9: 07-11-9-913-673 - (8) Washers: 07-11-9-903-078 DKF Section 1 Kit w/ 300 Cell Cats and Resonators - Satin Black NitroPlate Coating - http://www.zpost.com/forums/showthread.php?t=825540 DansDecals BMW Reflector Decals - Sapphire Black Metallic - http://dansdecals.com/BMW-Reflector-Decals-P274C73.aspx Eurosport Design Stainless Steel Double Walled Exhaust Tips - Flat Exhaust Tip - http://www.eurosportdesign.com/p-256...aust-tips.aspx ECS Blackout Grille Set - Matte Black - http://www.ecstuning.com/BMW-Z4-M_Co...419/ES2608277/ P3Cars VIDI Gauge w/ Analog Boost Sensor - http://www.p3cars.com/bmw-z-series/p...tal-interface/ P3Cars Low Profile OBD2 Extension - http://www.p3cars.com/add-ons-and-ac...sion-flat-2ft/ Euro OEM O2 Sensors - O2 Sensor - 1390MM - Part #: 11-78-7-837-564 - O2 Sensor - 1340MM - Part #: 11-78-7-837-565 Last edited by marinb; 07-30-2013 at 01:47 AM.. |
| 01-05-2011, 02:36 AM | #2 |
DHS
307
Rep 4,064
Welcome... Best color IMO!
2023 BMW M4 2016 X3 |
| 01-05-2011, 06:50 AM | #6 |
![]() ![]() ![]() 76
Rep 483
Wow! Love the wheels! Great details!
Why switch to the rubber antenna? Just looks? I'm going to buy one. Why spacers on the front wheels? To widen the track? Do the first ait kit drawers provide a little extra space? Or are you just using them for finish asthetics? Same part numbers for drivers and passengers side? It would be nice to squeeze my sunglass case somewhere. |
| 01-05-2011, 07:22 AM | #7 |
![]() ![]() ![]() 16
Rep 505
awesome car. I just recently picked up an 08 SBM M coupe and i love it.
Quick request, can you post a pic of where you mounted the Sirius antenna. I wanted to do the upgrade but do not want to mount it on the exterior - so i opted not to make the purchase. Any issues with reception? |
| 01-05-2011, 08:31 AM | #8 |
![]() 48
Rep 1,855
Hey welcome! Great looking car and nice mod list! Love the ZCP wheels.
![]() ///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
| 01-05-2011, 09:10 AM | #9 | |
![]() ![]() ![]() ![]() 31
Rep 615
| 01-05-2011, 11:57 AM | #10 | |
![]() 296
Rep 1,665
![]() Because of the offset of the ZCP wheels, they are sunken in 5mm vs stock. So the spacer is there to gain that back, and in both of our cases, add a little more to gain a little track and to get a more flush look I assume. Car looks nice!
![]() Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
| 01-05-2011, 12:29 PM | #11 |
![]() ![]() ![]() 2961
Rep 12,992
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
how and where were you able to snag an intravee 2? those have been sold out for a long time and i've been looking for months now but no luck!
awesome list of quality oem and oem+ mods... |
| 01-05-2011, 12:31 PM | #12 |
Rep 12,992
oh yea, that antenna 65-20-2-179-726, is that what's currently pictured above?
never even knew there was such a thing as cup holder covers =) Last edited by 3002 tii; 01-05-2011 at 05:42 PM.. |
| 01-05-2011, 12:32 PM | #13 | ||||
Rep 331
Just like 03BeastCharmer said, the offsets on the ZCP wheels are not the same as the stock wheels. ZCP wheels without spacers fit -5mm on the front and +9mm on the rear. Adding 12mm to the front gives me +7mm on the front, which looks a lot better. Quote:
I didn't realize they were sold out. I bought mine from bimmernav.com a couple of years ago. It works great especially with the new 6.0 firmware. |
| 01-05-2011, 01:24 PM | #14 |
Rep 243
Welcome and thanks for adding the part numbers.
2008 Z4MC #1786/1815 "The Last IB w/ Extended Leather Made" Gone but Not Forgotten
2014 M235i E.Blue Mods in Progress |
| 01-05-2011, 02:08 PM | #16 |
Dark Sider
153
Rep 1,781
Drives: 2008 Space Gray Z4MC
Nice car there. Like the color too. It's right behind Space Grey...
[URL=http://imageshack.us/photo/my-images/153/071jt.jpg/]2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
| 01-05-2011, 08:46 PM | #17 |
Rep 331
Definitely. There are some great drives in this area!
Have you been to the Cars & Coffee event at Santana Row? It's usually every Saturdary morning. The turnout can be really good when the weather is nice. http://www.m3post.com/forums/showthread.php?t=423647 |
| 01-05-2011, 09:38 PM | #18 | |
///M-fanatic
214
Rep 3,885
More into meeting up for DIY's or GB deliveries, dyno days, etc. |
| 01-05-2011, 10:33 PM | #19 |
Bimmer Noob
33
Rep 568
Excellent choice, if I do say so myself!
Welcome and thanks for the breakdown on part #'s.
![]() 08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
| 01-21-2011, 04:13 PM | #20 | |
Rep 331
http://www.bimmerfest.com/forums/sho...62#post5787462 |
| 01-21-2011, 05:08 PM | #22 |
![]() 495
Rep 2,747
Great list and write-up
Welome to the post ![]()
| Bookmarks |
