      01-05-2011, 01:48 AM   #1
marinb
marinb's Avatar
Drives: 2018 M3
Z4MC - Proper Hello and Mod List
Hello Everyone! I recently discovered ZPOST a few months ago, and it's an excellent forum! I wanted to repost the thread that I recently made on the bimmerfest forum because the mod list might be useful to some of you guys on ZPOST (who might not frequent bimmerfest).
I bought my Z4 M Coupe new in 2007 from a dealer in SLO, CA. It's Sapphire Black Metallic with Black Leather and Aluminum trim. The car has every option except Extended Leather, and includes factory Sirius radio (with the antenna mounted on the dash, i.e. not outside the car).
Here's a picture I took of my M Coupe the other day:
Since I haven't contributed much to this forum yet, here's a list of all my current modifications (including part numbers and links to websites where I purchased some stuff). Hopefully this will be helpful to some of you guys who might want to do similar mods.
CDV Delete
- http://www.zeckhausen.com/CDV.htm
1.5" Stubby Aluminum Antenna (didn't like)
3.0" Rubber Antenna (looked the best)
- Mangowalk ebay Store: http://stores.ebay.com/Mangowalk-Inc/car.html
4" BMW Sport Short Rod Antenna
- Part #: 65-20-2-179-726
BMW Navigation Software CD V32 Index "y"
- Part #: 01-59-0-141-891
BMW First Aid Storage Boxes under both seats
- Box part #: 52-10-7-044-958
- Bracket part #: 52-10-7-045-018
BMW Cup Holder Delete
- Cover left part #: 64-22-6-963-779
- Cover right part #: 64-22-6-918-464
Ultimate Cup Holders (two)
- http://www.ultimatecupholders.com/index.html
Cigarette Lighter Flashlight
- VW Touareg Torch part #: 7L6-947-175-A (black trim)
- VM Phaeton Torch part #: 3D0-947-175-A (gray trim)
- Audio Torch part #: 4F0-947-175 (doesn't fit, too tall)
Key/Car Memory (set by Dealer)
- One button unlock all doors and trunk
- Hold unlock button to roll down windows
- Triple blink turn signals
- Auto lock doors when driving
All Weather Rubber Floor Mats
- Black part #: 82-55-0-151-191
Carpeted M Embroidered Floor Mats with Heel Pad
- Black part #: 82-11-0-414-670
Rubber Trunk Mat
- Part #: 82-11-0-420-508
Carpeted M Trunk Mat
- Part #: 82-11-0-417-601
RPI Skid plates under front spoiler
- http://shoprpi.com/product_info.php?products_id=46
RPi Ram Air Induction
- http://shoprpi.com/product_info.php?products_id=47
BMW Car Cover
- Part #: 82-11-0-151-198
- Cable Lock Part #: 82-11-1-467-081
BMW UV Sunshade
- Part #: 82-11-0-417-516
BMW Factory Engine Strut Brace
- Part #: 51-71-0-305-114
BMW Factory Aero Side Skirts Trim
- Left Part #: 51-71-0-150-781
- Right Part #: 51-71-0-150-780
ABS Valve Stem Caps M Logo
- Part #: 36-11-0-421-543
BMW Z4 Jack Kit
- Part #: 71-106-773-536
BMW ZHP 6-Speed Weighted Shift Knob
- Part #: 25-11-7-896-886
23N Hood Bumper Stop with Ejector (two)
- Part #: 51-24-8-137-994
BMW M Cross Spoke (Style 163M) - ZCP Wheels
- 19x8.0 front offset ET 47 - Part #: 36-11-2-282-895
- 19x9.5 rear offset ET 27 - Part #: 36-11-2-282-999
- Center hub cap - Part #: 36-13-6-768-640
Hankook Ventus V12 evo K110
- 245/35R-19 - Diameter 25.8" (vs. Stock 26.0")
- 285/30R-19 - Diameter 25.7" (vs. Stock 26.0")
Velocity Motorcars 12mm Spacers (used on front wheels)
- http://www.velocitymotorcars.com/bmw-wheel-spacers.html
RAD 36mm Locking Wheel Bolts
- http://www.velocitymotorcars.com/rad...ck-silver.html
BMW Motorsports 210mm 4.10 Ring and Pinion
- Dan @ http://diffsonline.com/ (Gear Set)
VAC by Fabspeed - S54 Performance Exhaust Header
- Jet-Hot "2000" Ceramic Coating
- http://store.vacmotorsports.com/vac-...z4m-p2637.aspx
Stromung Exhaust
- http://store.vacmotorsports.com/stro...upe-p2597.aspx
Evolve-R: BMW Z4M: Evolver ECU Tune
- http://www.zpost.com/forums/showthread.php?t=694589
- http://www.evolvetuning.us/bmw/z-ser...-ecu-tune.html
- jamie@rkautowerks.com
- 1. Select MSS70
- 2. Read the entire DME and calibration area, E46M guys read just the calibrations...
BMW Clutch Stop Z4
- pickyeater334 ebay store: http://www.ebay.com/sch/pickyeater334/m.html
Beltronics GX65 Radar Detector
- https://www.beltronics.com/store/gx-65.html
Beltronics Direct Wire Cord
- https://www.beltronics.com/store/direct-wire-cord.html
Add-A-Circuit (tap into fuse box at fuse #2)
Intravee II iPod Interface
- http://www.intravention.co.uk/
- http://www.bimmernav.com/
Alpine KCA-420i iPod Interface
- http://www.crutchfield.com/
Interface cable that goes from the 12-pin slave port of the factory Sirius unit to both a 3-pin and a 6-pin cable for the Intravee
- http://www.europeanautosource.com/pr...roducts_id=235
Ridax iPod charge adapter
- http://home.swipnet.se/ridax/connector.htm?connipod.htm
- http://www.scosche.com/passport
DKF Hangers
- http://www.zpost.com/forums/showthread.php?t=687396
- http://www.dkfperformance.com/products.html
AutoSolutions SSK (short shifter kit)
- http://www.zpost.com/forums/showthread.php?t=719169
- http://www.autosolutions.net
Vibra-Technics Engine Mounts
- http://www.zpost.com/forums/showthread.php?t=783544
- http://www.vibra-technics.co.uk/bmw/..._engine_mount_
BMW Motorsport Engine Mount Bolts
- (6) M8x25 10.9: 07-11-9-913-653
- (2) M8x35 10.9: 07-11-9-913-673
- (8) Washers: 07-11-9-903-078
DKF Section 1 Kit w/ 300 Cell Cats and Resonators
- Satin Black NitroPlate Coating
- http://www.zpost.com/forums/showthread.php?t=825540
DansDecals BMW Reflector Decals
- Sapphire Black Metallic
- http://dansdecals.com/BMW-Reflector-Decals-P274C73.aspx
Eurosport Design Stainless Steel Double Walled Exhaust Tips
- Flat Exhaust Tip
- http://www.eurosportdesign.com/p-256...aust-tips.aspx
ECS Blackout Grille Set
- Matte Black
- http://www.ecstuning.com/BMW-Z4-M_Co...419/ES2608277/
P3Cars VIDI Gauge w/ Analog Boost Sensor
- http://www.p3cars.com/bmw-z-series/p...tal-interface/
P3Cars Low Profile OBD2 Extension
- http://www.p3cars.com/add-ons-and-ac...sion-flat-2ft/
Euro OEM O2 Sensors
- O2 Sensor - 1390MM - Part #: 11-78-7-837-564
- O2 Sensor - 1340MM - Part #: 11-78-7-837-565
      01-05-2011, 02:36 AM   #2
Endless619
DHS
Endless619's Avatar
Drives: 2023 M4, 2020 Land Rover
Welcome... Best color IMO!
2020 Land Rover Velar Autobiography
2023 BMW M4
2016 X3
      01-05-2011, 02:42 AM   #3
Mtxzptlk
Driving Dog
Mtxzptlk's Avatar
974
Drives: 635/1815, X3M Comp
Right behind Interlagos Blue...
      01-05-2011, 04:18 AM   #4
r4gs
Viper Driver
Singapore
36
Drives: F-16
nice mods writeup and extremely detailed information with part numbers welcome!
      01-05-2011, 06:14 AM   #5
RBull
Drives: 2007 M Coupe
Welcome. Looks great.
Your mod list with part numbers is a nice touch.
      01-05-2011, 06:50 AM   #6
santov
santov's Avatar
76
Drives: 2007 Z4 3.0si White over Beige
Wow! Love the wheels! Great details!
Why switch to the rubber antenna? Just looks? I'm going to buy one.
Why spacers on the front wheels? To widen the track?
Do the first ait kit drawers provide a little extra space? Or are you just using them for finish asthetics? Same part numbers for drivers and passengers side? It would be nice to squeeze my sunglass case somewhere.
      01-05-2011, 07:22 AM   #7
sabbanick
Drives: 08 SBM M coupe
awesome car. I just recently picked up an 08 SBM M coupe and i love it.
Quick request, can you post a pic of where you mounted the Sirius antenna.
I wanted to do the upgrade but do not want to mount it on the exterior - so i opted not to make the purchase. Any issues with reception?
      01-05-2011, 08:31 AM   #8
esqu1re
esqu1re's Avatar
48
Drives: M Coupe
Hey welcome! Great looking car and nice mod list! Love the ZCP wheels.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      01-05-2011, 09:10 AM   #9
mhughett
Drives: 2007 Z4 M Coupe
I don't have a picture but I have the satellite antenna right smack in the middle of the dash, way up front against the windshield. I originally installed it on the outside but this didn't work as the opening and closing of the rear hatch eventually weakened and broke the wire. The antenna runs from the rear bulkhead area (where it is attached to the receiver) down the drivers side door sill under the trim, and then I tucked it in along the left side trim up the dash and along the lower edge of the windshield. It stays in place with velcro on the bottom and on the dash where it sits. No reception problems at all in this location and no worries about it being damaged.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
      01-05-2011, 11:57 AM   #10
03BeastCharmer
03BeastCharmer's Avatar
296
Drives: '13 M3
I have the same wheels and spacers from the same company (10 mm for me).
Because of the offset of the ZCP wheels, they are sunken in 5mm vs stock. So the spacer is there to gain that back, and in both of our cases, add a little more to gain a little track and to get a more flush look I assume.
Car looks nice!
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      01-05-2011, 12:29 PM   #11
3002 tii
3002 tii's Avatar
2961
how and where were you able to snag an intravee 2? those have been sold out for a long time and i've been looking for months now but no luck!
awesome list of quality oem and oem+ mods...
Follow for latest mods
      01-05-2011, 12:31 PM   #12
3002 tii
3002 tii's Avatar
2961
oh yea, that antenna 65-20-2-179-726, is that what's currently pictured above?
never even knew there was such a thing as cup holder covers =)
      01-05-2011, 12:32 PM   #13
marinb
marinb's Avatar
Drives: 2018 M3
I originally switched to the short antenna because I was using the car cover a lot and I didn't want to unscrew the antenna every time I wanted to use the car cover. 3" or less works best with the car cover.
Yes, the one in the picture is the 4" OEM BMW antenna.
Just like 03BeastCharmer said, the offsets on the ZCP wheels are not the same as the stock wheels. ZCP wheels without spacers fit -5mm on the front and +9mm on the rear. Adding 12mm to the front gives me +7mm on the front, which looks a lot better.
I use both first aid storage boxes to store random stuff. The Z4 really lacks storage space, especially with that tiny glove box. The same part numbers work for either side.
I think mhughett did a great job describing the satellite antenna location, a picture wouldn't help much. My cable is routed differently, it goes: bulkhead area, up the passenger side B pillar, inside the roof lining, down the passenger side A pillar, then along the windshield to the center of the dash. No issues with reception other than the typical satellite reception issues.
I didn't realize they were sold out. I bought mine from bimmernav.com a couple of years ago. It works great especially with the new 6.0 firmware.
      01-05-2011, 01:24 PM   #14
HOG4DNR
HOG4DNR's Avatar
Drives: 2014 M235i
Welcome and thanks for adding the part numbers.
2008 Z4MC #1786/1815 "The Last IB w/ Extended Leather Made" Gone but Not Forgotten
2014 M235i E.Blue Mods in Progress
      01-05-2011, 02:00 PM   #15
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
214
Drives: '01 911 Turbo
Cupertino buddy!
We should meet up sometime
      01-05-2011, 02:08 PM   #16
mousitch
Dark Sider
mousitch's Avatar
153
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
Nice car there. Like the color too. It's right behind Space Grey...
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings
      01-05-2011, 08:46 PM   #17
marinb
marinb's Avatar
Drives: 2018 M3
Originally Posted by mfanatic325 View Post
Cupertino buddy!
Definitely. There are some great drives in this area!
Have you been to the Cars & Coffee event at Santana Row? It's usually every Saturdary morning. The turnout can be really good when the weather is nice.
http://www.m3post.com/forums/showthread.php?t=423647
      01-05-2011, 09:38 PM   #18
mfanatic325
///M-fanatic
Taiwan
214
Haha I'm kinda over the whole parking lot pimpin' phase =P
More into meeting up for DIY's or GB deliveries, dyno days, etc.
      01-05-2011, 10:33 PM   #19
a_riddler
Bimmer Noob
a_riddler's Avatar
Drives: 08 Z4MC;08 MBZ E350 4Matic
Excellent choice, if I do say so myself!
Welcome and thanks for the breakdown on part #'s.
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing,
AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges
      01-21-2011, 04:13 PM   #20
marinb
marinb's Avatar
Drives: 2018 M3
Guys on bimmerfest are reportedly able to get new Intravee units. Check out this recent post:
http://www.bimmerfest.com/forums/sho...62#post5787462
      01-21-2011, 04:53 PM   #21
ANUSTART
ANUSTART's Avatar
42
Drives: Z4
Welcome. Great list! Love the stubby antenna.
      01-21-2011, 05:08 PM   #22
crfine88
crfine88's Avatar
495
Drives: E86M
Great list and write-up
Welome to the post
