Thread Tools |
| 12-24-2024, 01:22 PM | #221 | |
![]() 1052
Rep 1,354
Thanks!
This is the only account I have on Bimmerpost, I will never post my e-mail publicly. If you want to contact me send a PM or you can find me on Instagram: @andre_westersund or @westersund_motorsport
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12 | BMW Z4 M Coupe -06 | BMW 330i -05 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
| 02-05-2025, 05:40 AM | #222 | |
![]() ![]() ![]() 2961
Rep 12,992
Garage List E86 Z4 M GTS [9.91]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
I dislike 99% of ACS products, especially this one. But I think color matching the sills (or better yet a version without the sills) would make it way less of an eyesore. Then add ducting and you're good to go. Last edited by 3002 tii; 02-05-2025 at 07:32 AM.. |
| 03-20-2025, 02:35 PM | #223 | |
![]() 1052
Rep 1,354
| 03-20-2025, 02:49 PM | #224 | |
![]() ![]() ![]() ![]() 594
Rep 951
I did extensive testing on braking, pad selection, temperature measurement, and my pads are correctly getting to temperature, and not any hotter than the pad temperature curves from the MFG recommended. In my case, I have hard evidence where blocking the cooling ducts improved brake feel and consistency. I went from having poor braking after long high speed straights to more consistent braking by blocking them. Still, I don't see how those will hold up mounted right onto the back of the front rotor covers. PC's glass point is 147C ? I would probably consider some newer materials like carbon PC to reduce warpage. I don't know of any serious racer running anything but metal ducting (or carbon fiber?) in those areas. That stuff melts or warps and it could ruin your race. I have an entire thread on here on my brake issues and conclusions regarding knockback and such. Attached an image of my current setup. 3" hose, simple 3" pipe adapter behind the caliper shield, rivited. Was a $5 affair, and has held up to abuse.
| 03-20-2025, 03:24 PM | #225 | |
![]() 1052
Rep 1,354
If blocking your brake cooling ducts have helped with consistency I'd say you're running a pad that's very high in the temperature range and reaches below it's range at the end of a straight. It's not uncommon for racecars to have variable sized intakes for the brake cooling depending on track and conditions to not over cool the brakes and get inconsistent brake modulation.
| 03-20-2025, 03:31 PM | #226 | |
Rep 951
Westersund1051.50 |
| 03-20-2025, 03:43 PM | #227 | |
![]() 1052
Rep 1,354
| 06-24-2025, 10:45 AM | #228 |
![]() 1052
Rep 1,354
I will be developing a new rear kit shortly that will be easier to install and it will be Z4 M specific. Only 3D-printed parts, no metal parts.
wdb5539.50 |
| 08-11-2025, 03:26 AM | #229 |
![]() 1052
Rep 1,354
As promised I have updated the rear kit now that I have a 3D-scanner. This kit is bespoke to the Z4 M/E46 M3 (the only difference is the V-brace air intake). The old rear kit will still be available is someone prefer that. The new air intake on the V-brace only extends 26 mm from the bottom of the V-brace. This kit will cost the same as the older kit, 250$, and everything but hose and hose clamps are included. As always, if you buy a front and rear kit at the same time you will get 50$ discount on the rear kit. An installation guide will be available shortly.
As I mentioned the V-brace air intake only build 26 mm below the underside of the V-brace. The intake are printed in PETG and the backing plate ducts are printed in glasfiber re-inforced nylon (PA6-GF). Included in the kit is a cutting template to make a (near) perfect window in the OE backing plate. Installed with OE droop of the suspension which compresses the hose a lot, but it works. Clearance between the duct/hose and the wheel (18x10" ET27) is about 20 mm so it is possible to run a wider wheel. Here you can see that the ducts/hose is inside the contours of the rear trailing arm. This is with the car on the ground, my car is about 25 mm lower in the rear than stock. ![]()
| 09-22-2025, 02:18 PM | #230 |
![]() 1052
Rep 1,354
At the bottom of the first post you can now find the installation guide for the new rear brake cooling kit.
wdb5539.50 |
| 09-27-2025, 02:28 AM | #232 |
![]() 1052
Rep 1,354
Sent you a PM.
| 11-26-2025, 11:39 AM | #233 |
![]() 1052
Rep 1,354
Perfect time to order your winter upgrades!
| 12-25-2025, 04:24 PM | #234 |
![]() 1052
Rep 1,354
The new Race version is now done with a single 3" inlet and protection for the ABS-sensor and ball joints. Another version with dual inlets/outlets (2x2.5") will be done both for the backing plate and front bumper.
3002 tii2961.00 |
| 12-28-2025, 02:19 PM | #235 |
![]() 1052
Rep 1,354
Some more pictures of the new Race backing plate with a few duct options.
The previously posted single 3" duct. The same duct but in 2,5" which could be used with my universal caliper cooling bracket/duct along with the upcoming front bumper duct with dual 2,5" outlets. A picture of my universal 2,5" caliper cooling bracket/duct. ![]() And a picture of it installed (installs with the same bolts as the caliper = red arrows). ![]() This a duct with dual 2,5" inlets which preferably should be paired with the upcoming front bumper duct with dual 2,5" outlets. Lastly a picture of the ABS-sensor cover in relation to the hub/wheel bearing. ![]()
3002 tii2961.00 |
| 01-06-2026, 12:40 AM | #236 |
Rep 12,992
How much for the newer design front kit, backing plates + funnel only?
| 01-06-2026, 01:52 AM | #237 |
![]() 1052
Rep 1,354
The Race backing plates only (funnels included) will be 200$ and with the universal caliper cooling ducts 270$, just like I've done on the F-series.
| 02-10-2026, 12:45 PM | #238 |
![]() 1052
Rep 1,354
Here's the new front Race backing plates. Will be available in single 2,5", dual 2,5" and single 3".
And here's the new front Race kit. Will be available in single 2,5", dual 2,5" and single 3". ![]()
| 03-18-2026, 03:59 PM | #239 |
![]() 1052
Rep 1,354
Track season is around the corner!
| Bookmarks |
