07-16-2019, 04:15 AM | #1 |
Rep 876
BMW Z4 M Brake Cooling Kit
This kit replaces the non functional OEM brake cooling ducts and it uses the same mounting points. Horn relocation/rotation is needed to fit this kit and some cutting in the inner part of the wheel arches for the hose routing. The front backing plates replaces the OEM ones and in the rear you have to modify the OEM backing plates. The kit includes brake cooling ducts for the front bumper, backing plates, funnels for the backing plates and brackets. All metal parts come painted and hardware such as bolts/nuts/washers are included in the kit, the backing plates come pre-assembled and ready for install. 3" fittings up front and 2" in the rear. Hose and hose clamps are NOT included in this kit. "MOTK made me aware that there's an OE block off cover for the wheel arches (From the 3.0 Z4) you can buy for cheap. The OE one in plastic cost around 5-6$ each side. Part number 5 in this URL: http://bmwfans.info/parts-catalog/E8...ch_trim_front/ Part numbers are: 51717056403 51717056404" Parts will be printed once payment is made, preferably via PayPal. Prices include PayPal's exchange fees but if you want Buyers Protection that's on your end (add 5.5%). The prices are as following: - Front bumper ducts and brackets is 220$ - Race backing plate and funnels is 150$ - Standard backing plates and funnels is 110$ - As an option a mesh insert can be bought for the front bumper ducts to prevent stones and such to get into the hose, this option is an additional 150 SEK (~16$) per pair - Hose holders for the shocks is 15$/pair - Rear intakes and brackets is 180$ - Rear backing plates/funnels is 110$ If you've bought a complete front brake cooling kit from me before or buy both a complete for the front and rear I will give you a discount of 50$. As of 4th of September 2023 the shipping cost (max 2 kg) to the US/Canada/UK is 22$. Front bumper ducts and brackets. Full kit with race backing plates. Race backing plates. Left this old picture here so you can see how the standard backing plate looks like! Complete kit for the rear brakes: Only intakes/brackets for the rear: Only backing plates/funnels: Extras Mesh inserts Hose holders for the shocks, there's both a horizontal and vertical version.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 Last edited by Westersund; 11-10-2023 at 11:12 AM.. |
07-16-2019, 04:28 AM | #2 |
Rep 431
Such an awesome kit! Thank you for bringing this to the community! Wish this was available earlier this year when I needed to do a custom job that's likely not as effective.
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red | 2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo |
Westersund495.50 |
07-16-2019, 09:24 AM | #3 |
Rep 218
Drives: 2008 BMW Z4M Roadster
I'll take a kit!
2008 E85 ///MZ4 Roadster - Sapphire Metallic Black / Imola Red Int.
IG: Jessed.alvarado Mods: ProFlex E85 Flexfuel kit, Eventuri Carbon Intake w/ RPI scoop, Megan Headers, Custom Axle-back exhaust, KW V3 Coilovers, Stoptech ST40 BBK, Poly FCABs, APEX PS-7s, Diode Dynamics Headlights, CF Trunk Spoiler, Sideskirts & Diffuser. |
Z4M0620.50 |
07-16-2019, 10:50 AM | #4 |
Rep 1,130
Is there a picture in this thread? Because I'm not seeing any
2014 BMW X5 Sdrive35i F15
07-16-2019, 10:52 AM | #5 |
Rep 342
Will you include any instructions for installation? I'm a bit daft with a wrench, but can read and - preferably - interpret pictures
Do the hubs need to come off to mount those brackets? It looks like these would just bolt into the caliper mounting brackets, so I am assuming not, but want to check. I have an AP Racing BBK, about the same size as a Brembo or Stoptech kit. Do you think the bracket will fit? What 3" hose hardware is needed? Just the hose and hose clamps? Would something like this hose work: https://www.bimmerworld.com/Masterdu...e-7-Black.html Sorry for the potentially dumb questions, very interested in a brake cooling solution and this looks lovely, just want to make sure I know what I am getting into. Cheers, Eamonn |
07-16-2019, 11:34 AM | #6 |
Rep 25
brake cooling ducts
the components look great! would you have any pics of these installed with the front wheels are full lock? I am curious of the clearance inside the suspension to the wheels before committing to an order
thanks |
07-16-2019, 02:27 PM | #7 |
Rep 45
Been waiting for this for a while, great news!! I'm in, but also have a few questions I sent to Andre via pm, perhaps it's easier for everyone if he answers them all here and the others on this thread. Like eggman I also have the AP kit with the 32mm disc, which can cause issues even with the standard backing plate around the knuckle area.
What additional fixings are needed? What are the 2 brackets on the floor for? Does the backing plate cover the steering knuckle area? What length of hose would you recommend? Is there much advantage to having the pieces printed in CFRP? (I've measured my discs at around 600c) When you say "Minor modifications to the brackets might be needed." do you mean the brackets that you have supplied?
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, RPI, AP f&r w/RSL-29, Apex ARC-8, A048, KW CS, Turner arms & RTAB limiters, VT engine mounts, Rogue pulleys & RSMs, Tillett B6s, custom half cage, UUC ssk, M5 knob, oem strutbrace
07-16-2019, 03:56 PM | #9 |
Rep 876
That's wierd, I can see it without a problem. Try another browser.
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
07-16-2019, 04:02 PM | #10 | |
Rep 876
If you want to remove your OEM brake shields in one piece you'll have to remove the hubs. My brake shields are designed so that's not needed and they use the OEM mounting points for the brake shield. The brake shields are made for the OEM 345 mm rotors, but slightly bigger rotors won't be a problem. Not even on smaller rotors, I run this kit on my Z3 Coupe race car. You just need 3" hose ans 3" hose clamps, the hose you've been looking at looks like a good option.
07-16-2019, 04:05 PM | #11 |
Rep 876
Sorry, but I don't have a picture of that since I'm keeping my car "stock". I did this for the community as I know how hard it is modifying a car that's not that common. I guess any clearing issue depends on how you route your hose.
07-16-2019, 04:06 PM | #12 | |
Rep 876
"You will need hose clamps, hose, some bolts/nuts/shims and a few screws. Just some regular stuff. The 2 metal pieces on the floor is for mounting the front bumper ducts to the OEM mounting points. The bracking plate covers the steering knuckles, that's why they look the way they do. But at the same time I have cut away as much material as I can to keep them light. I haven't mounted this kit on my own car, but on my Z3 coupe I needed a little over 2 meters. I would buy 3 meter to be safe. The CFRP is 20% stiffer according to the manufacturer, so it can be made lighter and be just as strong as the other plastic I use. But no, CFRP is not needed. Temperature vise it's not much of a difference. Minor modifications is for the brackets that come with the kit. I'm almost 100% sure you won't need to modify them. But see it as a disclaimer to avoid unsatisfied customers."
07-16-2019, 04:51 PM | #13 |
dances with roads
4722
Rep 4,096
Subscribed! This is the first I've noticed this. Fantastic work! I'd really love to see a photo or two of an installed kit to get a feel for what I'd getting into. Even if it's shots of the Z3.
07-16-2019, 05:21 PM | #14 | |
Rep 45
I'm sure Westersund is more qualified to answer this than I, but at the worst the different dimensions of the bbk calipers will require a snip of the shield (it's of course the same kind of snip that is required with the oe ones to fit a bbk caliper).
07-16-2019, 10:24 PM | #15 |
Rep 342
Thanks for the info.
As a general question... There are different temp ratings for the duct hose. Given I track the car fairly regularly and am heavy on brakes with a BBK, which temp spec would be needed: 275 F 300 F 550 F The costs go up appreciably, so I don't want to buy anything unnecessary. Plus I would prefer the optics of a black hose, but not if it's going to be problematic. I did read that the 550 F hose should be used for a track car. As a kit specific question... I am not sure I understand the hose routing. When I look inside the wheel well, I don't see how hose can run from the stock air duct to the inside edge of the brake disc without interfering with the tires. How is the hose routed? How do I go about ordering? Send you a PM? Cheers, Eamonn |
07-17-2019, 02:25 AM | #16 |
Rep 876
I believe they will, the brake shields themselves bolt straight into the OEM bolt holes. However I've made the brake shields as small/light as possible but with enough material left to cover the steering knuckle to keep the rubber from melting. I don't think any material have to be trimmed in order to fit a BBK, there's hardly any material at all on that side of the brake shield for that reason.
07-17-2019, 02:29 AM | #17 | |
Rep 876
The hose routing will require cutting away some plastic at the front bumper, you'll see once you remove/fold away the wheel well liner. I route my hose on along the control arm, but each to their own.
07-17-2019, 02:35 AM | #18 |
Rep 876
Some pictures, note that I have the first version of the brake shield (simpler design) on my Z3 Coupe, haven't swapped it out for the latest version (the one in this thread) yet. I'm runing a 3" hose but will be changing to a 2", but with the size of the Z4 ducts a 2" hose makes no sense. But there's more space in the wheel well of the Z4 than the Z3 IMO. My tire will rubb on the hose slightly at full lock in the pits, but never on track.
Bonus picture of the livery:
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 Last edited by Westersund; 07-17-2019 at 02:41 AM.. |
07-17-2019, 02:38 AM | #19 |
Rep 876
Some pictures of a customers car, a E36 328 Ti M-Sport:
07-17-2019, 05:16 AM | #20 |
1621
Rep 4,294
Love the kit!! good stuff
I also love your Co-Driver!!!
Powered by |
07-17-2019, 08:03 AM | #21 |
Rep 45
Well I've ordered
Will post up pictures of the install for those interested, I hope to do it on Aug 1st. Have a track day on the 5th so will update with disc temp readings, hoping to be nowhere near the 600c I'm reaching now which is causing the discs some problems.. I've cracked 2 sets of AP (356x32mm) in 3 years, so $300 for this is cheap if it helps as I think it will.
wdb4721.50 |
