![]() SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
Thread Tools |
| 02-06-2025, 09:48 AM | #1 |
Rep 47
M54 euro headers?
I’m assuming there is a European spec for the M54 engine regarding headers with similar benefits to what some of us have been doing with the euros spec S54 headers.
Is there anyone with knowledge on this? I’ve had some good experience with European headers was wondering if there is an equivalent for the M54 |
| 02-06-2025, 01:56 PM | #2 |
#buildnotbought
20401
Rep 6,476
There's no such thing as european headers for the M54.
That would also be impossible as the M54 system doesn't have an extra catalytic converter under the car like the euro spec s54 systems have. And as all of the EU has mandatory periodic MOT with emissions test, you probably wouldn't pass that emission test without the catalytic converter. Afaik, all m54 exhaust manifolds are the same, so with build in cats, and a very restrictive collectorpiece (way more restrictive than the US s54 exhaust manifold). If I were to guess, the diameter of the collector (to the cats) is maybe 1"? (per 3 cyl) However there are loads of fairly cheap m54 ebay headers available that are supersprint copies if you want to build something yourself (you have to solve the cat system then). And Schmiedmann has their own header design in a fairly affordable SS exhaust system with secondairy cats (where normally the mid muffler is). E46 only, but if you can weld a bit, adaptable for E85. These are the schmiedmann m54 headers (but they don't mount up to the rest of the stock system, so you have to get at least also the mid section and adapt that a bit for e85 use): ![]()
Old-Vectors20.50 ///M Power-Belgium89139.50 |
| 02-06-2025, 02:27 PM | #3 |
![]() 2529
Rep 2,757
This what I used when replacing OEM non-M exhaust manifolds with a tubular header.
https://www.hottexhaust.com/magnaflo...-eo-d-193-137/ It may require some fabrication as the flanges are clocked different, to the tubular header I have at least. It should splice into the rest of your system after the cats.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX |
Old-Vectors20.50 |
| 02-06-2025, 03:57 PM | #4 | |
Rep 47
| 02-07-2025, 10:27 AM | #6 |
Rep 754
FWIW I have racing dynamics headers and full supersprint post headers. The O2 sensors juuuuuust fit routing them down the firewall under the heat shield to the supersprint O2 bung for the post O2 on their cat section. I was very skeptical that there’d be enough to reach the O2s but it juuuust makes it. I do live in a non emissions state so I’ve never had it checked if it’d clear in states that do. I can confirm no codes.
Also can confirm racing dynamic headers bolt to stock exhaust, had the headers on before my supersprint arrived….oh the joy of smells from exhaust with no cats. Last edited by Piper1; 02-07-2025 at 10:32 AM.. |
| 02-07-2025, 10:35 AM | #7 | |
Rep 47
| 02-07-2025, 10:41 AM | #8 |
Rep 754
| 02-07-2025, 11:15 AM | #9 |
Rep 47
OK so possibly what makes sense is to supercharge before they release the headers because then it makes sense
| 02-07-2025, 12:06 PM | #10 |
Rep 754
That’s what I did. Ran it few thousand miles in about couple months time frame with s/c on stock exhaust before piecing that together. Also put a 4.10 lsd at same time as s/c pretty close to same break in time for the both so made sense timing wise.
Old-Vectors20.50 |
| 02-10-2025, 09:11 PM | #11 |
Rep 47
Is there an actual LSD route that is best?
| 02-10-2025, 09:34 PM | #12 |
Rep 754
| 02-10-2025, 09:35 PM | #13 |
Rep 47
| 02-10-2025, 09:46 PM | #14 |
Rep 47
| 02-11-2025, 09:27 AM | #15 | |
Rep 754
No tune needed as far as I’m aware for us, it’s not an e diff it’s mechanical I’ve not noticed anything wonky when traction control is on and does kick in like it’d be planning open diff traction control vs lsd. Make sure to check out this https://web.archive.org/web/20200729...calculator.htm If you plan on changing ratio. It gives a ball park calculation what your rev range is when you change. Last edited by Piper1; 02-11-2025 at 09:29 AM.. |
| 02-11-2025, 09:34 AM | #16 | |
Rep 47
| 02-11-2025, 09:39 AM | #17 |
Rep 754
| 02-11-2025, 09:41 AM | #18 |
Rep 47
The stock diff is just too lack luster for me personally. I would do a rear end M swap but I can’t find any
| 02-11-2025, 09:46 AM | #19 |
#buildnotbought
20401
Rep 6,476
I think 1st gear is gonna be useless with that final drive ratio if you're gonna supercharge.
I drive with the stock 3.07 and when accelerating from a standstill in dry conditions I already have to hoover the throttle somewhere around 50-75% otherwise the tyres just light up (regardless of the speed you're doing). ESS TS2+ with cams Too bad that there are no separate gearsets for sale to adjust ratio's for independant gears.
| 02-11-2025, 10:03 AM | #20 | |
Rep 754
bit more conservative if daily driving too, even so I’d agree saying 1st is pretty useless at that ratio not even blinking and you’re through it. |
Old-Vectors20.50 |
| 02-14-2025, 09:07 AM | #21 | |
Rep 47
| Bookmarks |
