      02-06-2025, 09:48 AM   #1
Old-Vectors
Drives: Z4M E86
M54 euro headers?
I’m assuming there is a European spec for the M54 engine regarding headers with similar benefits to what some of us have been doing with the euros spec S54 headers.
Is there anyone with knowledge on this?
I’ve had some good experience with European headers was wondering if there is an equivalent for the M54
      02-06-2025, 01:56 PM   #2
GuidoK
#buildnotbought
GuidoK's Avatar
20401
Drives: Z4 3.0i ESS TS2+
There's no such thing as european headers for the M54.
That would also be impossible as the M54 system doesn't have an extra catalytic converter under the car like the euro spec s54 systems have.
And as all of the EU has mandatory periodic MOT with emissions test, you probably wouldn't pass that emission test without the catalytic converter.
Afaik, all m54 exhaust manifolds are the same, so with build in cats, and a very restrictive collectorpiece (way more restrictive than the US s54 exhaust manifold).
If I were to guess, the diameter of the collector (to the cats) is maybe 1"? (per 3 cyl)
However there are loads of fairly cheap m54 ebay headers available that are supersprint copies if you want to build something yourself (you have to solve the cat system then). And Schmiedmann has their own header design in a fairly affordable SS exhaust system with secondairy cats (where normally the mid muffler is). E46 only, but if you can weld a bit, adaptable for E85.
These are the schmiedmann m54 headers (but they don't mount up to the rest of the stock system, so you have to get at least also the mid section and adapt that a bit for e85 use):
      02-06-2025, 02:27 PM   #3
Steeler
Steeler's Avatar
2529
Drives: Built not Bought 04 Z4.
This what I used when replacing OEM non-M exhaust manifolds with a tubular header.
https://www.hottexhaust.com/magnaflo...-eo-d-193-137/
It may require some fabrication as the flanges are clocked different, to the tubular header I have at least.
It should splice into the rest of your system after the cats.
      02-06-2025, 03:57 PM   #4
Old-Vectors
Drives: Z4M E86
I will definitely look into this
      02-06-2025, 03:58 PM   #5
Old-Vectors
Drives: Z4M E86
Excellent info
      02-07-2025, 10:27 AM   #6
Piper1
Piper1's Avatar
Drives: E85
FWIW I have racing dynamics headers and full supersprint post headers. The O2 sensors juuuuuust fit routing them down the firewall under the heat shield to the supersprint O2 bung for the post O2 on their cat section. I was very skeptical that there’d be enough to reach the O2s but it juuuust makes it. I do live in a non emissions state so I’ve never had it checked if it’d clear in states that do. I can confirm no codes.
Also can confirm racing dynamic headers bolt to stock exhaust, had the headers on before my supersprint arrived….oh the joy of smells from exhaust with no cats.
      02-07-2025, 10:35 AM   #7
Old-Vectors
Drives: Z4M E86
Hell yeah
      02-07-2025, 10:41 AM   #8
Piper1
Piper1's Avatar
Drives: E85
Originally Posted by Old-Vectors View Post
Hell yeah
If you do go that route wait for the sales. I picked up the Y pipe/muffler combo first on sale, then the headers went on sale then the cat section. Took a year of on and off sales but saved a grand over all doing it that way.
      02-07-2025, 11:15 AM   #9
Old-Vectors
Drives: Z4M E86
OK so possibly what makes sense is to supercharge before they release the headers because then it makes sense
      02-07-2025, 12:06 PM   #10
Piper1
Piper1's Avatar
Drives: E85
That’s what I did. Ran it few thousand miles in about couple months time frame with s/c on stock exhaust before piecing that together. Also put a 4.10 lsd at same time as s/c pretty close to same break in time for the both so made sense timing wise.
      02-10-2025, 09:11 PM   #11
Old-Vectors
Drives: Z4M E86
Is there an actual LSD route that is best?
      02-10-2025, 09:34 PM   #12
Piper1
Piper1's Avatar
Drives: E85
I went through diffsonline, bloody expensive now for sure. I’d like to have the same on the coupe but might not be in the cards for a bit.
      02-10-2025, 09:35 PM   #13
Old-Vectors
Drives: Z4M E86
Sounds familiar, I’ll take a look.
      02-10-2025, 09:46 PM   #14
Old-Vectors
Drives: Z4M E86
Prices are normal considering that they offer.
However I’m curious if I need to get a tune performed for the LSD
      02-11-2025, 09:27 AM   #15
Piper1
Piper1's Avatar
Drives: E85
Pricing think is close to 1k more now than when I did mine so when I started looking at one for the coupe that was a gut punch.
No tune needed as far as I’m aware for us, it’s not an e diff it’s mechanical I’ve not noticed anything wonky when traction control is on and does kick in like it’d be planning open diff traction control vs lsd. Make sure to check out this https://web.archive.org/web/20200729...calculator.htm
If you plan on changing ratio. It gives a ball park calculation what your rev range is when you change.
      02-11-2025, 09:34 AM   #16
Old-Vectors
Drives: Z4M E86
Good point to note since I’m aiming for 3.91
      02-11-2025, 09:39 AM   #17
Piper1
Piper1's Avatar
Drives: E85
Stock diff also should hold up to answer your other post too, think last I knew dre99 is on stock open diff still with his 2jz swap putting way more down than what you’ll see from ess alone on the M54.
      02-11-2025, 09:41 AM   #18
Old-Vectors
Drives: Z4M E86
The stock diff is just too lack luster for me personally. I would do a rear end M swap but I can’t find any
      02-11-2025, 09:46 AM   #19
GuidoK
#buildnotbought
GuidoK's Avatar
20401
I think 1st gear is gonna be useless with that final drive ratio if you're gonna supercharge.
I drive with the stock 3.07 and when accelerating from a standstill in dry conditions I already have to hoover the throttle somewhere around 50-75% otherwise the tyres just light up (regardless of the speed you're doing).
ESS TS2+ with cams
Too bad that there are no separate gearsets for sale to adjust ratio's for independant gears.
      02-11-2025, 10:03 AM   #20
Piper1
Piper1's Avatar
Drives: E85
ESS TS2+ with cams
Whole heartedly agree on the ESS TS. I decided to go with the ESS VT +4.10 lsd for the same price as the TS was going for at the time so slightly different set up but that way it’s one less back slap I’d get from the Mrs if I blew something up never living down the I told you so bit more conservative if daily driving too, even so I’d agree saying 1st is pretty useless at that ratio not even blinking and you’re through it.
      02-14-2025, 09:07 AM   #21
Old-Vectors
Drives: Z4M E86
Seems like an E46 M3 differential swap could work considering everything is pretty much identical - the only components I’m tracking on swapping are the half shafts
