10-30-2012, 12:52 PM | #133 | |
Rep 104
You can get a degree or so using pre-existing holes in the strut tower. I'm fuzzy on the details but my BMW tech said it's kosher. No kit or anything, it's all there from the factory. |
10-30-2012, 02:57 PM | #134 | |
Not a New Member
94
Rep 925
the strut tower mod is simply removing the factory guide pins, and does not require any bolt kit. if there is some other mod going on, be sure to get detail and post them. zpost would be glad to have more information. also, you could use 4 front wheels on carefully selected tires. you would still need one helluva neg camber setting for the front though.
10-30-2012, 03:35 PM | #135 | |
Rep 104
That strut tower mod sounds right, it's just the guide pins IIRC. Wish I was the mechanical expert but alas, no. Hell, we're still trying to code out TPMS on my '07. |
10-30-2012, 08:45 PM | #136 |
Mad tyte EuR0 style boooi <--- Joke
212
Rep 2,472
Glad I found this thread.
Sub'd. I need to find wheels ASAP. Shamesless whoring, if anyone wants to buy some mint 5x112 OZ Ultraleggeras let me know. Back to fitment! |
11-02-2012, 01:22 PM | #137 |
Rep 12,570
Post in classifieds, that's what it's there for
11-04-2012, 12:49 AM | #138 |
Rep 60
Well after a long month or so wait, the new 18in 313's finally arrived. They fit great and are a huge improvement on the original elypical 202's i think, that are boxed up now for sale in Hong Kong... . Thanks for the help and advise to all from this thread!!!! Just a few more days and the BMW Performance brake kit goes on as well.
[/SIGPIC]
11-04-2012, 06:25 PM | #139 |
Rep 12,570
I want 313's in 18x8.5 square real bad...
11-13-2012, 08:52 PM | #140 |
Rep 415
Drives: 2005 z4 3.0
I'm not too picky, I just want 313s, 18 or 19s will do, no money for rims right now though
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips |
11-19-2012, 05:20 PM | #142 |
John 14:6
59
Rep 588
Would the following set of wheels fit a non-M that's lowered:
19x9 et48 19x9.5 et45
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
11-29-2012, 02:53 PM | #143 |
Rep 509
F: 8.5x19 ET 35 w/235/35 Nankang NS2
R: 9.5x19 ET 35 w/275/30 Nankang NS2
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
11-29-2012, 03:03 PM | #144 | |
Rep 509
Tires: 235/35 and 255/30 Yokohama Advan S. A tiny rub in the front with full compression and turning.
11-29-2012, 03:07 PM | #145 | |
Rep 376
12-02-2012, 11:31 PM | #146 |
Rep 60
Mate it should be all four , but due to other reasons its been delayed.
Hope to sort it out next week with the shop. Fingers crossed it works out.
[/SIGPIC]
12-03-2012, 03:46 AM | #147 |
Rep 1,546
gawd hellrot is so sexy.
12-17-2012, 02:59 AM | #148 | |
Rookie
33
Rep 379
1) Were camber plates absolutely necessary? If so, what camber are you running? Streetable? Are your fenders rolled? 2) Do you think these wheels will fit 17x9.0 ET30 (http://www.apexraceparts.com/ARC-8-1...l_p_151.html)? I am guessing yes because you got 17x9.5 ET35 to fit? 3) Instead of going with staggered 17x9.0 and 17x19.5, you picked square. Why? (I understand you may cite performance, ability to rotate, etc) I think I will go with 17's after seeing how your car looks. I don't want to lose the great handling/streetability on the car by going with huge heavy wheels. Looking great!
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
12-17-2012, 02:22 PM | #149 | |
Rep 12,570
2. Yes, 17x9 et30 will fit. While I'm running 17x9.5 et35, I am also using a 5mm spacer up front effectively making it a 30 offset. I needed the 5mm to clear my coilover perch. 3. I went square because I prefer having equal rubber all 4 corners for the track. While in theory it might help with longer life, I don't bother rotating. It's my dedicated track setup and I just wanted max rubber up front and keep the car as neutral as possible. Keep in mind my answer regarding camber was specific to my suspension and my wheels (9.5 et35). Also certain tires tend to have wider shoulders, ie Star Specs and RS3 will run wider than say a Michelin PSS or Hankook V12. There's good info here on different 17" fitments for NON-M Z4's on stock suspension http://www.zpost.com/forums/showthread.php?t=676629 Also before ordering, I would definitely ask Eddy @ Apex for confirmed fitments. Best of luck! |
12-19-2012, 03:48 PM | #151 |
Rep 19
What is the highest offset you can have with a 17? I'm looking at 17s with an offset of 35 and width of 7.5". Car is an '03 3.0i, base model, stock suspension.
12-20-2012, 12:41 AM | #152 | |
Rookie
33
Rep 379
2003 Z4 2.5i
12-20-2012, 07:22 AM | #153 |
Rep 12,570
For what it's worth all that rubber up front without camber will result in worse handling. It it's a cost issue take a look at Rogue Engineering's fixed camber plates. I had them and was able to get -1.8*.
12-20-2012, 09:52 AM | #154 |
Rookie
33
Rep 379
It's more of a streetability and tire life issue... I'm still deciding whether I should copy your setup (17x9.5ET35+camber_plates) or just go 17x19.0ET30. I really don't want to start heavily modifying my street car ... especially since "my other car is a 911"
2003 Z4 2.5i
