04-14-2012, 03:41 PM | #1 |
441
Rep 1,658
Z4 non-m track wheel test fitments
A friend with a stock non-m Z4 3.0 came by the shop the other day, so I took advantage and did some test fitting of 17" track setups. I did not take the photos so a number of ideal shots are missing.
Test #1 17x9" ET42 Square with no spacers. 255/40/17 Nitto NT-01 r-compound tire This setup fit perfectly up front. Strut tube clearance was fine, as was fender clearance. Any more aggressive and it would have fender issues though, so this is the limit in offset/width for a stock application. Sadly I don't have detailed photos of this front fitment, but I can verify that it was clean, and would only be aided further with camber plates. Here is a shot of the rear Rear clearance was easy. I would classify this as a conservative rear fit. There is room for this setup to be pushed further out. A 12mm spacer would make the rear fitment flush with the fender. Flush is not ideal for a track setup as you need the tire to fit under the fender, but if a narrower tire like a 245/40/17 were used, it would be ok to push the wheel out more for aesthetic purposes. This test showed that it would be easy to run 17x9" ET42 square with 255/40/17's on a stock car. There is no reason to go more conservative for fear of strut tube clearance as I could easily fit a finger between the wheel/tire and strut tube. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Test #2 17x9" ET30 rear with 255/40/17 Nitto NT-05 extreme summer tire This setup is the equivalent of running a 17x9" ET42 wheel with a spacer. The new concave 17x9" ET30 wheel is spacer free, concave, and lighter than the previous higher offset 9" wheel. The wheel is flush with the fender, but the 255 extreme summer tires run narrower than the previously tested r-compounds. The bead protector and part of the sidewall stuck out of the fender, but the actual corner of the tread was still within the fender on this setup. This is aggressive already, and could require a fender roll to eliminate all rubbing. I'd say there is a 75% chance that this setup would have no rubbing without a roll as long as the tire is no wider than what was tested. With either added negative camber or a roll, you could get away with more. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Test #3 17x9.5" ET35 rear with 255/40/17 Nitto NT-05 extreme summer tire The offset difference between this wheel and the 17x9" ET30 wheel makes the face of this wider 9.5" wheel only 1mm more aggressive. The rest of the wheel's width is pushed inward. The benefit of this is that the tire is centered further inward vs. on the 9" wheel. This combined with the slight stretch to the tire make this a usable rear fitment. This is the most aggressive of the 3 test fitments, but it still works. A fender roll in the rear would definitely eliminate any possible rubbing if a meatier tire like an r-compound were used. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Test #4 17x9.5" ET35 with 255/40/17 Nitto NT-05 on Front This test was only done to measure strut tube clearance. No spacer was needed to clear the strut tube. We do not have a test fit on the ground as this setup would definitely stick out of the fenders on the stock car an unusable amount. Camber plates could allow this front setup to fit with 2.5-3 degrees negative camber. The 9.5" ET35 wheel will not fit up front on a car without camber plates. It would stick out of the fender at least 10mm. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ After performing this test I would consider one of the following setups:
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Wheel Specs: 17x8.5" ET40 - 17.2lbs 17x9.0" ET42 - 17.4lbs 17x9.0" ET30 - 16.55lbs 17x9.5" ET35 - 16.95lbs
04-15-2012, 02:35 AM | #2 |
Rep 5,327
paint have you done one of these fitment guides for the ///M model??
04-16-2012, 11:05 AM | #3 |
Rep 12,546
Drives: Z4 M, 550i, X3
Garage List F15 X5 xDrive35i [9.00]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Thank you so much, this is exactly what I needed to know. Stickied for my future order... definitely going 17x9.5 et35 square! The question is what color do I go for!?
04-16-2012, 11:19 AM | #4 |
Not a New Member
94
Rep 925
04-16-2012, 11:54 AM | #5 |
Rep 12,546
Order just placed, 9.5 et 35 in Hyper Black, should be a fun track season! =)
04-16-2012, 12:08 PM | #6 |
1817
Rep 5,337
The ///M models have similar fitment to the E46 M3.
04-17-2012, 11:57 AM | #7 |
441
Rep 1,658
We have not yet. We'll be doing testing as tires and cars become available to us. We'll do even more in depth tests in the future.
Tags |
17x9, 17x9.5, 2.5, 3.0, track wheels |
