06-30-2013, 08:27 PM | #1 |
Rep 2,547
M5 Illuminated Shift Knob w/boot in a Z4
I bought a F10 M5 illuminated shift knob with boot from Tischer. I knew that the knob would fit but requires removing it from the boot by cutting a plastic ring up inside the boot near the shift knob. The leather on the M5 boot seems much nicer (thicker and softer) than the stock boot on the Z4 so I thought I'd try to use the M5 boot. The problem is the M5 trim base is squarish, while the Z4 base is ovalish. The M5 boot is stapled on, while the Z4 boot is glued on. So, out with the staples on the M5 boot it comes right off the base. The Z4 took longer since it's glued on the base, but a heat gun and a molding trim removal tool, I was able to get it off without destroying it. If I didn't care about destroying the stock boot, I could have cut the stock boot and removed it with little effort. The M5 boot fit on Z4 ovalish base with some relief cuts around the corners. I used contact cement and a heat gun to attach the boot to the base. The electrical connector is the same so it's a plug and play.
The F10 shift knob is weighted (ZHP), shifts are more positive, a little shorter than stock M knob, feels nice in hand and illuminates nicely. |
06-30-2013, 09:05 PM | #2 |
Rep 1,134
Drives: '07 M Roadster
Awesome! I just put the knob on my car a few weeks ago and loved it. I thought about trying to do it this way and use the M5 boot, but didn't want to bother with trying to switch the rings around. Looks awesome!
06-30-2013, 09:14 PM | #3 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Did it and love it! Wish i knew about heat gun. Took two hours with xacto. No wounds though!
06-30-2013, 09:37 PM | #4 |
Two Wheels or Four?
93
Rep 655
Any idea of the part number?
Current: '18 AW Performance Edition m240i Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci |
06-30-2013, 10:07 PM | #5 |
1621
Rep 4,294
awesome, i only did this a week ago or so, but my original Z4 boot wasnt that lucky. love the mod
Powered by |
06-30-2013, 11:57 PM | #6 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Sweet, nice job! My M coupe's illuminated ZHP knob has pretty pathetic illumination compared to the F10 knob. The F10 knob is very similar in terms of illumination to that in my E39 M5.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
07-01-2013, 07:33 PM | #7 |
Two Wheels or Four?
93
Rep 655
Appears that Tischer may have a special on these right now. I believe the part number is 25112284205.
Is the knob essentially the ZHP knob, besides the lighting? Anyone compare how much heavier it is than the stock knob?
07-01-2013, 07:46 PM | #8 |
Rep 1,269
The M5 knob is taller than the ZHP knob.
2019 Porsche 911 4 GTS
07-01-2013, 07:46 PM | #9 | |
Rep 2,547
The knob is much heavier then stock, but I didn't weight it since the boot was attached and would not be an accurate weight. It's heaver than the standard ZHP knob. Check this thread for more info. |
07-02-2013, 04:49 AM | #10 |
1621
Rep 4,294
Not meaning to hijack the thread, but have you seen, felt the BMW performance shift knob? I installed this thing last week on the recommendation of a fellow member, and I just love it. The weight is perfect and the lenth is also great.
http://www.turnermotorsport.com/p-17...d-pattern.aspx That's the review. |
07-02-2013, 08:57 PM | #11 | |
Rep 2,547
07-02-2013, 09:14 PM | #12 |
The Wrapgician
47
Rep 354
Drives: z4si
did the same thing, notes that the leather wont go all the way into the boot. about 80 % fit IMO
07-02-2013, 09:37 PM | #13 |
Rep 2,547
07-02-2013, 10:56 PM | #14 |
The Wrapgician
47
Rep 354
Drives: z4si
07-03-2013, 09:40 AM | #15 |
Rep 782
Just ordered it with the discount. Can't wait to get it installed. Love the illumination. I will NOT be so careful with the stock boot
2011 30i
[SIGPIC]/SIGPIC] |
07-03-2013, 10:19 AM | #16 |
Rep 2,866
OP...nice job refitting the boot Look very professionally done. How did you shape the leather around the ring so well? Did you have to use any clamps while waiting for the glue to dry? Or did you just use the heat gun and forced the glue to dry while shaping the leather?
07-03-2013, 12:44 PM | #17 |
Rep 1,663
Can someone take pictures or measure the M5 knob versus stock? If it's not that much shorter I might pick one up. With the SSK I prefer having the additional leverage.
07-03-2013, 05:45 PM | #18 | |
Rep 2,547
07-03-2013, 05:55 PM | #19 | |
Rep 331
http://www.zpost.com/forums/showthread.php?p=14149415 |
07-03-2013, 06:50 PM | #20 | |
Rep 1,663
07-03-2013, 07:10 PM | #21 | |
Rep 2,866
07-03-2013, 07:20 PM | #22 |
Rep 2,547
