02-22-2015, 08:00 PM | #1 |
Rep 115
Turbocharging - Pros, Cons, and Costs
I'm certain this has been discussed in depth before, but I couldn't find the thread so please forgive me. I would love to turbocharge my Z4, but I want to hear about the experiences you have had with your own.
What are the pros and cons? How much should I expect to spend? What performance gains can I expect? Feel free to dump your knowledge on me. |
02-22-2015, 10:06 PM | #2 |
Rep 405
I do not know your model, whether it be ///M, or 3.0 or 2.5, but I will speak of the s54 cars.
Simply put, it's never been done successfully (with stock Ecu). Our Ecu is known for being a pain to successful get power from. And if you search through old turbo build threads everything goes well until tuning is done. The only option is a standalone, and even then, I think some of the custom shops had difficulty. If you want to turbo a z4m, I advise you to buy an e46 m3. But if you are insistent, check out maximum psi or if you can find an old used hpf kit, go to lab22. Perhaps they could assist you with a standalone, im heisted I would expect you would lose some drivability and functions over the stock vehicle. Edit- just saw you have a 3.0si, my advise doesn't apply to you therefore and cannot be of much assistance. Goodluck |
02-23-2015, 01:41 AM | #3 |
Get Some
225
Rep 759
Drives: 07 Z4 3.0si
3.0si has a magnesium block, plenty of discussions on it and from what I remember the engine isn't suitable for F.I
02-23-2015, 03:59 AM | #4 |
Rep 876
Everything is relative and it depends how far OP is willing to go. You can always drill the block and put in steel liners (is that the right word?) when you're changing pistions/rods. That way the magnesium block should be able to handle the boost.
02-23-2015, 09:34 AM | #6 | |
Rep 115
In regards to the ECU, what makes it difficult to tune? I assumed I could take it to a performance shop and have it done pretty easily. |
02-23-2015, 11:05 AM | #8 |
Rep 2,704
The 3.0i M54 has very good potential for power using FI
The limiting factor as far as Turbocharging is indeed the ECU. It has been tried several times unsuccessfully. Supercharging on the other hand is very doable and there are at least 2 supercharged M54's on this forum with close to 300hp at the wheels Search "Pokeybritches" for one such car.
02-23-2015, 04:51 PM | #10 |
Rep 1,991
Do a search- it has been documented on this or another Z4 forum. I don't have a 3.0i so didn't need the info.
02-23-2015, 08:57 PM | #11 |
Rep 52
I've read a few different topics. I've seen pics of this kit on a FL car a little while back, but I can't seem to find it. I do know the car was sold years back. I think I remember them saying they used a stand alone to get this to work.
http://www.techniquetuning.com/bmw-e...st2-turbo.html |
02-23-2015, 09:47 PM | #12 | |
Rep 106
02-24-2015, 01:26 AM | #13 |
Rep 876
He can always get a forged crank from a M54. I have a feeling the list is going to be long getting that engine to handle the boost.
02-24-2015, 08:06 AM | #14 | |
Rep 2,704
Still stands that the ECU is the limiting factor on our cars
02-24-2015, 08:17 AM | #15 |
Rep 1,991
It actually is pretty cheap from what I remember. There are many intakes from other cars with the N52 si version which will work to convert an i to si. Under $1K for sure.
02-24-2015, 05:48 PM | #16 |
Rep 66
02-24-2015, 05:53 PM | #17 |
Rep 2,704
http://www.zpost.com/forums/showthread.php?t=392330
http://www.zpost.com/forums/showthread.php?t=455180
02-25-2015, 02:21 AM | #21 |
Rep 62
ESS was doing a supercharger for the N52 saw something pass on Facebook that they have installed one recently...
My Z : Lightnnings Z4
02-25-2015, 02:26 AM | #22 |
Rep 509
http://europeanautosource.com/ess-su...m-bmw-n52.html
http://europeanautosource.com/blog/j...ercharged.html
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
