12-02-2017, 05:11 PM | #1 |
Rep 23
First and second gears issues
Hi, I've only had my 2006 Z4M Coupe for a couple weeks now. It has 68,000 miles and it's difficult to shift into first from rest and then second. The other gears are no trouble. I make sure the clutch is all the way in but still. It's not a crunch but more like something is in the way? Not sure if this is common or if there could be an adjustment made. Thoughts? Thanks!
12-02-2017, 05:43 PM | #2 |
Rep 25
I have only been on the forum for a short while, but first and second are sticky in many of these cars. Mine seemed so at first; almost like there was some obstruction, but as I have become more familiar with the car, the stickiness has abated until I no longer really feel it. You will become smoother with time. There are many members more qualified to speak to this issue, and I am sure you will hear from them.
bfm016.50 |
12-02-2017, 07:16 PM | #3 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
While I'm not sure why you have trouble getting the transmission into first gear at rest, the 1st to 2nd gear shift can be difficult on the M coupe until you get used to it. There are a few posts located in the FAQ sticky above (the first post) that you will find useful.
If you haven't already, I suggest CDV delete and a slightly weighted ZHP shift knob (https://www.leatherz.com/products/il...ort-shift-knob). The combination of these two easy modifications is significant. GL!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
bfm016.50 |
12-02-2017, 07:55 PM | #4 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Also, a weighted shift knob had a very noticeable improvement for me. I used the lighted weighted shift knob from an M5 (F10), and cut and glued the leather boot onto the Z4 plastic retaining "hoop." http://www.zpost.com/forums/showthread.php?t=1422560 Salty
12-03-2017, 01:26 AM | #5 | |
Rep 133
I also felt my M's Gear changes to be sticky when i got the car a year ago.. to try to remedy it, I fitted uprated Gbox Mounts, New gearbox Oil, CDV Delete and ran the car like this for a year thinking i got it sorted as the shifts were so much better... and then this past friday i fitted the weighted ZHP knob, man or man, why didn't i do it sooner... it feels great, all the above really transformed the way my car takes gears now... Smooth like silk.
12-03-2017, 07:04 PM | #7 |
Rep 23
Some good info...thanks people! I do already have a weighted knob and it's great. The CDV issue sounds like a promising fix along with new fluid. Appreciated!
12-03-2017, 09:16 PM | #8 | |
Rep 870
Salty
bfm016.50 |
12-03-2017, 09:22 PM | #9 | |
Rep 870
Salty
12-04-2017, 11:31 AM | #10 |
Rep 23
Ok, good. So I ordered the Zeckhausen modified CDV and want to order the Royal Purple but can't seem to find the quarts/liters needed. I feel like it should be easy to find but I can't. Can someone please let me know? Thanks again...
12-04-2017, 12:00 PM | #11 |
salty cowboys fan
6158
Rep 3,407
Have a weighted F10 knob, cdv delete, engine & trans mounts, SSK, and relatively new fluid... 2nd gear is apparently a bitch if you shift too fast no matter what you do scary moment on track flying into corner getting denied 2nd
Just be a hair slower and deliberate with your change I think
bfm016.50 |
12-04-2017, 12:45 PM | #12 | |
Rep 870
http://a.co/3A5dp24 If you are looking for a local purchase, Pep Boys is a good option if you have them in your area: https://www.pepboys.com/product/details/9334508/00105 Use code MMJ20 Salty
12-04-2017, 12:55 PM | #13 |
Rep 679
60000 miles is usually the end of fluid life with bmw "lifetime" fluid. I used royal purple synchromax on an E46 330i and its great. Havent done my Z due to low mileage but will. Youll need about 1.5 liters and new washers. I must be the only forum member that loves the stock clutch with no cdv delete. Perfect bite 1/2 way up the travel.
bfm016.50 |
12-04-2017, 12:56 PM | #14 |
Rep 870
I just re-read your post. If you're talking capacity, you'll need two liters. Transmission holds 1.5 liters. Diff holds about 1.1 liters.
Salty
bfm016.50 |
12-04-2017, 02:10 PM | #15 |
Rep 3,286
This is not complete, but a good start regarding fluids:
http://www.zpost.com/forums/showthread.php?t=537104 BTW, PS fluid is not listed, but the Z4M coupe/roadster use ATF (about 1.5 L).
bfm016.50 |
12-04-2017, 07:54 PM | #16 | |
703
The third to second denial issue is super common quirk and all do it under heavy g load. We did extensive trial/error on this years ago here and there's no silver bullet. Improvements, but under heavy g. I just stay in third, the time lost due to poor gearing isn't as big a deal as nope nope nope and maybe second or back into third. If that's not an option and your track layout makes this sensible, you could change to a 4.1 diff and then third would have more torque at the wheels. |
12-04-2017, 10:13 PM | #17 | |
salty cowboys fan
6158
Rep 3,407
12-05-2017, 12:49 PM | #18 | |
703
Using an E46 and an E36 we did some timing tests, and the conclusion was staying in third gear no matter what with those cars was one second faster. It feels faster to get into second, but the differential in weight transfer, along with the time to shift, really ends costing time. We tested this theory going into and out of some esses, so the weight transfer/unsettling of shifting before full corner exit is probably driving more of the timing issues than the actual shifting activity itself. Since you're not out to win any races, and this is supposed to be fun, if you can manage to get second gear to work I say go for it. Note: be careful with autocorrect and the word "esses". If you use your imagination and replace the "e" with an "a" and one of the sentences above you can see why! |
12-05-2017, 04:59 PM | #19 |
Rep 150
I also agree about the break in and changing the transmission fluid.
When I got my M coupe I suspect it hadn't been driven very much for a long while. The gears got easier as I drove it more and then I changed the transmission fluid and it became downright sweet after that. They say that the transmission fluid is supposed to last the life of the car, but it isn't true. |
bfm016.50 |
