      05-27-2011, 02:04 PM   #1
biped
Drives: 97 e38, 01 e38, 07 z4mc
Z4 Maintenance Information
I'm trying to put together a table of information related to maintenance on the Z4's. For the DIYers. But I'm pulling a few blanks and would appreciate any input. The information I have so far is either from the manuals/inspection sheets/TIS or various posts on this and the other forums.
2006-08 Z4 M Roadster / Coupe
Engine Oil
Volume : 5.5 litres
Suggest Interval :
Recommended :
Castrol TWS Motorsport SAE 10w-60 Synthetic
Castrol Formula RS 10w-50 Synthetic
Parts :
Engine Oil Filter BMW PN # 11 42 7 833 769
Engine Oil Filter O-ring PN # 11 42 1 741 000
Oil Pan Plug PN # 07 11 9 904 550
Oil Pan Plug Washer PN # 07 11 9 963 151
Transmission Oil
Volume : 1.5 litres
Suggested Interval :
Recommended :
Catrol MTF-LT-2 PN # 83 22 0 309 031
Options :
Amsoil 5w30 Manual Syncromesh
Amsoil 75w90 MTF
1/2 Redline D4ATF & 1/2 Redline 75w140NS Gear Lube.
Royal Purple
Pentosin MTF2
Parts :
Screw Plug with Gasket Ring PN # 23 11 7 531 356
Differential Oil
Volume : 1.1litres
Recommended :
Castrol SAF-XJ PN # 83 22 1 467 993
Castrol SAF-XJ + FM PN # 83 22 2 282 583
Options :
Amsoil Severe Gear 75W140
Redline 75W140 GL-5 Gear Oil
Parts :
Notes :
Find a parking lot and do several tight circles in both directions to aid lubing.
Brake Fluid
Volume : 1 litre
Power Steering Fluid
Volume :
Coolant
Volume : 10.7 litres
Suggest Interval :
Instructions for Oil/Inspection Reset
  1. Insert Key
  2. Hold Trip Reset Button and turn ignition to first position
  3. Hold Trip Reset Button until display shows "Inspection Reset/Oil Change Reset"
  4. Release and Hold Trip Reset Button until Reset flashes
  5. Release and Press Trip Reset Button once
  6. Release and Press Trip Reset Button again
Next oil service interval will be shown and disappear
Oil service lamp is now reset
Last edited by biped; 05-29-2011 at 12:50 AM.. Reason: Added volume information from Ron Stygar
      05-27-2011, 02:09 PM   #2
Beedub
great post :-)
      05-27-2011, 02:29 PM   #3
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Would love to see a non-M version of this. For the slower folks.
      05-27-2011, 02:41 PM   #4
tekmoe
tekmoe's Avatar
55
Drives: ///M
Great post.
For the record, I've been running Redline 75w140 in the diff and I've not had a single problem with grinding noises. Best stuff out there, hands down.
      05-27-2011, 08:04 PM   #5
pal
pal's Avatar
433
Drives: Z4 M Coupe
My intervals
Engine Oil - Every 2-3 track days or 3K-4K miles (Blackstone every sample)
Trans Fluid - every 40K miles
Rear Diff Fluid - every 20K miles
Coolant - Every 50-55K miles
      05-27-2011, 09:31 PM   #6
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Originally Posted by pal View Post
My intervals
Is everyone forgetting power steering fluid? I've been using a turkey baster and Mobil 1 synthetic ATF at 30k intervals.
      05-28-2011, 12:07 AM   #7
beta
Drives: 2006 M Roadster
Engine Oil suggested interval I'd say 7.5k. It lines up really well with the regular schedule, it's twice as often as BMW recommends, and most oil analysis I've seen showed that it would be fine. I'll see if I can dig up some links.
      05-28-2011, 12:17 AM   #8
biped
Heh, this is cool, I was naive and didn't factor the track guys will be exchanging fluids more regularly, ideally I was just looking for factory recommended intervals. I guess just expected track guys to already be on top of their own needs But having that info is great.
      05-28-2011, 01:27 AM   #9
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
Hey, I'm not a track guy, but I try and exchange fluids as regularly as I can
      05-28-2011, 11:15 AM   #10
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Not sure if this applies to the M but brake fluid interval for regular street use is every two years and I believe 1.1 liters. You need roughly 2 liters to flush.
      05-28-2011, 11:55 AM   #11
jdl1pt
Drives: Z4M coupe 2007 IL Blue
That volume can't be correct. I just flushed my Clutch and brake lines with super blue and did it in less than a liter.
Great post, i say sticky!
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      05-28-2011, 12:03 PM   #12
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
Once this is complete...this should be a sticky for everyone to have quick access to it.
Now if someone would post the same for the Z4 2.5, 3.0i and 3.0si
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      05-28-2011, 12:07 PM   #13
Ron Stygar
Drives: 2006 Z4 M Coupe
Originally Posted by jdl1pt View Post
That volume can't be correct. !
http://www.bimmerfest.com/forums/sho...4&postcount=36
      05-28-2011, 05:42 PM   #14
biped
Will look to see what info I can gather for the non M models,
      05-29-2011, 12:38 AM   #15
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
This is great. Let's make this a sticky then hang the first person to ask "What fluids and how much?" Just like I want to scratch my eyes out when a newbie asks if the Z4 is a good car to buy.
If I'm going to rant I'll contribute. Here's what I've compiled for my 3.0si N52 engine. Same for the 3.0 if it's an N52 (2006 and later I think). Not sure about the 2.5.
OEM Spark plug = 12120032138
Bosch Spark Plug FR7NPP332 (cheaper to buy Bosch plugs then BMW OEM part number for exact same plug)
Oil:
OEM Oil 07510017866 = 6.9 quarts (safe to use 7.0)
Oil options = Mobil1 0w-40 Full Synthetic Euro Spec
OEM Oil filter = 11427541827 (comes with drain plug crush washer and two filter housing o-rings making it cheaper than buying filter, washer and orings separately)
BMW Coolant 82141467704 = 9.3 quarts Link to DIY here.
Need about 5 gallons fresh water and 1.5 gallons of BMW coolant (Mixes with water 50/50)
64316915764 Charcoal Cabin Filter
13717542545 Engine Air Filter
61610154440 Wiper Blade Refill (cut to size)
Edit: I'm adding this info on ATF. I know there's a huge debate on "lifetime" fluids and such, but this is what I did.
ZF Automatic Transmission
OEM ATF Fluid = ?
ATF Fluid Options = Valvolene MaxLife Dex/Merc ATF = Drain and refill ~8 quarts
OEM ATF filter and plastic pan = 24117536387
Interval = BMW says 100k then drain and replace filter. I drained and refilled at 25k and plan on draining/refilling WITH filter change at 50k.
Might I suggest links to BavAuto and Tisher? You have to compare prices between the two. BavAuto wins if you meet their $150 free shipping minimum.
      05-29-2011, 12:45 AM   #16
biped
Not sure if I should amend the non M models to the original post, or start a thread per each. Also wasn't sure about the policy with link posting, I know on the 'other' bmw forum, they have sponsors, and it could be a source of conflict.
I think probably best to rename this topic, not M specific, and will amend your info to it
      05-29-2011, 01:30 AM   #17
santov
santov's Avatar
64
Oh on Brake Fluid I heard a great idea:
Alternate between ATE Super Blue and Super Gold so when you start to see the "new" color you'll know you've purged the old stuff.
I haven't done that since I'm still in warranty and don't want to introduce any warranty issues with aftermarket fluids. But plan on switching to this method post-warranty.
In the meantime I just use Valvolene DOT 4 full synthetic. It's very clear in color so still easy to identify when old fluid is purged.
      05-29-2011, 12:28 PM   #18
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
@Santov, I picked up Valvoline synthetic and it's marked DOT 3 AND 4. Are you running the same?
      05-29-2011, 11:09 PM   #19
santov
santov's Avatar
64
My bad... I had ATF on the brain. The DOT4 I got at Kragens was Prestone. I like it since it looks clear like water making it ready to see when the fresh fluid is pumped out.
      05-31-2011, 09:37 AM   #20
45ACP
Long Live the 1911
45ACP's Avatar
Drives: Hooptie
Stock wheel lugs should be torqued to 88.5 ft-lbs.
      01-17-2014, 01:34 PM   #21
just2talented
just2talented's Avatar
Drives: Alpine ///M roadster
Amsoil 75w90 MTF
these will work in our transmissions? Amsoil is the best out there hands down but I wasn't aware they made anything for our cars. Has anybody ever tried either of them?
      04-26-2016, 11:42 PM   #22
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Bumping this thread up because:
1) I found it very useful
2) Wondering if any additional parts are needed for the differential oil change other than the fluid (washers, etc.).
Getting ready to perform diff and tranny fluid changes as I'm almost at 30K miles.
Thanks!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
