09-15-2017, 02:36 PM | #1 |
Rep 401
Shift knob problem
My stock Z4M shift knob keeps coming off. It's now extremely loose. I can see the tabs are broken inside. I've read some threads on this issue but it isn't clear to me how to fix this. Does the whole shift knob need to be replaced or can the interior fitting be replaced?
09-15-2017, 02:40 PM | #2 |
Rep 1,543
It's probably easier to just replace it unless you want to glue it together. I have some shift knobs sitting around if you need one. I have OE, ACS copy knob etc.
09-15-2017, 04:28 PM | #3 |
Rep 401
09-15-2017, 04:40 PM | #4 |
Rep 870
Drives: 2006 BMW Z4M Roadster
Kav, the lighted one from an M5 is very nice and is weighted. It's amazing the difference in feel it makes when shifting. I was blown away. Didn't believe it would make much difference, but I was very wrong.
BMW Part Number: 25-11-2-284-205 You will have to cut and glue the boot onto the Z4M plastic mounting ring, but it's not a hard job. I used contact cement. If you want to go this route, I'll try to find the link to the DIY that was helpful. Salty
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete Last edited by SaltyNC; 09-15-2017 at 04:42 PM.. Reason: Gave wrong part number initially |
09-15-2017, 04:44 PM | #5 |
Rep 870
StickMon636.00 |
09-15-2017, 05:02 PM | #6 |
Proud E86M Owner
79
Rep 650
I am doing the M5 shift knob exchange too very soon. Link looks very helpful. Thanks for the link. I purchased the M5 one because of all its positive feedback and reviews.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
09-15-2017, 05:34 PM | #7 | ||
Rep 401
Thank you Salty! |
09-16-2017, 02:13 AM | #8 |
636
Rep 3,124
I'll vouch for the F10 M5 knob.
I've had one for years and I love it. Don't be put off by the boot mods. I'm terrible with scissors and glue, but I had no problem with it.
09-18-2017, 08:00 PM | #9 |
Rep 2,547
As others have said, the M5 shift knob and boot is a great upgrade.
09-22-2017, 04:24 AM | #10 |
Where Does He Get Those Wonderful Toys?
94
Rep 290
Don't let pungo's pick fool you. I have it also and the color is identical to the dash lights. It Always looks more yellow in pics. It really is easy to put out ring on. I'm not handy whatsoever with that type stuff and I got it done on my couch in about 10min.
09-27-2017, 02:23 PM | #12 |
Rep 401
Quick question guys. I'm about to order the M5 knob.
I have the UUC short shifter installed. Has anyone used the M5 knob with this short shifter? I just wanted to make sure it did not make it too low? it seems like the M5 knob sits lower. |
09-27-2017, 04:27 PM | #13 | |
Rep 1,543
09-27-2017, 05:24 PM | #14 |
Rep 870
You can see the difference in height in this photo, kav. No experience with a short shifter.
http://www.zeleznik-klein.com/z4/fix...tKnob-047.html Salty
09-27-2017, 05:31 PM | #15 |
94
Rep 290
I have a short shifter in mine. My zhp fit fine but when I upgraded to the illuminated m5 knob I found myself pulling it off all the time. The base of the knob where the boot meets is just ever slightly longer than the zhp by itself making it not fully seat into the short shifter. I put a drop of silicone into the slit in top of the shifter and it seems to be holding fine as of right now.
09-27-2017, 06:04 PM | #18 |
94
Rep 290
09-27-2017, 07:57 PM | #19 |
Proud E86M Owner
79
Rep 650
I am also duing M5 Shift knob and Autosolution Short Shifter, I hope its okayfor me. I hearded very good reviews for both this Shift Knob and this Short Shifter.
09-27-2017, 08:14 PM | #20 |
94
Rep 290
Oh I love it very much! That's the only problem I had. Other shifters may not even have that problem. Just on mine where it flares out below the knob securing slot, rubs the bottom of the boot attachment ring and doesn't let it seat 100%. I have seen people cut the boot off just to have the illuminated knob, and theirs seats correct. I've been driving it for a few months since applying the silicone and I haven't pulled it off again.
On a side note, only took about 10 minutes to swap my base ring onto the m5 boot. |
