09-11-2019, 09:55 AM | #156 | |
Rep 17
Drives: 2006 z4 3.0i sport pkg
so i have the 3 stage manifold installed, but i have not flashed the ecu. i was looking in the INPA software and under the VIMDISA menu i was able to test the disa valves. what is interesting is when driving the valves are actuating, and i can feel the power increase in the 5k rpm range. is this normal for a stock 3.0i without the ECU flash? |
09-11-2019, 08:51 PM | #157 |
Rep 244
Drives: 2006 330i Manual
RSA delete failed on me
RSA delete failed on me, now my car just cranks. I have the bimmergeeks cable with latency set to 1 on COM 1 and the latest version of their standard tools. My laptop has Windows 10 on it.
I have an 07 3.0 and was tempted by the bimmerlabs batch file. I also posted at e90post as there are many there with so much experience in flashing. If anyone can help I'd be very grateful. Thank you. This is the error that I received. https://1drv.ms/u/s!AnlavCs9oGBdlM1dzxn-lYudrwEfhQ |
10-24-2019, 07:16 PM | #158 | |
Rep 2,287
I can assure you the Bimmerlabs files for the 3.0 work. |
12-29-2019, 12:02 AM | #159 |
Rep 244
I never did resolve it. After about a month without the Z4, I attempted to flash the old 3.0 file back on and it worked without issues. I'll try again in the spring for the SI power.
01-01-2020, 05:13 PM | #160 |
Rep 775
The bimmerlabs files should work. If one prefers, I can also supply a program variant that ignores the hours counter on the DME and allows the powerclass to be changed - that would allow you to flash an unmodified 3.0si tune.
01-14-2020, 10:04 AM | #161 |
Rep 16
I used Bimmerlabs to flash to the stage 3. One of my disa valves broke so I'm going back to stock. I already put the old manifold on. What files do I use to flash back to original? Also, Bimmerlabs website is down. thanks
01-14-2020, 06:59 PM | #162 |
Rep 775
Just do an "upgrade" with WinKFP, that should flash it back to the latest version of a stock tune
01-15-2020, 06:20 PM | #163 |
Rep 2,287
Bimmerlabs was down for a short period. Hassmachine has it up and running again.
01-22-2020, 10:48 AM | #164 |
Rep 244
I'll try flashing it in the spring without using the batch file. If that doesn't work, then I'll get back to you. Thanks!
07-02-2020, 02:56 AM | #165 | |
1999 E46, 2002 E53, 2007 E85....all in progress
Rep 103
to look for that will work on my 2007 Z4 3.0i roadster. Can I buy one off of a 3.0Si Z4 and bolt it right on? I know I'll need a tune later for full activation and hp gain. I found the one shown below. It says modifications needed. Thanks for any help. -
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... |
07-02-2020, 08:40 AM | #166 |
Rep 2
I did this about a year ago and am happy with it. Bimmergeeks and Bimmerlabs are pretty awesome. I suggest you download all the software and make sure it works for you, that was my biggest obstacle really. Had my desktop down in the garage because the laptop wouldn't cooperate.
As far as that manifold goes, it seems to pricey, but . . . they says the DISAS are tested and working = BIG PLUS. Those are stupid expensive. It also has that heated PCV hose on the right side, those break easily, are a pain to replace and not cheap either. I would expect its cracked, but if not then it is a valuable piece of insurance in case yours cracks during the process. Some people say to just buy them to have them just in case. There is another one on the under side, but I don't see it in the pictures. It also has the BMW cover. The mods mentioned are probably just for the small parts change over. My manifold was from an X5 and I had to swap brackets and stuff over, not a big deal. It may actually be worth the price. All I will add is that some cars, I think earlier ones like mine, had the oil separator under the manifold and some are above it. There is like a Y shaped PCV hose involved there. i know nothing about that; check under your hood thoroughly before buying and there are fixes for the mismatched hoses thing if you research it. Familiarize yourself with bimmerlabs if you are going to DIY your ECU flash. or look into Active Autowerk. Turner has a flash tune, but it is DIY, Active Autowerk (AA) uses "delaers", approved shops. There is some level of guarantee in that since a tech will be doing the work for you. |
07-03-2020, 03:55 PM | #167 | |
Rep 103
Is that what you meant? I doubt there is anyone in my area to do tunes like this. I called the two I know about and they almost laughed when I said BMW. I am not mechanically inclined but will work on stuff if I can find a YouTube video of whatever I need done. I'll have to go look at my X5 and see if it has a 3 stage intake also. -
07-17-2020, 11:44 AM | #168 |
Rep 103
N52 Vs N52 B30?
Hello all. Hope everyone's Friday is going great. Recently I bought an intake manifold from a user here and the tag on it is shown below. Seller said it came off of a 2006 330i. My 2007 3.0i has an N52 but I see some some engines listed as N52 B30 like it shows on the tag.
Are those the same engines? If not, how do I tell exactly what engine I have in my car? Thanks -
08-10-2020, 02:18 AM | #169 | |
Rep 103
I purchased a 3 stage intake from a 2006 330i and I want to install on my 2007 Z4 3.0 i to convert it to an Si. I assume getting the Si software on it "should" up my HP to 255 like the Si came OEM from BMW correct? Thanks -
08-10-2020, 09:03 PM | #170 | ||
Rep 2,287
08-25-2020, 05:15 PM | #171 |
Rep 1
UK 2.5I
Hi everyone,
I’ve been wanting to do this mod for awhile but I’m a little confused about the tune. Do I need to select one that is specific for my model of z4? So in this case, flash a tune from a 2.5si? Or is there a way of knowing which will work? |
08-29-2020, 11:27 AM | #172 | |
Rep 244
From my understanding, this 3.0i to 3.0si flash is for 3.0L N52 motors (2006-2008) that just need to swap the intake manifold. All I did at bimmerlabs is type in the VIN and then the files for my car were displayed. |
08-29-2020, 06:36 PM | #173 | |
Rep 2,287
Your car/upgrade request is pretty rare. Check with him directly. If he's too busy, that's something I could post for you in a few minutes. If Hassmachine does not respond , send me a PM. |
08-30-2020, 02:57 AM | #174 |
Rep 103
Thanks. I will check them out.
09-26-2020, 04:34 AM | #175 |
Rep 21
Drives: 2006 Z4 3.0i 6spd manual
Just finished my swap. $150 for 3stage intake manifold, $30 for gaskets, 4 hours total for swap (take lots of before pictures). Drove to Kassel Performance in York PA for the ecu flash. $180 for stock 3.0Si, I went with the stage 3 tune for $359. You can mail in your ecu for the flash. Definitely check them out if you looking for ecu upgrades or custom work.
wdb4762.50 |
09-27-2020, 10:18 AM | #176 | |
Rep 103
What car tune did you use? I dont see an E85/E86 listed anywhere on their site. -
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress..... Last edited by CrazyOneToo; 09-27-2020 at 10:39 AM.. |
