04-12-2014, 09:54 PM | #1 |
Rep 38
Thoughts after upgrading from 3.0i to Z4M roadster
I thought I would share my opinions after recently buying a Z4M roadster, after coming from a Z4 3.0i.
The cars: 1 - 2003 Z4 3.0i Roadster - 6spd Manual - fully stock ~82k miles 2 - 2006 Z4M Roadster - 6spd Manual - fully stock ~20k miles My random thoughts/opinions:
I think that's about it... definitely VERY happy with the purchase. I love the 3.0, but The M is exactly what I was hoping for. I would recommend anyone thinking about it should at least drive one to get a sense for yourself. Selling my 3.0 here if anyone is interested - http://losangeles.craigslist.org/wst...414208173.html |
04-13-2014, 12:07 AM | #2 |
Rep 1,034
Every E85/E86 Z4 uses the same 6-speed transmission (the 2.5i had a 5-speed though). Many of your points have more to do with wear/age and general changes that were done for the 2006 facelift or as production evolved.
And you didn't even mention the limited slip diff. You could try something like this for a simple bluetooth solution. Just plug it into the AUX input.
04-13-2014, 12:37 AM | #3 | |
Rep 2,002
Another solution which would likely sound a lot better is to go with the USA Spec unit and add the BT streaming module. There was a thread about this recently(http://www.bimmerfest.com/forums/sho...t=#post8225267). It is a very reasonable way to get the job done. |
04-13-2014, 01:21 AM | #4 |
Rep 1,034
He should install the AUX no matter what he does, it's so easy, and it cheaper if you get the E46 cable and install it in the stock location instead of that silly ashtray.
04-13-2014, 02:56 AM | #5 |
Rep 73
Drives: 2011 BMW X5 xDrive35i Titan Si
Interesting!!!
I did a test drive of an Z4M roadster some time ago and I agree with you on the differences you found. For me how solid the car felt and the feeling of the steering were the most noticeable differences. My car has an 3.67 differential so I didn't feel day and night difference in the acceleration. I'm kind of on the same boat, trying to sell my car now in order to get an Z4M coupe or roadster (going towards the coupe more for now). How long have you had your car for sale? I've had it for 3 weeks so far and not much interest. I got a couple of "offers" but they were offering just too low and I rejected them right away. Mine is an 03 with 89,455 on the odometer, 6 speed manual and in excellent condition as well (a lot maintenance done as well). In the past I sold my 3 series and Z3 within 2 weeks of posting them, I feel that with the Z4 is harder. |
04-13-2014, 08:37 AM | #6 |
Rep 2,784
I agree on the differences, and my list would probably have mirrored yours if I was to have made one after my first drive in an M.
The "planted" feel is probably half steering feel/suspension setup from the factory, and half due to your 3.0's OEM shocks. Replacing your worn shocks will return the solid feeling, but the M does give more feedback and is more communicative about where the limit is. Because of this, I feel I can utilize more capability in the M. 100% agree on the steering wheel. After driving the M a bit, I felt like I was driving a teenage girl's car in the non-M due to the steering wheel. When I decided to keep the 3.0i and start modding it, one of the first mods was an M wheel. It's one of those things only the driver gets to appreciate, so you won't get any oooohs and ahhhhs when others see/hear/ride in the car. But, it's one of the best things you can do to a non-M for $575.
04-13-2014, 09:30 AM | #7 | |
Rep 38
"The Z4 M Roadster and the Z4 M Coupé were introduced in 2006. They feature the (In the US) 330-horsepower 3.2 L S54B32 engine. A new six-speed manual transmission is used . It's the only transmission available and its final gear ratios are virtually the same as in the M3. The M Roadster has a 6-speed getrag manual box." From http://www.bmwz4roadster.net/bmw_z4_history.htm I didn't even know about the limited slip diff! |
04-13-2014, 09:32 AM | #8 |
Rep 38
I think this is all I would need. I was disappointed the 2006 was missing the aux input under dash.
04-13-2014, 11:15 AM | #9 |
Rep 2,002
The USA Spec has an Aux-in as part of its connections and gives a lot more flexibility. I wouldn't waste time with the OEM unit with what he wants to do.
04-13-2014, 11:50 AM | #10 |
Rep 38
Do you have some more info about this? Do I need to buy an oem connector to add this cable/input socket? Thanks
04-13-2014, 12:10 PM | #11 | |
Rep 2,002
I do not personally have this as my car had the OEM ipod connection kit, but wish I did. Seems to be much better and even scrolls the song info on the business unit radio. |
04-13-2014, 12:47 PM | #12 |
Rep 2,784
The transmission on the M feels different than the non-M, that is a fact. The M's is like a boxing coach that smacks you every time he sees a mistake. The non-M has smoother engagement and doesn't feel as clanky. For 90% of my driving, I prefer the non-M's feel. The M truly shines at high speed. When pushed hard, it feels perfect. Most of this probably has to do with the clutch/flywheel combo, and some has to do with the differences in engine rpm when shifting.
04-13-2014, 11:43 PM | #14 |
Rookie
33
Rep 379
I've been driving a Z4 2.5i for a year, I love the car so much that I just bought an Z4MC today and shifting isn't as nice, for sure. For one, the shifter is way notchier, much like my E39M5 was, and I hated that gearbox. The other thing, is that I removed the CDV from my 2.5i and I keep missing/bloopering shifts on the Z4MC. The CDV is coming out this week if I can help it.
Overall the car is very similar but moving to a coupe I can really feel the extra weight up high. The car is much more responsive but as a consequence it's not as nice of a ride. The 2.5i was the perfect car to just cruise. The Z4MC is already seeming like a little guy with an attitude. We'll see how it turns out. I sold my E39M5 because it was just too rough for me. I am hoping that is not the case with the Z4MC because if that's the case... I will need to surrender my man card and go buy a Sienna.
2003 Z4 2.5i
2013 FR-S 1990 911 C2 1983 Wife |
04-13-2014, 11:53 PM | #15 | |
639
Rep 3,124
Put your big-boy pants on! Because Racecar!
It's a bit harsh to drive, for sure; I love it though. Adds to the fun. I drive 20-25k miles a year, and the challenge of hitting a perfect blip-shift is the only thing that keeps me sane during my 1.5 hour each way drive to work and back. The car's daring you to drive it smoothy. Embrace the challenge. Quote:
Coming from 25 years driving MK1 MR2s, the torque of the engine makes a lot of difference. In a car with low torque, if you don't rev match exactly, the momentum of the car will change the engine speed to match, without much jerking. In the ///M, if you don't get the rev match right, the engine wins, and you get a nice smack telling you to try again and get it right next time. P.S. I found that a cheap adjustable clutch stop helps a bit, too.
04-14-2014, 10:29 AM | #16 | |
Rep 1,771
Drives: 2007 Z4M Coupe
04-16-2014, 11:03 PM | #17 |
instagram 997turbotom
296
Rep 7,381
if you're not noticing a big power difference compared to the 3.0, you're not revving it hard enough
a short shift KNOB really improved shifting sloppyness for me. The stock knob is too flexible
04-16-2014, 11:15 PM | #18 |
1827
Rep 5,337
I went from an '03 3.0i with SMG (bought new) to an '06 MZ4 Coupe (also bought new). The '03 3.0i was no slouch. Had it on multiple So Cal tracks and it would chase down cars with a few hundred more HP with ease.
But the MZ4 Coupe is on another stratosphere IMO.
04-17-2014, 03:31 PM | #19 |
Rep 429
I made this change a few weeks ago and was genuinely surprised at how much it improved shifting. I've done the clutch stop and trans mounts and neither made as big of a difference as the shifter. I should have done that years ago
04-17-2014, 04:56 PM | #20 |
Wagon life
39
Rep 991
I switched to an OEM BMW Performance shift knob (the one with alcantara) and combined with the RE tranny mounts, it shifts perfectly. Still little clunky from 1st to 2nd when cold, but otherwise quite minty.
Tags |
comparison, roadster, z4m |
