12-10-2013, 04:42 AM | #1 |
Track Addict
110
Rep 813
Drives: 2010 BMW M3 E92 | 2008 Z4M E86
Easy Bluetooth Code Access Shortcut
Hi
So instead of taking apart the whole trunk, which I was planning on doing, I discovered a shortcut and pulling my hair trying to remove a clip. First some lighting can help. I was going to remove everything here like what other members had said. This guy was a pita… But then I noticed this when I tugged on this unintentionally. So I kept pulling. Module on very left side. Then I hit a dead spot… The code is facing towards the front of the car… being lazy I decided to use my iPhone 5s and used the camera record function and recorded this Code starts with the letters PK and is on the very left side of the module. My code is 0090 Hope this helps! Oh! and before I forget… I have a M coupe, I guess roadsters will be different
BMW ///M3 Coupe
Completed November 16, 2009 Received December 29,2009 |
12-10-2013, 08:26 AM | #2 |
#dubspec
6347
Rep 5,201
Awesome. Thanks
12-10-2013, 02:50 PM | #3 |
Rep 579
When I bought my car I found out something cool/creepy!
My bluetooth code is 8408 and I am born in August 1984. Pretty cool The car and I are meant to be ))
My cars: http://WWW.GARAGET.ORG/PHILLY
12-24-2013, 12:08 AM | #5 |
636
Rep 3,124
You have to tell your phone to search for new devices.
When it sees BMWxxxxxx tell it to connect. Your phone will then ask you for the 4 digit code.
12-24-2013, 12:09 AM | #6 | |
Track Addict
110
Rep 813
BMW ///M3 Coupe
01-11-2014, 10:11 PM | #8 |
Rep 1,034
There a few different variations and versions of the Bluetooth setup in the Z4. It wouldn't surprise me if something that works on one car doesn't work on another.
But looking on the Assist module in the trunk is a sure fire way to get the code.
