11-30-2013, 01:48 PM | #1 |
Rep 12,570
GoPro 3 1080p + Harry Lap Timer
Up to now I used to record my videos with my iPhone. This allowed me to overlay acquisitions data, edit and upload the film all directly from my phone which was very convenient. However I picked up a GoPro 3 not too long ago so tried synchronizing the external video and acquisition data and I'm pretty happy with the result. There's obviously few extra steps involved but I think it's worth it.
The only issue which I haven't figured out so far is there is a time delay between what you see on the lower left corner of the video vs. the timer on my phone in the car. The developer says it it has to do with the fact the video catches the "real time" view of the driver - which is always behind reality by approximately 1.5 seconds. I think I can add a 1.5 sec delay in the sensors and the next video should be fully in sync. Here's the vid, I'll try 60fps next time: Same event/track last year, but recorded with iPhone in 720p (front facing camera): Last edited by 3002 tii; 12-02-2013 at 10:03 PM.. |
11-30-2013, 04:41 PM | #3 | |
Rep 12,570
The Recaro or any bucket seat for that matter is a huge upgrade for performance driving. They keep me in place and I can focus on driving, not staying put. I'm currently shopping around this winter for 4 point cages so hopefully I can run a 6 point harness next spring. |
11-30-2013, 09:17 PM | #4 | |
Rep 844
12-02-2013, 08:58 PM | #5 |
Rep 4,531
I missed this thread.
Awesome video overlay. I'm very jelly. What software did you use to overlay the data? I need to do some research and see if trackmaster can do comparable data for Android. BTW you using medium angle? |
12-02-2013, 09:55 PM | #6 |
Rep 12,570
Don't recall if it was medium or narrow but definitely not wide. I use HLT on the iPhone
12-03-2013, 06:16 AM | #7 |
Rep 4,531
12-03-2013, 08:09 AM | #8 | |
Rep 12,570
If the external camera you used is a non-GoPro, the overlay process is a little tedious as you need to figure out the exact time the lap and video line up. If you use a GoPro that has wifi functionality, then HLT will speak to the GoPro real time and save the file name and time associated with the video clip to each lap so later when you transfer the video to your phone, the information is already 'sycned' and overlaying is easy as pressing the overlay button. The only video editing I really had to do was to put all my laps into a single video as HLT doesn't allow you to overlay an entire session, rather lap by lap. For that I transferred each video lap back to my computer and used Apple's iMovie. In the past I used Windows Moviemaker but that was a painfully long process as it has to convert the raw video into a WMM compatible file first, and then resave as mp4. With iMovie, you can edit the file directly. Sorry if this wasn't clear, I'm not the most technical when it comes to video editing but check out the links on the bottom of this page: http://www.gps-laptimer.de/Home.html http://www.gps-laptimer.com/LapTimer...%20Chapter.pdf |
12-03-2013, 08:15 AM | #9 | |
Rep 4,531
I thought you were taking raw data, obtained by HLT and merging them together manually via RaceRender, or a similar product. Did't know HLT has evolved that much to where it can talk to GoPro that easily |
12-03-2013, 09:12 AM | #10 |
Rep 12,570
Also even if you had an older gopro or regular non-wifi camera, the overlaying would still be done via HLT, you just have to specify the exact frame/time. Basically saying everything is done on HLT, but having a GoPro 3 or recording with iPhone/iTouch will make your life easier. You can even do PiP with multiple cameras work HLT.
12-03-2013, 06:49 PM | #11 | |
Rep 704
Drives: '08 MC
Yea as always those videos are awesome. Takes me right back to HPDE at NJMP except you are a far better driver. Now just need to try Thunderbolt.
12-03-2013, 08:33 PM | #12 | |
Rep 4,531
You should use an external mic |
12-04-2013, 12:28 AM | #13 |
Rep 12,570
HLT for droid?
