      07-13-2013, 03:03 PM   #1
schwank
Drives: 06 z4 m coupe
another intermitant starting issue
Hi guys,
My 06 z4MC has started not starting... it seems like it might be heat related, but I am not sure. Basically it either starts up no problem, or I turn the key and it "pops" under the hood, its like an electronic snap, but the starter doesnt move. To me it sounds like a bad starter or solenoid since the signal is getting under the hood. If I turn the key without the clutch down, it does nothing, with the clutch engaged it "pops" under the hood.
Any thoughts?
thanks!
K&W v3, APR splitter, magnaflow axle back35% tint, stubby antenna, Jet black, and interlagos blue stock wheels, clutch delay delete, illuminated ZHP shift knob, Leather Z m shift boot, and arm rest.
      07-13-2013, 03:28 PM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Check the wiring to make sure everything is making good contact.
If that looks OK, sounds like typical solenoid failure.
Comes as one piece starter + solenoid.
      07-13-2013, 05:14 PM   #3
yousefnjr
salty cowboys fan
yousefnjr's Avatar
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
I've had this happen twice on my Z's, first was a bad starter and the second was a bad ignition switch. GL
      07-15-2013, 07:39 PM   #4
wonton180
wonton180's Avatar
Drives: 07 Z4MC
do you have a clutch stop? this burned me last summer....
basically, it mimics the issue you are having. car will start fine in a cool spot or garage, and once sitting in the heat of the day, the rubber expands to the point where your foot travel is not enough to satisfy the clutch switch. The starter won't turn.
      07-17-2013, 08:22 AM   #5
schwank
thanks for the replies guys!
It doesnt do anything If I dont push the clutch in. no click no pop, no nothing. Ill see if I can get it to act up again, and look at that clutch stop though (I dont have an after market one).
      07-17-2013, 02:08 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
if you dont have an after market one that is taller, then that wont be the issue.
sounds more like wiring (corrosion, high resistive contact) or starter/solonoid issue to me
      07-17-2013, 02:56 PM   #7
seank
enthusiast
seank's Avatar
48
whs
      07-17-2013, 05:39 PM   #8
psygnosis
psygnosis's Avatar
23
Drives: '04 Z4 3.0i Sport
It doesn't sound like it's the problem, but it couldn't hurt to try the other key.
      08-05-2013, 07:35 AM   #9
schwank
I just replaced the starter with a little help from this thread. So far that seems to have been the problem. Thanks for all the suggestions!
http://www.zpost.com/forums/showthread.php?t=777861
