      05-11-2013, 08:52 PM   #1
3002 tii
3002 tii's Avatar
2961
Center Console Light Switch Tab
My center console light would always stay on. Upto now I assumed a piece of plastic had snapped off the bottom of the door flap. I eventually just disconnected the light but after randomly browsing the forums, I found this picture.
There is a metal tab that gets pushed down and makes contact with the switch (circled in red). I DON'T have that tab, duh!
Question is, is that metal tab part of that cheap plastic cover (*fingers crossed*) or is it actually part of the switch mechanism itself that lies underneath that plastic cover???
Follow for latest mods
      05-12-2013, 12:38 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
I just checked mine and it looks like it's part of the switch.
Looks like a standard "micro-switch", which come as a basic switch with lots of optional actuators pre-assembled from the factory. Oddly, I haven't found it on RealOEM yet.
There's also an easily broken long plastic pin sticking out of the bottom of the door to strike it.
Shmeesh, that cheap plastic cover is a PITA.
Oh, here it is. Glad to be of assistance.
I also just checked to see if it's magnetic. No joy. So if it's gone into the nether regions of your tunnel, you won't be able to fish it out with a magnet on a stick.
      05-12-2013, 05:01 AM   #3
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
this seems to be a weak spot of engineering from BMW. First, stuff easily slides off from the shelves, second they fall into the hole if you dont have that cover in place. if you do have that cover, the object probably helps in ripping off the tab from the door that hits the switch. In my car, I didn't have the cover at the bottom and the tab holding the switch in place got bent 90ยบ to the side and the metal part of the switch got ripped off. I bought a replacement cover and switch, but I dont think I can reattach the switch due to the damage on its mount. At least with the cover in place I wont be losing stuff down that hole anymore.
      05-12-2013, 10:20 AM   #4
3002 tii
3002 tii's Avatar
2961
Hmm, so it seems I'm missing both the plastic tab on the bottom of the door/flap as well as the metal piece off the switch lol.
      05-21-2013, 06:56 PM   #5
3002 tii
3002 tii's Avatar
2961
This is hilarious, so I ordered a new switch, installed everything only to realize the bulb died out. In trying to pull the bulb housing out, I cracked one of the tabs so I now need to order the lamp replacement... yes the irony
Looking at realoem however, I couldn't find the center console lamp, anyone have a p/n for me? It didn't look like parts 1 nor 8 in the picture below.
      05-26-2013, 02:34 PM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
I can't find that socket, either. Just like I can't find the sockets for the front corner marker lights that go into the headlight assembly. I broke some pieces off one of those while playing with LEDs. Easy to do. They get brittle from the heat of the bulbs.
      05-26-2013, 05:58 PM   #7
jeebus87
Drives: '11 atacama yellow Z4 35i
I actually had the same exact problem on mine - switch worked fine to turn the light off, but the console door tab had broken off and the light would stay on.
Rather than spending $70 on a new console door, I took a small screw, drilled a tiny hole into the bottom of the console door where the tab should be (so that the screw head sticks out far enough to contact the switch when closed) and it works great. Call it a redneck hack, but it was free and took about 5 minutes of my time.
      09-26-2013, 08:13 AM   #8
ncognito01
Drives: 2007 Z4 M Coupe
Jeebus - I like the way you think, would you do me a favor and post a pic. of your creation? I would like to re-create it since I have the same problem. Thanks much!
      09-26-2013, 10:32 AM   #9
Vanne
Vanne's Avatar
United Arab Emirates
1765
Drives: 2007 Z4MC
And just now I find out what that thing is actually used for... Of all things....
A pen holder...
Powered by
      09-26-2013, 06:23 PM   #10
jeebus87
Here's my ghetto hack.
      05-15-2024, 12:26 AM   #11
Robert McCutcheon
Drives: 2006 bmw z4 + 2013 bmw f30
center console light switch
Thanks for the Ideal - i am ashamed that I did not think of that - Thanks
      03-27-2026, 02:51 PM   #12
CharmingCurmudgeon
Drives: NOYB
I like the screw idea, but since I have a 3D printer, I made and glued this on to the ridge at the bottom.
Tried to attach the .stl in case someone needs it,but am not able to attach the .stl
It slips over the ridge on the console door and recreates the missing tab that actuates the switch. A small drop of superglue placed in the groove of the printed piece will permanently bond it to the ridge.
