03-20-2013, 06:25 PM | #1 |
Rep 862
Need help, or.. Why does BMW make it impossible to remove anything?
Ok, so I just took of my front bumper to adjust my recently painted front reflectors.
In doing so, the brittle plastic that holds the bumpers up near the headlights broke. I had the same problem with the damn cheap BMW plastic when I did my side skirts. Anyways, they're these: http://www.ecstuning.com/Search/51117165179/ES74722/ or #17 here: http://www.realoem.com/bmw/showparts...60&hg=51&fg=15 I have no idea how to remove them other than 1. destroying my paint with a tool to saw them off 2. removing the entire front of the car 3. removing the rest of my flesh on my hands and arms. CAN ANYONE HELP ME TO REMOVE THESE BASTARD PIECES BMW PURPOSELY MADE IMPOSSIBLE TO REMOVE??? |
03-20-2013, 07:03 PM | #2 |
Rep 415
Drives: 2005 z4 3.0
I hear you, I've had several, let's just call them "issues" with similar clips in the past. I finally worked out that most of them work on the plastic spring principle and that they require reverse prying off. By that I mean that you normally need to insert a tool into the necessary slot to release tension on an otherwise engaged spring loaded tab. Now I've not removed these particular SOBs but from the picture of ECS website it looks like the 3 bottom clips are released from the other side of the base plate. HTH
2005 Z4 3.0 steptronic | TiSilver on Black | sport & premium package | 108s | Msport seats | wind deflector OMP strut bar | blacked out emblems | de-french-fried | sound gen | DIY aux input | custom speedo logos | stubby antenna | polished exhaust tips |
03-20-2013, 07:32 PM | #3 |
Rep 862
Yes, exactly.
It would be SO EASY to remove...IF BMW PUT THE RELEASE ON THE EASILY ACCESSIBLE, OTHER SIDE. God, sometimes I really, really hate BMW. It's almost like they're toying with me. They actually made the tabs go IN towards the body! Making it impossible for anyone to get to them. They also made them out of very, very stiff plastic. |
03-20-2013, 10:35 PM | #4 |
Rep 2,931
I recalled the removal instructions from BMW calls for "breaking" them, which is exactly what I did when I had them replaced. It's a total PITA...have you ever had to "gently" break something?
03-20-2013, 10:39 PM | #5 |
Rep 12,635
Garage List E86 Z4 M [10.00]
The reason they broke is because you probably put your hands on the brackets instead underneath to grab bumper, so you actually pulled the bracket out and broke them. I replaced both sides this past weekend and basically used a flat head to pry the pieces very carefully so as to not damage the paint. It was tedious, 5 mins per side of cracking piece by piece but eventually got it done.
03-20-2013, 10:45 PM | #6 |
Not a New Member
94
Rep 925
i've taken the front cover off multiple times and not had this issue... weird...
i guess we should feel lucky they're only plastic and bolted in, rather than carbon fiber and glued in. anyone here brave enough to try removing the c-pillar wing on the i8 when it comes out? not me, thanks... i'll just watch from here.
03-20-2013, 10:59 PM | #7 | |
instagram 997turbotom
296
Rep 7,381
03-20-2013, 11:02 PM | #8 |
Rep 2,931
03-21-2013, 07:01 PM | #9 |
Rep 862
Ok, I think I found a pretty good tool that works.
Went to Harbor Freight to pick up this: http://www.harborfreight.com/7-piece...set-93958.html Used the smaller 90 degree pick to put into the hole from underneath and the outside. It barely fits. You can then twist it enough to break the tabs through the hole on the inside. |
03-22-2013, 07:48 AM | #10 |
Hug the road... Carpe Asphalt
106
Rep 722
2007 BMW ///M Coupe
03-22-2013, 08:51 AM | #11 |
Bimmer Noob
30
Rep 568
have ordered 5 of those over the course of two years. hate that piece!
its a crap shoot for me, sometimes the bumper comes right off, sometimes I am ordering a new part... wonder how many tischer ships, they always have them in stock...
08 Z4MC /// DKF Exhaust, Stoptech 6/4 BBK, TCK Coilovers, Strong-Strut, Apex EC-7's, APR Splitter/Wing, AFE Intake, Underdrive pulleys, AS SSK, Jaffster, UUC Tranny Mounts, Matte Grill, RPI Scoop, CF Badges |
