09-17-2012, 07:28 PM | #1 |
Rep 1,224
Quick Drain Oil Valve
http://www.quickoildrainvalve.com/ and http://www.stahlbus.com/info/en/prod...l-drain-valves
Anyone have experience with one or the other of these?
09-17-2012, 07:47 PM | #2 |
Rep 178
I've had these on my last 5 cars. They are built with quality and will not open unless you want it to. I don't know enough about the Z4 yet to know how it would fit on our cars though. Clearance can be an issue depending on the vehicle. But I've had these on all sorts of cars and found them to be indispensable for those of you who like to change your own oil, or for those who don't trust grease monkeys to apply proper torque to your oil drain pan.
-Edit - I just looked at your second link. Looks interesting, but my post is in reference only to the fumoto oil drain valve. |
09-17-2012, 10:03 PM | #3 |
Rep 932
Fumoto are not for bottom drain cars. It is a very tight fit and I wouldn't take a chance it might damage oil pan or the threads. i have it on my wife's suby.
09-18-2012, 09:08 AM | #4 |
Rep 1,224
Do you think the Stahlbus would be any better clearance wise?
09-18-2012, 01:09 PM | #5 |
Rep 932
I have no experience with Stahlbus. It looks like this valve was desgined for bottom drain. There aren't much details on the actual valve size. Our cars don't have much clearance IIRC.
09-18-2012, 01:46 PM | #6 |
Rep 1,224
No arguement on the limited clearance. Let's see if Stahlbus will respond to an email.
09-18-2012, 02:48 PM | #7 |
Rep 924
What's wrong with the hex plug?
After an unsuccessful experience with valve mechanisms (Speed Bleeders), I find the "old-fashioned" way of twisting stuff with tools really isn't such a big deal after all. As for grease monkeys, I'd be skeptical they'd know how to operate it and try to take it off anyway.
09-18-2012, 03:31 PM | #8 | |
Rep 178
The guy in the pit obviously didn't get the memo and didn't think twice to remove the valve when it must have been blatantly obvious it was NOT a standard bolt. Some people just don't have common sense. |
09-18-2012, 03:53 PM | #9 | |
Rep 1,224
09-18-2012, 03:58 PM | #10 |
Rep 1,224
Just received this back from my Stahlbus inquiry:
"The cap is about 3mm under your flap from the under shield. If you want to measure by yourself the valve sticks 22mm out of your oil pan, the original only about 4mm."
09-18-2012, 05:40 PM | #11 |
Rep 932
I'll pass on this. 3mm is not much tolerance given how low our cars sit already.
