05-14-2012, 10:57 PM | #1 |
Rep 2,460
Question on blown front left Bilstein PSS10.
okay, so my front left Pss10 is shock I have major clunking noises coming from the strut. I wondering if anyone has gone through anything like this and what you all suggest I go about doing.
thanks. Oh btw, I absolutely love the PSS10 setup! Last edited by Z4-VILLA; 06-20-2012 at 02:29 PM.. |
05-15-2012, 05:35 AM | #2 | |
Rep 701
Wouldn't it seem obvious to contact TMS or Bilstein
05-15-2012, 07:44 AM | #3 |
Rep 2,460
Wow good memory!
My question was more directed towards a course of action rather than spiteful retort :-) I will be contacting TMS today but before I do so I will back track and make double sure that the sounds Im hearing are not caused by a bad mount rather than a whole tube. I did some searching and found that the worn mounts can sometimes make similar sounds that blown shocks do. Hopefully its just the mount |
05-15-2012, 10:04 AM | #4 |
Rep 912
Is it possible that a PSS10 with a lifetime warranty crumbles down in front of some potholes and such?
I highly doubt that, I think there's some other variable than the PSS100 going wrong in this equation |
05-15-2012, 10:45 PM | #5 |
Rep 108
Contact Bilstein directly Or look for a local suspension tuner that can rebuild them.
Bilstein, Koni etc all offer rebuild services. IMHO it'd be a good time to take them all four to a knowledgeable race shop, have the dyno'd & rebuilt to your tastes. |
05-15-2012, 11:21 PM | #6 |
Rep 701
If I was a gambling man I would bet that the noise and vibrations you are describing are from something that has come loose and not a blown shock.
You would want to be sure it was the shock before you send it back as a warranty claim. Some companies charge an inspection/testing fee if there is no fault found and rightly so. From what I have seen the Bilstein PSS10 package is excellent quality and value for money.
05-18-2012, 03:26 AM | #7 |
Rep 2,460
Well I have pics to confirm the busted pss10 strut.... FML. I hope everyone see this and learns from my mistake. Pss10's and the city don't mix.
You can see where the fluid sprayed all over the wheel well. I really hoped it was a strut Mount. Guess not. What to do, what to do......hmm Last edited by Z4-VILLA; 06-20-2012 at 02:28 PM.. |
05-22-2012, 12:50 AM | #9 |
Rep 5,329
Hmm interested to see how bilstein deal with this
05-22-2012, 12:56 PM | #10 |
Rep 2,460
I confirmed that my front left shock is done but just for good measure I am removing the entire bilstein suspension and sending it off so that way I can run on stock struts wwhile that thing gets returned to factory spec
05-22-2012, 03:40 PM | #11 |
Rep 12,571
So 1 shock will be serviced for free, but what about the other 3? How much are they charging for that?
05-24-2012, 12:52 AM | #12 |
Rep 2,460
I believe if you go to Bilstein's website and look under service or warranty there should be a work sheet. Pricing is not bad from I vaguely remember.
06-16-2012, 07:31 AM | #13 |
Rep 2,460
so btw in case anyone wanted to know...both fronts were gone. first the left went then 2 weeks later the right eventually failed. upon removal both were separated from each other. It was a big mess. They are currently at Bilstein in Cali awaiting a verdict.
06-17-2012, 07:09 AM | #14 |
Rep 12,571
You bought used right? Wonder if previous owner d!cked you over...
06-20-2012, 02:45 PM | #21 |
Rep 2,460
There are parts inside like the piston and the snap rings that are rated at 10,000 pounds and I managed to blow them both out. They think I basically drove the car over a cliff.
06-20-2012, 02:48 PM | #22 |
instagram 997turbotom
286
Rep 7,377
Do you remember hitting any big potholes, soon after which the noises started? I think you previously said you live in NYC
