Thread Tools |
| 02-26-2012, 09:48 PM | #1 |
Rep 2,120
Home alignment, what tools do you have?
I don't know how many DIY'ers we have here like me,
Figured it might as well be worth a shot to see what people are using for this. Making sure your not going to ruin your tires, getting the car setup for track then return to street, I know there are plenty of tools out there but I want to hear from people that have used them and own them ![]() Post what ya got ![]()
![]() Imola Red Roadster |
| 02-26-2012, 10:13 PM | #2 |
enthusiast
55
Rep 1,695
Longacre camber tool, 2 measuring tapes, and 2 metal strips that are 30 inches long (home depot). I also would like to say that I would not recommend doing alignments on the fly.
These tools are good for minor tweaks, as long as it is not WAY out of tune. |
| 02-29-2012, 12:06 AM | #3 |
Rep 108
I somewhat ashamed to say i made a camber gauge for less than $20. Built a metal T using square tube & Angle iron. Welded it up as level as possible. Added three feet, one at each end of the T. Feet are adjustable to accommodate for minor re-leveling. Added a bubble site on horizontal piece to find an accurate level. Finally using a harbor freight digital angle gauge can get accurate readings with 0.1degree.
Also made a toe plate similar to Sean's idea. Key here is to pump tires UP to 40psi ish. Roll car back & forth a little to settle out tires. Using two identical tape measures clamp them to one plate, measure at front & rear of opposite tire. Also as Sean said this is a quick way to gauge minor tweaks, you'd be best advised to get a proper alignment done after major work. |
| 02-29-2012, 06:28 AM | #4 |
Rep 11,671
Do all my own.
That reminds me, I need to update my alignment thread.
nada
| 02-29-2012, 09:06 AM | #5 |
Rep 170
For Basic Set up:
- Smart Strings - Smart Camber - Balast to simulate driver weight For quick alignment changes at the track - Longacre - Toe Plates - Smart Camber If the surface you are doing the alignment on is level and flat this is all you should need. My garage unfortunately isn't, so ended get scales, leveling pads,... |
| 02-29-2012, 01:16 PM | #6 |
Rep 11,671
I have these 18" high stands that I use to elevate & level the car. (set up with a laser level)
I lower the car onto greased slide plates which lets the suspension squat into normal position. ![]() I use a Longacre digital caster / camber gauge kit that reads to .1º (1/10º) camber and caster as high as needed. ![]() I use string lines to set up toe
nada
| 02-29-2012, 03:42 PM | #8 |
Rep 1,548
inTgr8r, how much did that lift cost you?
| 02-29-2012, 04:06 PM | #10 | |
Rep 170
What brand are they? How do you level them? |
| 02-29-2012, 05:05 PM | #11 |
Rep 11,671
I made them.
The floor level is pretty good so all I do is stack some SS plates & use a laser to check level. (there's a 1" lip on the top of the stands)
nada
| 02-29-2012, 05:36 PM | #12 |
M = Midlife Crisis
70
Rep 2,006
Need to book my alignment
2006 Z4MC - #LL93158
| 07-09-2013, 07:27 PM | #13 |
Rep 11,671
update to an old thread.....
I took a couple of pics of my last alignment session. the stands make doing the adjustments a breeze. ![]() ![]() ![]()
nada
| 07-09-2013, 07:54 PM | #14 |
M = Midlife Crisis
70
Rep 2,006
| 07-09-2013, 08:25 PM | #15 |
Rep 1,548
How do you like those ZIIs?
| 07-09-2013, 09:36 PM | #16 |
Rep 11,671
Fantastic!!
They are a huge upgrade over the NT05s that I had before. They warm up quickly, have great turn in and are very consistent for the entire session.
nada
| Bookmarks |
