06-06-2011, 08:12 AM | #1 |
Rep 956
Z4 Spare Wheel/Tire
For anyone considering a spare tire in the trunk instead of other options out there, here is some info. This is the setup I went with.
135/80/R17: 36110306541 Steel Wheel: 36116750007 Wheel Valve-Stem: 36121116326 I purchased all the parts from Tischer and took it all over to the local Firestone shop and they assembled all the parts for $8. I also have a 15" Craftsman breaker bar with a 17mm socket, 1.5 ton Torin jack from Walmart and a bag from Harbor Freight. Cost for all of that was roughly $50. Here are some photos… Last edited by ANUSTART; 06-06-2011 at 08:28 AM.. |
06-06-2011, 09:15 AM | #2 |
Rep 421
06-06-2011, 01:26 PM | #4 | |
Rep 421
http://www.bimmerfest.com/forums/sho...ght=spare+tire |
06-06-2011, 02:13 PM | #5 |
Rep 956
Yeah, I had that one on order originally through Tischer. Waited about 3 weeks before hearing back that it was not available any longer. Not sure if that has changed, but this was the only one they had that was remotely close. I also checked locally and that size wasn't available through local Continental distributors. But, if you can find the 125, it is the perfect match.
135 will work, just can't run it on the rear. I did some testing to see how the car handled and felt with it on and I honestly didn't notice any difference. That was at low, back road speeds though. |
06-06-2011, 03:41 PM | #7 |
Rep 956
I'll have to verify when I get home. I looked it up on getbmwparts.com and it showed up the same as I remembered it from several months ago when I ordered it. At the time, it was showing up on their website, but it was not available to them. I confirmed with Jason at the time and he couldn't find no PN for that size. And the PN I had was for a deleted product.
06-06-2011, 04:23 PM | #8 | |
Rep 421
Put in 36 12 0 418 839: http://www.trademotion.com/partlocat...?siteid=214760 LeatherZ.com sells the kit but he might sell a tire if someone wants it. |
06-06-2011, 05:42 PM | #10 |
Rep 661
Garage List 2022 M5CS [0.00]
Ron, I had a spare tire for my '05 3.0 and just upgraded to a '06 M Roadster. As I understand it, the spare will not work, correct? Is there a spare that can be purchased that will work with the M (both front and rear if need be)?
Chris
06-06-2011, 06:02 PM | #11 | |
Rep 421
The one in number 1 is what I have 135/80/17 in my Z4M. The one in number 1 should be a 125/80/17. |
06-06-2011, 09:41 PM | #12 |
Rep 661
I have the 125 80 17....it's a Continental tire.
Chris
06-07-2011, 02:04 AM | #13 |
Rep 421
06-07-2011, 10:11 AM | #15 | |
Rep 661
Thanks! Chris
06-07-2011, 11:04 AM | #16 | |
Rep 421
I'll check when I have the wheels off. Maybe jmillet will explain which wheel or both. |
06-07-2011, 09:25 PM | #17 | |
Rep 666
It fits very snugly in the rear compartment.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
07-25-2011, 02:56 PM | #18 | |
Rep 3,314
Drives: 2002 M5;2007 M Coupe;2020 M2C
08-01-2011, 12:26 PM | #19 |
Rep 12,635
Garage List E86 Z4 M [10.00]
i used the spare off a 5-series for a while, which also fits but didn't like the loss of trunk space. since then i purchase a mobility kit by continental (sold through tire rack). fingers crossed..
08-02-2011, 01:44 PM | #20 | |
Rep 666
Second time with 15mm spacer and longer lug bolts it clears the front caliper and fits just fine. Haven't had to use it in an emergency situation
Jim Millet
08-02-2011, 02:35 PM | #21 |
Rep 3,314
Thanks for the response. I will go this route.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
