05-15-2011, 02:01 PM | #1 |
6 of Diamonds (ret)
82
Rep 566
Single touch Power Convertible Top Control
Installed the Gap-Tech Remote Control Hood Plus (RCH+) today.
Works as advertised. Makes the whole process of the power top much simpler. In a nutshell, you no longer have to hold the dash buttons while you lower/raise the top, it gives your remote down and "up" capability, and you dont have to continuously hold the remote buttons to make it function. I had heard there was another product that does this but there were issues. This one broke the surface on the Z4Forum - Our UK compatriots appeared to line up and buy it in mass. They called it the OTH+ there. No complaints I noticed. Should have come like this from BMW - but I suppose that when you live in the land of the leisure suit litigation ambulance chasing pond scum, whoops, I mean defenders of the defenseless downtrodden masses.........but I digress, the key sequence using the key remote takes just a minute to get used to. Put about a one sec pause in between clicks. Down - is Unlock, Unlock, Unlock Up - is Unlock, Unlock, Lock The Dash controls: Push for about a half sec and release. www.gap-tech.co.uk He will ship to the US - took about 14 days for it to get here and about 30-45 min to install.
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
05-16-2011, 08:13 AM | #5 |
Rep 782
05-16-2011, 08:48 AM | #6 |
G-Powered
Rep 14
I just ordered one... hope it's not much trouble installing.
Z4 3.0i S, G-Power SKIII Supercharger [364 RWHP], Eisenmann SuperSport Exhaust system, 19" Breyton CS, Remote Roof Control...
05-17-2011, 05:18 AM | #7 |
Rep 10
Install is very easy, and the unit comes with good instructions. It comes with scotch locks to splice into a few wires located just under the ashtray trim. However I used a soldering iron and solder to make the connection.
It's 5 wires in total, takes about 1/2 hour start to finish |
10-18-2015, 11:54 AM | #10 |
Daily driver/Weekend mechanic
Rep 48
Drives: '06 Z4 3.0i Roadster
I purchased the SmartTop module. It's a very simple install. Pull the speaker panel behind the driver's seat and the second access panel closer to the door, unplug the oem top module to insert the Smart Top module inline..that's it. Yes, the top goes up and down much more often.
All remote SmartTop features are operated using the FOB's open button. Each feature may be turned on or off individually and customized. Mine is set like this: press twice to roll down windows, two times lowers the windows & top, four times, top down, windows up. Pressing this number of times again will do the reverse action. I set in-cabin one touch operations to be allowed at a speed up to 20 kmh. Overall, I'm super satisfied. But I miss my oem settings where the windows stay at half mast, and would consider a swap to a module that retains that option. A word of caution; if you're not careful when unlocking the passenger door, you might unintendedly activate the top. Although this is not a danger, it can make you look daft on a rainy day. Last edited by Forbes; 10-18-2015 at 01:11 PM.. Reason: Grammar |
10-18-2015, 01:02 PM | #11 |
Rep 48
SmartTop:
www.mods4cars.com Installation manual: http://www.mods4cars.com/sms/shop/in...action=manuals |
03-01-2016, 05:58 AM | #12 |
Rep 2
Hi
Anyone have contact details for GapTech please Tried getting hold of them via the online support, but not sure if it is going through Looking at picking up a unit when i am in the Uk in a few weeks |
03-02-2016, 08:48 PM | #13 | |
///Multiple
2998
Rep 4,243
When my car is in the garage, the top and windows are always up. When I'm preparing to leave home and walk into the garage, I press the unlock button on the key fob three times and the windows and top go down. I can open the door and get into the car while the top is going down and the windows don't stop. I usually park the car with the top up and the windows down, so when I park the car I just push the interior top up button twice. If I want the windows up when parking I just push the interior top up button once. No need to hold the button until the top and windows are up. I can get out of the car during operation and it doesn't stop the windows or the top. If the top is already down you can press the top down button once and it will toggle the windows up or down. When I come back to the car, as I approach it I press the unlock button on the key fob three times and the top goes down while I get into the car. As I arrive home and start up the driveway I just hit the top up button once and the top and windows go up while I'm pulling into the garage. I think a lot of thought went into the design of this module and it just really works just the way you would want it to.
