XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
Register FAQ Calendar Today's Posts
      03-19-2011, 05:35 AM   #1
AusX1
Drives: X1 2.0D Sport
Spare wheel
Hi,
I haven't got my X1 yet, it'll be on the boat downunder with a few other X1M Sports by the sound of it.
Bit of a penny pinching idea for such a car, but I was thinking of setting up with a spare for longer trips (My nearest BMW dealer is 7 hours away).
Do any Australians know if Holden Commodore wheels fit the X1 Ok? Or would it maybe be better to buy a new cheap alloy wheel to suit.
I was thinking it'd be handy to have a spare rim and maybe fit it out with one of the runflats when they need replacing.
I like the idea of a spare to enable you to use non-runflats on a regular basis too.
Apart from that, carry tyre plugs I suppose as well as a 100L tub of water to find any holes to plug!
I can't imagine a loaded up car with a punctured runflat would go too too far without wasting the tyre completly.
BMW recommend certain km's possible on flat runflats. What happens to the tyre if you overdo it?
Anyone had experience with the BMW tyre goop for punctures? Most similar products available here cause corrosion of rims.
Regards
Damian
      03-20-2011, 10:59 AM   #2
BillQuarter
BillQuarter's Avatar
Scotland
11
Drives: 2 series 218i Grand Coupe
Originally Posted by AusX1 View Post
Hi,
Regards
Damian
Hi AusX1
No space allocated in the boot for spare wheel, and I think I am right in saying if you travel any distance on run flat tyres they have to be replaced which I think will be more expensive.
      03-20-2011, 01:10 PM   #3
tompak23d
tompak23d's Avatar
Drives: iX M60
In Sweden a car magazine did at test with a RFT. They drove 150 km without any problem at all, they could have gone longer but aborted the test efter 150 km.
      03-20-2011, 01:22 PM   #4
Gatekeeper
Gatekeeper's Avatar
France
11
Drives: BMW 320d Security
AusX1, I don't know where you intent on stowing away a spare wheel. The trunk is just not designed for it.
Runflat are a good idea given your surroundings. They hold tough.
My sister-in-law drove back and forth to work for a week, roughly 80 klics a day, before realizing that the weird shimy was due to BOTH rear tires being flat on her Mini!
"Let our manners distinguish us from our enemies, as much as the cause we are engaged in"
      03-20-2011, 08:38 PM   #5
AusX1
That sounds good with the distances possible.
      03-21-2011, 06:30 AM   #6
Gatekeeper
Gatekeeper's Avatar
France
11
In your predicament, it becomes a safety issue I would say.
      03-21-2011, 07:04 AM   #7
mario486
Mario
mario486's Avatar
Scotland
26
Drives: X1 XDrive 2.0d, Mini Cooper
I have now had two colleagues/friends who have had a flat with a RFT tyre fitted to a BMW. In both cases they drove around 100km on the flat easily but in both cases were told to replace the tyre.
Could be just a money making racket but surely running on a flat RFT will weaken the tyre wall fairly quickly.
To be honest I don't know enough about it. I will see if I can find out more.
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda
"Truly wonderful, the mind of a child is" - Master Yoda
"There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela
      03-21-2011, 07:17 AM   #8
Gatekeeper
Gatekeeper's Avatar
France
11
Sure, but my point is, in Aus1 case, it's a whole different ball game.
Contrary to our urban, semi-urban or even country roads, there is no service station for miles, and street lightning is not existent in the middle of the bush.
Trying to repair a flat on the side of the road might become a life or death situation (Passing traffic, thugs, vengeful kangeroos and other wild animals, meteorits, MadMax ... you name it!)
Being able to continue driving a car with a flat tire in these conditions make sense.
      03-21-2011, 07:24 AM   #9
mario486
Mario
mario486's Avatar
Scotland
26
Oh I totally agree, I think RFT's are a good thing although they don't seem to be catching on really. The most important thing for me is that you can actually drive with it flat to where you can get help. If the terrain is very bad there is nothing to say you cannot get a second flat and then with non-RFT tyres you are scr3wed.
Two other points to mention. How many older cars actually have a servicable spare? And those wee space savers some cars have give you the same performance and range as a flat RFT anyway.
      03-21-2011, 08:20 AM   #10
nathan35
Drives: X1 sDrive18d
One more thing you should keep in mind when carrying around a spare wheel: As there is no dedicated space in the boot/trunk for it, you will basically just have to put it there in the trunk (which btw. is probably going to take the full available space. The wheel is reaally heavy, and as there is no proper separation between the load compartment and the cabin, in case of frontal accident the wheel may fly into the cabin producing massive damage to the passangers. The same applies in case of rear accident, where the wheel may be pushed into the cabin, potentially breaking the rear seat backrests and whoever is sitting there.
I personally think the gain is not worth the trouble.
      03-21-2011, 08:28 AM   #11
Gatekeeper
Gatekeeper's Avatar
France
11
Makes sense. Go RFT !
      03-21-2011, 09:44 AM   #12
mario486
Mario
mario486's Avatar
Scotland
26
Good point. Although thats probably true for any heavy object in the back, eg a toolbox.......or my snow chains ....Oh cr4p!
      03-21-2011, 10:04 AM   #13
Gatekeeper
Gatekeeper's Avatar
France
11
Yep. My sister-in-law would qualify too.
      03-21-2011, 10:14 AM   #14
nathan35
Sure. For a smaller object you can always hope that it slides against the rear backrest rather than jump above it. For a spare wheel there is little hope
Anyway, my personal opinion is that this aspect of car safety has been completely overlooked so far by manufactureres and testing organisations, and I also think crash tests should be performed with heavy objects in the boot.
      03-21-2011, 10:31 AM   #15
mario486
Mario
mario486's Avatar
Scotland
26
There are some anchor points in the back of my X1. I have similar points in the back of my mini to which I have fitted a net to hold the loose objects. Not sure if there is a similar accessory for the X1 but would probably be a good idea to fit a similar one.
PS: Many, many years ago I was involved in an accident as a front passenger. I would have been fine except I got hit in the back of the head by a speaker that broke free of the rear parcel shelf. No jokes now
      03-21-2011, 09:41 PM   #16
AusX1
I hadn't thought of being sandwiched between a kangaroo through the windscreen and the spare wheel at my back!
Seriously though, it's a great point that any spare really needs to be bolted down or in a separate compartment. The Australian X1's come with the cargo net/barrier as standard, but unless it's kevlar reinforced or something I can't see it'd help much.
It's good to hear the confidence you all have in RFT. A lot of people just complain about not having a spare and how poor they ride/handle.
Might have to set up a roof box to put the spare in if I'm really heading into the middle of nowhere.
      03-22-2011, 03:42 AM   #17
Gatekeeper
Gatekeeper's Avatar
France
11
Oh, heading to the middle of nowhere is no problem. Coming back might !
      03-22-2011, 07:47 AM   #18
brettnosse
Drives: Mini
I live 600km from the nearest BMW dealer so in a similar situation. I have driven a runflat with no air as it turned out for 500km. At speeds I am scared to think about. I hit a massive hole in the road a few minutes later the warning flashed which is common on rough country roads, I reset it and when I got to Brisbane I noticed a bump in the tyre. Took it to get checked. Pulled it off and there was a 8 inch tear in the inner lining . So if the mini runflat tyres can do that. You will have no worries
      03-23-2011, 10:35 PM   #19
Filski
Drives: None
At one point in oz you could get a spare wheel holder on the rear door for the x5. I've also seen a photo of a mini that had fabricated a spare wheel carrier that was in a similar spot.
Not sure yet if I'll get the x1 or x3 but I'm considering adapting something to carry a spare wheel in the same spot based on a bike carrier later this year. Will let you know if it works out.
      03-24-2011, 02:10 PM   #20
manicm
Drives: X1 sDrive18i
Yeah, thought about RFTs, I think they ought to be OK, also another good point - a 17 inch rim might be a touch too heavy to change myself. Well I'll see how it goes. Picking my car up on Tue or Wed at my convenience
      03-24-2011, 06:00 PM   #21
AusX1
I have thought of that as a possibility, but from experience with 4WD's I'd be really cautious about adding weight to the rear door. Longterm I'd reckon the door alignment could be affected leading to hinge problems and rubbing on the door frame duco - stripping it and bareing the metal...rust? thedoor's probably not engineered for it and apart from the passive load, you could imagine the effective weight of the wheel every time you go even over a speed hump much less offroad.
I much prefer the idea of a wheel carrier that is linked to the rear bumper, but don't know if that's even possible with an x1 and if it is it means you'd need to swing it away before you open the door each time.
Even though BMW produced the carrier for the X5 it may not mean it's necessarily a good idea.
      03-24-2011, 08:08 PM   #22
Filski
Drives: None
I'm not sure what the deal was with the x5 carrier. Pretty sure the mini one attached to the bumper in the same way a bike carrier did. In any case the bike carrier forms the base of what I propose to do. It'll hinge out when you need to access the door and be fully removable for when just driving around the burbs. Getting it to look right is the challenge. I'm fairly confident this is the way to go for camping trips or heading out west.
xbimmers
