      01-06-2011, 11:48 AM   #1
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
Help, need new track pads
Any suggestion from other Z4M track rats?
I don't want to spend over $200 on each set. I also need rotors soon, probably another 3 track days. I couldn't seen to find anyone makes slotted rotors for our car.
Thank you in advance!
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      01-06-2011, 12:04 PM   #2
The HACK
The HACK's Avatar
1821
You have to pay to play. There are no such thing as "cheap" track pad.
I bought a set of DTC-60s from Bimmerworld about 6 months ago for $175 ea axel. It seems the prices have gone up AGAIN. I used a set of Cobalt XR-3s before this, while the Cobalt had more initial bite, the DTC-60 was more consistent throughout the range of pedal movement. A few friends of mine use PFC-06es and like them a lot too. Outside of that there's really nothing I can really recommend for track use.
I've also got a set of RacingBrake 2 piece replacement floating rotors up front as well. It's worked well for me the last 4 years I've owned the MZ4 Coupe. Looks like it'll easily last another 2 years of moderate to heavy tracking (8-12 days a year). The first 2 years saw anywhere between 18-22 days on track a year. They don't have a rear fitment because with stock pads, the pads will come in contact with the rear rotor's fasteners (not good) but if you use a slightly different pad fitment than what is intended for the M3 caliper it'll work. Side effect of the more efficient front brake cooling has also extended the life of the rear rotors, although I'll still go through 2 sets of rear rotors for every front set.
      01-07-2011, 02:49 PM   #3
runnerx
runnerx's Avatar
thanks Hack! Wouldn't those pads overkill for street tires? I probably still 10 trackdays away from r-comps. for now, I think any semi-hardcore pads will do. I am leaning towards another set of Ferodo DS2500 at this moment.
2009 BMW X5 4.8i
      01-07-2011, 03:07 PM   #4
The HACK
The HACK's Avatar
1821
I don't use these pads for the street. I swap pads out before each event (takes about 40-45 minutes).
