XBimmers.com | BMW X6 Forum X5 Forum
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      12-12-2010, 12:25 AM   #1
youngien
Drives: X6
Wheels Locks on BMW x6?
Dear Fellow X6 Owners.
I just bought a new set of BMW winter tire sets (Was using the Ferric Gray BMW OEM 215 wheels), when I tried to unscrew the wheel stud, now matter what I tried I could not do it. Does any of you know weather there is a wheel lock for our X6?
Thanks guys,
      12-12-2010, 12:53 AM   #2
audioquest
2nd to None!
audioquest's Avatar
Singapore
42
Drives: M8 GC, M5 30Jahre, X6 50i
Have you ever change your wheel before. I believe your wheel lugs been tighten with pneumatic Air Gun. There is no way you can unscrew that even with a longer handle wrench. You need to bring it the tire shop to get it undone by a pneumatic air gun. Just tell them not to over tighten the lugs. Only tighten it by hand or set it at 105 ft/lb. For E71 X6 14mm lug = 105 ft/lb by hand. A airgun bang it in at 300 ft/lbs and there is no way you can unscrew that by hand.
Hope the information help. Good luck.
[SIGPIC][/SIGPIC]
My Car Audio Install
http://www.mobileelectronics.com.au/...owtopic=554389
      12-13-2010, 09:57 AM   #3
dmlgc
dmlgc's Avatar
Drives: 2022 BMW X6MC - 335D
I had to purchase wheel locks for mine, most likely like audioquest says they have been over tighten.
      12-13-2010, 10:42 AM   #4
zerrantoss
Drives: 2011 X6
If yours came with wheel locks, the key would be in the trunk.
xbimmers
