11-01-2010, 06:37 PM | #1 |
Rep 973
urgent!!!!107s with 275 35 18?
one of my stock tires which are put on stock 17 rims is screaming for a replacement and since some time ago i bought a set of 107s, now i am looking for tires but dont know the biggest size i can go without compromising performance. any input? would 273 35 18 fit on the rear? biggest size on the fronts? thanks guys
i did my homework and searched but didnt find anything relevant
if you want perfection buy a mercedes, or marry an accountant
11-01-2010, 09:48 PM | #3 |
Rep 973
so, what do you think? 255 40 18 maybe?265 35 18? 255 35 18? i really dont know much about this
people claim to use 275s on z4m rear wheels which are 9" so i guess i can use 265s right? still, dont know much about this. thank you for your help
11-02-2010, 09:53 AM | #5 |
Rep 973
according to tire rack the oem tire size for the rears is 255 35 18 so i guess 265 35 18 should be ok, please id appreciate if someone can confirm this
11-02-2010, 01:23 PM | #6 |
Rep 12,635
Garage List E86 Z4 M [10.00]
i'd stick with 255 since it keeps ride height even with the fronts and it is the recommended width for a 8.5. 8.5 really isn't that wide so don't see why you'd want to go with wider tires. i know you even can run a 225 on a 8.5... 265 just seems like more weight than necessary too.
11-02-2010, 01:26 PM | #7 |
John 14:6
59
Rep 588
I just added a set of 265/35/18s to the rear and I like how it filled in the wheel well.
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
11-02-2010, 01:44 PM | #8 |
Rep 973
so it is doable then, how do you feel the ride? can you share some pics? thanks guys youve all been very kind taking the time to help a fellow member
edit: i want bigger tires because of the grip and the looks, also because where i live there are very nasty punchholes so haveng wider tires may help when you are facing bumps on a daily basis
11-08-2010, 10:32 AM | #9 |
Rep 973
ill go with 165s then. do you know if the rear will need spacers? i think oem 107 wheels look too tuck in the rear fender. 100 mm? 15 mm? thanks again
11-08-2010, 12:35 PM | #10 |
John 14:6
59
Rep 588
Either a 10mm or 15mm will help push it out to where it looks close to flush with the fender. I'm running a set of 197s with a 35 offset, with 265s. I'm very pleased with how it looks
11-08-2010, 01:58 PM | #11 |
Rep 973
wow, saw your car in a thread. very lovely, i think ill go with 15mm spacers. u should change your sig as i think the new look is way cooler. just my 0.2 cents
11-08-2010, 02:01 PM | #12 | |
John 14:6
59
Rep 588
Post some pics of your ride when you get the wheels and spacers installed!
06-26-2011, 11:58 PM | #14 |
Rep 973
well, went with the 265s suggested by misterawa. thanks bro, now Ill look for spacers and springs
