XBimmers.com | BMW X6 Forum X5 Forum
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Members Classifieds : For Sale / Wanted / Group Buys
      04-09-2010, 12:37 PM   #1
EAS
EAS's Avatar
548
Drives: VF620 M3
▀▄ eas | Video Source Module (VSM) for BMW X5/X6
This kit allows you to view camera/video inputs on your BMW's navigation screen. The unique picture in picture layout allows the user to view the map or iDrive screen while viewing a reverse camera feed or video source. When the car is put into reverse the VSM module automatically activates the reverse camera display; when the car is taken out of reverse the camera display is deactivated.
The optional camera fits into the BMW trunk by replacing one of the license plate lights for an OEM look and fitment. With an integrated LED license plate light, no functionality is lost after replacement. The camera is equipped with an ultra wide angle lens allowing you to see what is behind the car as much as possible. The VSM module allows you to overlay a parking distance apex grid on the reverse camera display.
Features
Audio/Video Source Selectable by OEM Steering Wheel Buttons (CANbus)
Picture in Picture (PIP) Function
Automatic Reverse Camera Activation
Parking Distance Apex Grid Overlay
1 Camera Input
3 Audio/Video Inputs
RGB Video Input for those using CARPC Displays
NTSC, PAL Auto Detection
Small footprint allows for easy storage behind dash
Models Supported
2008-2010 iDrive equipped e70 X5, including X5M
2008-2010 iDrive equipped e71 X6, including X6M
http://www.europeanautosource.com/pr...oducts_id=2926
http://www.europeanautosource.com/pr...oducts_id=2927
      04-09-2010, 12:38 PM   #2
EAS
EAS's Avatar
548
Drives: VF620 M3
Have an older model than listed above and still want the VSM? We didn't forget about you!
The Video Source Module (VSM) is a video input for integration for a rearview camera or aftermarket products (e.g. DVD player) with the factory navigation System.
Specifications:
- 1 Video Input
- 1 Camera Input
- Auto Video Switching
- PAL & NTSC Compatible
- Analog & Digital Compatible
- Plug & Play Connection
- Any aftermarket device attached to this interface will work on the move
Kit Contents
- Video Source Module
- Plug and Play harness
- Instructions
- Optional Bumblebee camera with forward/reverse image (end user selectable)
Reverse bumblebee Camera (optional)
Imported overseas from one of the best CCTV Security Surveillance equipment manufacturers in Taiwan, Misumi is well known for applying state-of-the-art CMOS Image Sensor Devices (Camera On A Chip) to the design and manufacturing of security surveillance video cameras.
These kind of cameras incorporate high technology used to minimize the size of the cameras and produce a crisp and clear picture quality. The small and indestructible design allows for mounting virtually anywhere on the vehicle without the need for drilling.
The "bumblebee" camera gets its name from the mounting bracket that can be mounted virtually anywhere from underneath the decklid next to your license plate or underneath the rear spoiler. This is perfect for newer BMWs that do not feature a keyhole, eliminating the need for drilling. The camera features a 150-degree maximum viewing angle and a 0.5 LUX rating for low light viewing, even in dark areas.
Features:
- Significantly decreasing power consumption; operates on 3-12V DC
- Lightweight
- High reliability at low cost
- RCA video input
- Simple installation
- Great for covert use in any place imaginable
Specifications:
Water Proof (IP67) Color CCD Camera
Wide Angle View for Reverse Back Up System
Signal System: NTSC/PAL
Pixels: NTSC-512x492, PAL-512x582
Image Sensor: 1/4" COLOR CCD
Lens: 1.9mm/F2.4
Lux Rating: 0.5 Lux
Viewing Angle: 150 Degrees
Dimensions: 19x18mm
Camera to main board box: 22cm
W/Video & Power mixed line (AF-U183)
Models Supported:
10/2002-2007 X5
2004-2009 X3
Warning:
It is illegal in all 50 states, and in most Canadian Providences, to have real time video (TV Broadcast, VHS, DVD, Video, etc.) in view of the driver. If you are going to use the VSM for anything other than interfacing a rearview camera system, the interlock wire must be properly connected to prevent the driver from viewing real time video while driving. Please drive safe and obey all laws while driving.
http://www.europeanautosource.com/pr...oducts_id=2422
xbimmers
