04-03-2010, 07:57 AM | #1 |
Rep 3,004
Wheel Lug Bolt Socket w/Protective Inner Coating and Wheel Locks Question....
Is there a lug bolt socket that has an inner soft coating to prevent scratching the lug bolts??
Recommendations for wheel locks?? I just purchased OZ Ultralelggeras in black and ordered Turner Motorsports black wheel lug bolts. Thanks Racerbruce |
04-03-2010, 11:49 AM | #3 | |
Rep 666
Grey Pneumatic Corp sells a high quality set SKU 1503TP for around $20. I have one of those too
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
04-03-2010, 07:38 PM | #4 | |
Rep 3,004
I'll google the sockets. Any wisdom re black wheel locks for our cars?? Regards Racerbruce |
04-03-2010, 07:44 PM | #5 |
Skull Squadron Leader
309
Rep 2,031
04-03-2010, 10:59 PM | #6 | |
Rep 3,004
The OZ rear fitment requires 20mm spacers....so the lub bolts need to be 20mm longer. I'll contact McGard and ask if there is a fitment for this app. Racerbruce |
04-04-2010, 01:51 AM | #7 |
309
Rep 2,031
Oi... in that case then you're probably going to need p/n 27013 or 27014
http://www.mcgard.com/Applications/A...4K1gwvBg%3d%3d But they're not black-faced |
04-04-2010, 08:53 AM | #8 | |
Rep 3,004
Just sent this to McGard: McGard Wheel Locks for 2007 BMW Z4M Roadster / REQUEST FOR INFORMATION From: bruce jarrard (racerbruce@msn.com) Sent: Sun 4/04/10 3:51 AM To: csinfo@mcgard.com Cc: jarrard bruce home (racerbruce@msn.com) Greetings - I just purchased a 2007 BMW Z4M Roadster. I am replacing the stock wheels with OZ Ultralegerra 18 inch rims, painted black. The lug bolts that ship w/the OZ's from Tire Rack are chrome, so I ordered black lug bolts from Turner Motorsports. Here is where it gets interesting.... The front rim offsets are nearly the same: Stock: 42mm OZ's: 40mm If I use stock length lug bolts (the black bolts from Turner Motorsports) will the bolts be too long, or too short by 2mm? Do you have a black locking lug bolt in the appropriate length? If not, is there a plus or minus factor that allows a 2mm (too long or too short) factor? ------------------------------------------------------------- The rear rim offsets are different: Stock: 30mm OZ's: 40mm Tire Rack stated I need a 20mm spacer to ensure the wheel assembly is back in the exact same location as the stock wheels. Pls offer your comment on this. Also, do you have a black locking bolt in the appropriate length? If you just have chrome, can you apply the black finish, so I have black finished lug bolts on my new OZ black wheels? stock 18's: front: et 42 rear: et 30 oz 18's: front: et 40 rear: et 40 O.Z. Ultraleggera Finish: Black Painted Front Fitment 18x8 Offset: 40mm Backspacing: 6.10" Bolt Pattern: 5-120 Rec. Tire Size:225/45-18 Weight: 18.6lbs. Rear Fitment 18x9 Offset: 40mm Backspacing: 6.57" Bolt Pattern: 5-120 Rec. Tire Size:255/40-18 Weight: 20.8lbs. Thanks very much - my new OZ rims arrive appx 15 Apr and I want to install on Fri 16 Apr, if possible (with McGard locking lug bolts, of course) (: Thanks very much - pls call and/or email to: Bruce
Racerbruce
