03-04-2010, 02:00 AM | #1 | |
Smiling Politely
1524
Rep 29,119
Leaking head gasket
So two weeks ago when I was getting my exhaust done I noticed a leak near the trans.
So I take it to the dealer and they told me it's the head gasket leaking. I'm fine with it as long as it's fixed. But my SA did mention that there was a large amount of carbon buildup on three cylinders. He said it's either due to fuel choice, I use chevron 91oct, or lack of heavy driving. According to him the m engines need to be driven hard often. He said the immediate fix is a fuel system flush. I don't beat on the car but I also don't baby it, opinions?
03-04-2010, 03:21 AM | #2 |
Rep 9
Is the head gasket going to be done under warranty? You got a much bigger problem if the head gasket is leaking versus carbon build up.
The motor is spec'd at 91 octane. If you are putting in higher octane fuel which could cause carbon buildup due to incomplete combustion if not driven hard enough, or you do a LOT of stop n go traffic driving at low RPM's then i would get the SA to prove to you how he came up with the carbon build up theory? Fuel system flush sounds like a stealership grab unless its covered under warranty. To clean carbon out is usually accomplished with a few good hard runs coupled with a top engine cleaner cleanse such as seafoam or even water sucked in via a vacuum line with the motor running. If the headgasket is truly leaking, compression will be down in one of the cylinders and your radiator will be bubbling out air through it if you take the cap off and start the motor. Regards |
03-04-2010, 09:40 AM | #3 |
Rep 4,726
congratulations you are most likely the victim of the dealership.
There's no way you have a leaky head gasket. If it was an oil leak near the trans it's likely a CPV valve, fairly easy fix. What kind of a leak was it? Carbon buildup isn't fixed by a fuel system flush, that's ridiculous. There probably is no (excessive) buildup in the first place.
03-04-2010, 10:40 AM | #4 | ||
Smiling Politely
1524
Rep 29,119
Oh hell im not paying for it. Its all under warranty. I dont care what they say will fix it as long as they fix it. Im interested in the theories of the carbon buildup though
03-04-2010, 11:17 AM | #5 | |
Rep 4,726
One thing I am thinking though, are you sure he did not mean you have a leaking valve cover gasket? Carbon buildups probably BS, and a fuel system flush wont be fixing it if there is. They probably want to charge you for this supposed flush.
03-04-2010, 11:25 AM | #6 | ||
Smiling Politely
1524
Rep 29,119
Theres really nothing i can do about the head gasket leak. whether it really is there or not. He didnt say valve cover leak. He said the carbon buildup was on the cylinder walls/pistons..he would need the head off to see that. its under warranty and i really cant refuse the service. as for the fuel system flush, this is their description; Using specialized equipment, our trained technicians will clean throttle body, intake valves & combustion chambers. Personally I dont buy in to it but if they'll do it for free..have fun. I have heard of audis getting carbon buildup but i dont know the reasons for that.
03-04-2010, 11:35 AM | #7 | |
Rep 4,726
Ugh, they took it off already? That sucks. 99% of the oil leaks that are dripping down the bottom of the bellhousing on the s54 are CPV valve leaks, the rest are rear main seals. You're probably a bit early for both, but way more likely then a headgasket. Headgaskets can leak out the side of the block, but it's only on cars with 100ks miles and usually includes coolant (and lots of other things). And what they meant was the guy from the wash bay will go to town on your valves with a metal wheel. (can you tell I don't think very highly of the dealerships?)
03-04-2010, 11:41 AM | #8 | ||
Smiling Politely
1524
Rep 29,119
anywho, Im not 100% convinced that the head is leaking... Personally i dont want my engine opened up by anyone for any reason. but such is life. Luckily i trust my SA and the tech working on my car. they have been working with my car for over a year and they seem to know what they are doing.
03-04-2010, 04:16 PM | #9 | |
deft danish devil
Rep 114
Drives: BSM E86 M-Cp, LMB 335d M-Sport
03-04-2010, 07:07 PM | #10 |
Rep 4,726
Main bearings don't like high pressure, there is a valve that relieves the pressure to prevent them from seeing it, it's on the side of the block. The O ring goes bad and it starts to leak oil which then drips to the bottom and makes it look like a bad rear main. An experienced tech, instead of diagnosing a very expensive rear main will identify that 50-100$ fix instead.
03-08-2010, 02:37 PM | #13 | |
deft danish devil
Rep 114
03-08-2010, 02:41 PM | #14 |
deft danish devil
Rep 114
scratch that,, Constant Pressure Valve,, just found it
03-08-2010, 02:59 PM | #15 | |
Smiling Politely
1524
Rep 29,119
k im pissed now,
he sayings theres a oil pan leak now. now im 100% sure they misdiagnosed this. my engine got taken apart for nothing
03-08-2010, 03:11 PM | #16 | |
Rep 4,726
99% that that is where your leak is from. It leaks all the time and from the picture below you can see how close it is to the bell housing/ why it gets misdiagnosed. I'm not trying to be a jerk, but I feel really bad for you because I can almost guarantee they did not put it back together 100% properly. A lot of engines can be built be ignorant monkeys, the high strung s54 isn't one. Make sure you give them a poor review when BMW calls, and pray the headgasket holds/it was timed and torques right.
03-08-2010, 03:21 PM | #17 | ||
Smiling Politely
1524
Rep 29,119
ocha i completely agree with you, i used to work for Mbenz i know the difference between a good engine tech and a oil change monkey. im heated right now.
03-08-2010, 03:49 PM | #19 | |
Smiling Politely
1524
Rep 29,119
Well my car is still under warranty so i have to take it to a dealer. I havent heard anything good from san diego bmw so i take it to another dealer near sd.
Actually havent heard of any good BMW dealers in ca Ah, my car is never going to be the same.
03-08-2010, 04:07 PM | #20 | |
Rep 4,726
And the reason I ask about the shops is if you can find a really good shop you KNOW has the tools and can check timing you can confirm if the tech is an idiot or not. If he is it'll be timed wrong.
03-09-2010, 06:04 PM | #21 | |
Smiling Politely
1524
Rep 29,119
*update*
They cant get the timing right. O-cha......you were right
03-09-2010, 06:14 PM | #22 |
Rep 1,337
I got inspection 1 done at 21k and I feel my timing isn't right either. how can i check my timing, I am complete fool when it comes to engine knowhow? Thanks
If everything seems under control, then you aren't going fast enough"
