Go Back   ZPOST > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      02-26-2026, 01:26 PM   #1
Dirty Jerzey
Drives: Now:G82,X4MC Old:E46,E92, F82
Valve and Default setting on G82 questions
Just bought a 24' G82 comp xdrive
If I set the default setting to sport, etc. The next time I get in the car it defaults back to comfort/efficient, is that normal, or do I have a memory issue.
Also, Exhaust button, yes it opens the valve, but to what degree 25% 50% do we know. and would it make sense to get a valve controller to open 100% for a more aggressive tone?
Current:24' G82 M4 Comp Xdrive: Mad Fat boy mid Pipe, MAD valve controllers. RW carbon air ducts and grills and front lip
21' X4M Comp: VRS downpipe, Eventuri intake, Acropovich exhaust, BM3 and Jordan tunes. Acropovich Diffuser and RW Carbon Side skirs and grills.
OLD: E46, E92, F82
      02-26-2026, 02:07 PM   #2
chris3g
chris3g's Avatar
5758
Drives: 2023 M3 xdrive
the default settings are not adjustable.
the exhaust valves are variable, the position depends on many factors including the button, the engine mode, rpm, load, gear etc.
if you just want them open 100% all the time then it makes sense to get a valve controller.
BMW Remote Coding - https://chris3g.com
CS Software Bundles
BMW Service Manuals - https://chris3g.com/manuals
      02-26-2026, 03:19 PM   #3
Dirty Jerzey
Thanks Chris. makes sense.
Any views on the default comfort/ efficient default setting that changes back to default after I change it after each ride? Is that by design?
OLD: E46, E92, F82
      02-26-2026, 03:25 PM   #4
chris3g
chris3g's Avatar
5758
yes it's by design you can't alter the default startup settings. you can get a cando+ device if you want to do that.
CS Software Bundles
      02-26-2026, 03:40 PM   #5
Dirty Jerzey
Ah so, I can change mine to sport etc....but upon start up next time its defaulted back..ok, so its not a memory issues. I only drive in M mode anyway...but was just curious...thanks for your help..Greatly appreciated.
OLD: E46, E92, F82
      03-21-2026, 10:50 AM   #6
Dirty Jerzey
FYI. you can actually overide this with bimmercode app...default to all sports setting and actuall sport+ making it the default.
OLD: E46, E92, F82
      03-21-2026, 11:52 PM   #7
JABCAT
Professor
JABCAT's Avatar
Drives: '23 M2 & '22 X3 M Competition
If you want the exhaust valves open 100% all the time:
1. Remove the valve actuator on each side by removing (3) 10mm screws on each.
2. Manually open the valves to 100%.
3. Reconnect the actuator but makesure the spring is not sitting in the groove that opens the valve.
4. Remove exhaust valve fuse in rear fuse box.
I've done this to both my M2 & wife's X3MC. Takes about 5 min & costs $0
jmg23503.00
      03-23-2026, 06:38 PM   #8
jmg
jmg's Avatar
23503
Drives: G87 M2
Is this a new feature? Coding to default into sport mode wasn't possible for as long as I can remember.
2025 G87 ///M2 LCI - Ohlins R&T, Millway Uniball Camber Plates, SPL Adjustable Tie Rods, Endless ME20 Track Pads, Milltek Single Midpipe, Turner CF High-Rise spoiler, Turner Motorsports Front Splitter, Apex ML-10RT 19x11
Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3
      03-23-2026, 06:47 PM   #9
MMnut
Drives: M4
You dont want to set sport mode as default on startup. It'll do more harm than good. Think about you wake up in the morning, go to the gym and do the heavy lifting right away, or jump to the pool and swim right away without a proper warm up.
      04-07-2026, 03:41 PM   #10
Dirty Jerzey
Must Be. because I just did it
OLD: E46, E92, F82
      04-07-2026, 03:43 PM   #11
Dirty Jerzey
Just opens up the valves in a more advanced state. I still let it warm up the same...Just has a more aggressive tone at start up since its currently stock with just valve controllors and mid pipe.
I hear what you are saying, but Im not driving it hard after starting it up.
OLD: E46, E92, F82
      04-07-2026, 09:17 PM   #12
AlpineSwift
AlpineSwift's Avatar
259
Drives: 2025 M340i XDrive
I can personally vouch for the 11Mode controller if you want to forego messing with the hard parts of the valves. A little pricey for what it is but honestly it's been perfect since day 1. You just clip the included wiring bundle in between the valve connectors and it's ready to rock; no external box to mount, no crazy wiring mess to cinch up with zip ties all over, no splicing external power in. 2 modes/buttons on the remote: Full open and stock. That's it.
It's kept me from pulling the trigger on any catback or axleback system out there because it gives me just enough tone to be happy with it...for now.
Current - G20 ‘25 M340i XDrive - Tanzanite Blue II w/ Black & Blue Stitch, Extended Shadowline, All the M options, Carbon trim, Dinan CAI, 11Mode Exhaust Valve Controller, G80 Firewall Brace, Cusco Style Strut Brace.
Sold - E92 '08 335Xi 6AT - Original Prototype Xi DOCRace 6266 ST Swap. Former Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; Verified by The US Mile.
      04-07-2026, 09:22 PM   #13
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Awron has memory flap control on startup. More info in our thread here:
https://g80.bimmerpost.com/forums/sh....php?t=2231711
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
