      10-17-2024, 02:04 PM   #1
flyzipper
flyzipper's Avatar
Drives: 2008 M Coupe
Dashboard light trio: Brake Warning, DSC and Flat Tire Monitor
Good day all!
I'm wondering if anyone has dealt with the trio of dashboard warning lights I mentioned in the title. Brake warning, Dynamic Stability Control and Tire Pressure Monitor lights illuminated in yellow.
My 2008 M Coupe uses the ABS sensors for tire pressure monitoring, so taken together this could indicate there's some issue with ABS/DSC sensors, but I'm just guessing.
This first started after the front rotors and calipers were replaced in the spring, but back then the lights were random and intermittent (or not at all on some drives). At that time, I believe I could feel a very slight grabbing that felt like a brake applying, then that trio of lights would illuminate ("believe" because it was very slight and perhaps observer bias influenced by the lights themselves).
Currently, the lights clear when the car is off and then started, but they appear as soon as the car moves in reverse.
I have service scheduled with the garage who performed the last brake service, but would appreciate any insights I can find to prep me for that appointment.
      10-19-2024, 01:47 PM   #2
Vanne
Vanne's Avatar
United Arab Emirates
1766
Drives: 2007 Z4MC
prob a wheel speed sensor on one of the wheels (4 installed) did you recently do brakes or wheels? edit: i just re=read what you typed.. so yead def a wheel speed sensor.. which one? beats me.. id start by having a look at the condition of them and go from there.
Powered by
      10-20-2024, 07:49 PM   #3
3002 tii
3002 tii's Avatar
2980
Agree unless your battery died recently, I’d think ABS sensor but best thing is to scan for codes instead of throwing random parts at it.
Follow for latest mods
      10-20-2024, 09:43 PM   #4
maupineda
Drives: E86 Z4MC
Scan the car and see what DTC's codes you have.
      10-29-2024, 05:58 PM   #5
flyzipper
flyzipper's Avatar
Thanks all, it's going into the mechanic on November 5th and I'll let you know what's discovered.
      11-12-2024, 06:37 AM   #6
kptools
Drives: 2007 BMW Z4
Just curious what codes you had what was done to car.
      11-16-2024, 09:56 AM   #7
B328iC
Drives: 97 328iC, 2003 Z4
A lot of times it's just dirt blocking a wheel speed sensor. Cleaning them could be all they need.
      12-03-2024, 09:18 AM   #8
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Another thought for you: it may sound ridiculous, but it could be your voltage regulator. I have seen many cases with these symptoms.
Powered by
      12-14-2024, 11:13 AM   #9
wdb
dances with roads
wdb's Avatar
5544
Uhh, code reader.
      12-15-2024, 10:21 AM   #10
B328iC
If you have a Foxwell 530 you can jack the car up & run live data on each wheel spinning them by hand and get an idea which one is giving you issues. Sometimes it's just dirty and after cleaning it up it will work fine.
      12-16-2024, 03:56 PM   #11
ANILE8
ANILE8's Avatar
No_Country
241
Drives: Z4 M Coupé - Carbon Black
This was the exact problem with mine when it did this. I replaced the complete alternator and all the warning lights disappeared.
      12-17-2024, 04:12 PM   #12
Michael9218
Michael9218's Avatar
633
Drives: 2007 Z4 M Coupe
I’ll third that.
My street car had a hesitation and the radio would cut out momentarily. Also got the trifecta lights.
Found a DIY on replacing the regulator thats on the alternator so fixed it for $40. Didn’t save the link, but search.
