      04-29-2024, 07:49 PM   #1
lauz
Drives: bmw z4m
BE bearing and arp bolts
Anybody have replaced thei rod bearing with the BE bearing and ARP bolts. Are you happy with the results ?
      04-30-2024, 05:03 AM   #2
grannyknot
grannyknot's Avatar
953
Drives: 2008 Z4M coupe
Unless you are seriously tracking the car you don't need them, many guys track hard with stock bolts with no problems.
2008 E86 M coupe
belcom182.00
      04-30-2024, 07:44 PM   #3
belcom
belcom's Avatar
Drives: '18 540i, '06 Z4si, '07 Z4MC
I used ARP when mine were done. They're reusable by the way. So that is probably the main benefit.
Do make sure to check if yours are 10mm or 11mm.
From Bimmerworld:
This rod bolt set is made for the later S54 (February 2003 and newer production dates), which used an M10 sized bolt, versus the earlier cars which used an M11 sized bolt. (If your S54 engine is built before 02/2003, or you know it has an M11 sized bolt, please see BimmerWorld part # 201-6103 instead.)
https://www.bimmerworld.com/Engine/G...02-03-M10.html
