02-05-2024, 07:07 PM | #1 |
Rep 31
Replacement key fob housing to freshen up worn key
Hello,
My current key works fine. It is just worn from use and age. Are there any replacement key fob housings/shells available that I can transplant the innards to without needing to buy a whole new key with the electronics and programming? If there's no housing options, is it possible to upgrade the key to a newer style BMW key? |
02-08-2024, 02:08 PM | #3 |
Rep 31
No, the key's plastics look faded and the BMW logo is discolored. A cover won't fix anything. Seems like the only solution is to get a new key. I guess it's not terribly expensive ~$180. Cheaper than most new keys nowadays.
02-08-2024, 02:41 PM | #4 |
Rep 1,774
Drives: Bmw 330i and Bmw 328i
Can you just recopy the metal part of your key or you need the electronics inside it also?
02-08-2024, 04:41 PM | #5 |
Rep 31
Everything about the key is perfectly fine. The metal shaft and electronics are functional. I was hoping to just get a replacement plastic body and transfer things over if that's possible.
02-08-2024, 05:58 PM | #7 | |
Rep 2,650
Drives: Z4MC, X3-35i,525i, Corrado G60
Aloyouis218.00 |
02-08-2024, 07:12 PM | #8 |
Rep 31
Apparently, key shells do exist. Here's an amazon listing for one https://www.amazon.com/beler-Button-.../dp/B07FJ781BH but they are uncut. After some research, original key shells are glued shut and the key blade is molded into the shell so transferring the key blade will be pretty much impossible. What I find interesting is that the BMW emblem on the keys can be separately ordered and that tiny little piece is ~$10 (part number 66122155753).
02-08-2024, 07:25 PM | #9 |
Rep 2,650
I've cut them open to replace the battery so it's doable, but not trivial. With that said, I would not cut open a perfectly working key.
03-09-2024, 10:34 AM | #12 |
Rep 19,462
OP, do you have a second key that is not used or worn? If you only have one key, then you should have a spare key regardless of the condition of your daily key. You need a working key to program any new keys you buy.
03-09-2024, 03:26 PM | #13 |
Rep 31
That's good to know since I'll probably get a new key eventually. I do have a second key in slightly better condition. Both are working so not in a huge rush.
03-10-2024, 04:19 AM | #14 |
Rep 2,784
Great timing. Addressing my worn key fobs is next on my project list. I recently replaced both of my 996tt key housings with refreshed designs, and I’d love to do the same with the Z4.
3002 tii2387.00 |
03-14-2024, 08:08 PM | #15 |
Rep 31
I've looked and don't think there are many options for a new or redesigned housing that fit our keys. I'd be a customer if there are new compatible key designs out there.
03-27-2024, 10:40 AM | #17 | |
Rep 2,650
I use the original BMW leather holders, which are comfortable in pocket and my keys still look nearly new. |
