11-24-2021, 09:42 PM | #1 |
Rep 2
2001 bmw x5 brake switch?
Hello, my 2001 bmw x5 is having issues here and there with what I believe is the brake switch, when I start the car my brake lights are on when my foot is not on the brake and my gas pedal does nothing. Is this a brake switch issue? I had also pulled the fuse in the glove box for the switch and nothing changed. I had just recently bought the car and it has a aftermarket sound system in it which I believe might be part of the problem. This problem isn't always constant, as I sure the next time I go to it, it may be fine. But if it's a faulty switch I would like to be able to replace it so I can stop leaving it sit. Any help or leads I the right direction are greatly appreciated.
11-27-2021, 01:06 PM | #2 |
Rep 2,304
Not really seeing a brake light switch here: https://www.realoem.com/bmw/enUS/sho...diagId=34_0986
There is a hand brake light switch however. Lots of complicated parts to an X5 brake system; do you know of an indy BMW garage in your area? I do via BMWCCA. |
12-08-2021, 10:05 PM | #3 | |
Rep 3,458
Drives: Harrop E90 M3
