04-11-2021, 08:20 AM | #1 |
Rep 49
Drives: Z4MR
Z4M front sway bar options
I'm looking to try a milder sway bar setup versus stock. The rear is easy as bars from e46/z4 all fit. The front however is a unique setup from what I understand.
Which of these is most likely to fit a stock Z4M front suspension? 1. Z4 3.0/E46 2. E36 M3 Any other candidates? |
04-12-2021, 08:36 AM | #3 | |
Rep 689
Drives: 06 Black Sapphire Z4MR
The M roadster runs a 21.5mm rear bar, the coupe runs a 22.5mm rear bar Part numbers shows also E85M Rear: 33552282181 E86M Rear: 33552282681
Revolution of our Times
I will return to the track, one day. |
04-12-2021, 09:18 AM | #4 |
Rep 49
Drives: Z4MR
Are there any smaller diameter than stock front sway bars that fit?
04-12-2021, 09:22 AM | #5 |
Rep 11,669
04-12-2021, 09:36 AM | #6 |
Rep 978
I have a coupe so my statement was applicable to my car. If the OP has a roadster he can upgrade to the coupe’s / CSL’s
04-12-2021, 10:03 AM | #8 |
Rep 49
Drives: Z4MR
Street for sure. I think the car would ride a lot better on uneven surfaces if it has smaller sway bars.
04-12-2021, 01:29 PM | #9 | |
Rep 11,669
They aren't adding anything to spring rates for normal driving. The only time they really add anything is under cornering load or if one wheel drops into a pot hole. A softer front bar ; 1. Increases front chassis roll.For ride comfort springs and dampers are the only real solution. |
04-13-2021, 03:02 AM | #10 | ||
Rep 1,923
And so glad u r back!! As I am lol
04-13-2021, 11:19 AM | #11 |
Rep 2,707
Soft springs, big bars give perfect combo of ride and handling.
https://www.scribd.com/doc/157853842...is-Engineering
