02-28-2021, 10:34 AM | #1 |
Rep 3
2007 E86 Unable to connect to A/T with scanner
First time poster here, thanks in advance for your input!
I recently purchased a 2007 E86 with an automatic transmission. I’m currently going through and replacing all of the fluids as I don’t have records of the last time they were done. The procedure to change out the transmission fluid calls for you to check the level with the transmission fluid at a specific temperature. I purchased a Foxwell NT510 Scanner so I could read the temperature and do other BMW specific maintenance/troubleshooting in the future. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The problem I am having is that the scanner can communicate with every other system on my E86 except for the transmission. When I try to connect to it, I get a “no communication” error. The car does not show any codes and I’m wondering if anyone else has had this issue? I’m not sure if it’s a limitation of the scanner (the manufacturer says there could be a problem with the transmission). It would seem if the ECU was unable to communicate with the transmission then I would be having some other kinds of problems right? Check engine light or something I would assume. If anyone has any ideas or has had issues with this particular scanner please let me know. Also, if you have one that you have used successfully please share the model of scanner that you used. Thanks! |
03-01-2021, 06:21 AM | #2 | |
Rep 2,287
Its free and it works. |
03-01-2021, 04:19 PM | #4 |
Rep 2,287
I had my 2007 long enough to change the trans fluid twice, refilling is a bitch and by the time you get all of the fluid into the transmission it's too hot to properly check the fluid.
Plan on two sessions, once to fill it and a second several hours later to check the fluid level. |
Tags |
code scanner, e86, foxwell, transmission |
