      11-14-2020, 11:09 AM   #1
filtercoffee
I like Coffee & Z4s.
106
Drives: 2007 Z4MC
2007 BMW Z4MC  [0.00]
Z4M 245/40/R18 rubbing (18x9 ET30)
so I pulled the trigger on some tires, got em mounted, but having front fitment issues.
I thought the front would fit with just a bit of extra camber but the tires are running against the fender liner in places I did not expect, on certain turn angles.
any general advice? let it rub through the liner?
pics incoming.
PS lowered on coilovers. ~ -1.7 camber
      11-14-2020, 12:37 PM   #2
filtercoffee
106
Drives: 2007 Z4MC
driver side front where the bumper cover meets the fender:
View post on imgur.com
that's where it rubs when I turn right. (well, used to rub)
here's the rub point when I turn left:
michelin pilot a/s 3+. probably should have stuck with 235. oh well. I hope people can learn from my mistake. and any advice is appreciated.
      11-14-2020, 03:41 PM   #3
filtercoffee
106
Drives: 2007 Z4MC
post car wash pic
the wheel/tire diameter is larger than I projected, since there's less sidewall stretch going from 235/40 to 245/40.
      11-14-2020, 06:07 PM   #4
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Unfortunately, that is where everyone gets tire rub when going wider. Since I'm at stock ride heights, I'm only rubbing on full compression. my solution is to just stack a few electrical tapes in that area and replace it when it rubs through the tapes
wdb4732.00
      11-14-2020, 06:28 PM   #5
filtercoffee
106
Drives: 2007 Z4MC
I'm definitely considering raising the car. it's just annoying work.
      11-15-2020, 02:18 AM   #6
maupineda
Drives: E86 Z4MC
I would not let them rub through the liners, they are f’ing expensive. I just replaced mine at 240 each!!!!!
Get the camber washers and remove the pins. Better to wear the tire than the liner. Or change to a wheel that doesn’t rub.
Liners are important to protect the lamps, horn, harnesses, etc.
      11-15-2020, 10:49 AM   #7
filtercoffee
106
Drives: 2007 Z4MC
yikes! haha. based on where the rubbing is occurring, I'm not sure more camber will help. I give it a shot if the rubbing continues.
btw, check ebay for OEM parts next time, some dealers sell parts on there at a reasonable price.
      11-15-2020, 12:02 PM   #8
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
I just remember that even my stock wheels and tires were rubbing in that location. Granted, not a lot, but enough to leave rub marks. Most likely the deformation of the liners as they age exacerbates the problem.
      11-15-2020, 02:57 PM   #9
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
my oems wheels rubbed same spot with eibachs, new rivets helped a little, but they still rubbed. I went back to stock springs.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
wdb4732.00
      11-16-2020, 11:03 AM   #10
Steeler
Steeler's Avatar
2429
My liners tuck inside the the fender lip where yours are shown as outside.
Is this how it came from the factory?
      11-16-2020, 11:06 AM   #11
filtercoffee
106
Drives: 2007 Z4MC
Not sure, yours is more likely to be correct since this mine has had the liners replaced at some point. Maybe that would reduce the rubbing on that side.
      11-16-2020, 11:11 AM   #12
Steeler
Steeler's Avatar
2429
Could be as much as a quarter inch difference so would likely solve the rub up front.
      11-16-2020, 12:29 PM   #13
maupineda
Drives: E86 Z4MC
I did, and all I found were knock offs, or non-M versions, and though you can fit non-M items, you need to force them to attach under the sill and lower bumper attachment points.
My car is my joy so was not going compromise even in items like liners, when I see a car with missing or chewed liners in my mind is an indication or carless. Damn, I have even replaced rusted hardware that no one can see.
      11-16-2020, 12:46 PM   #14
filtercoffee
106
Drives: 2007 Z4MC
ah you're absolutely right.
update: here's a thread on the M vs non-M fender liner, in case anyone is curious to know more
https://www.zpost.com/forums/showthread.php?t=1307429
      11-16-2020, 02:46 PM   #15
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
As others mentioned, get a different tire size (245/35/18) OR increase ride height. I also had a rubbing issue when I crammed 275s up front, but after bringing the car back up to stock-ish height, rub issues went away
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      11-16-2020, 05:17 PM   #16
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
I'm assuming that you're referring to this picture? Most/All of the MR/MC that I've come across have their liners on the outside as shown in the picture, including mine. The picture also show blind rivets being used, so most likely OE.
      11-16-2020, 06:03 PM   #17
Steeler
Steeler's Avatar
2429
It appears that is the case. My non M has spring nuts attached to the liner for fastening which dictates the liner fitting behind the fender lip.
      01-02-2021, 05:51 PM   #18
TheMetrologist
Drives: 2008 Z4M
I am also looking at changing out my wheels to ET30 18"x9" APEX EC-7's
I would then wrap them in Michelin PS4S 255/35-18
Lastly, I would run street camber plates in the hopes that the front tires will not rub.
However, after reading this thread I am concerned. I am at stock ride height and I plan on staying there. Is your car on stock ride height? Were you able to get this issue fixed?
      01-02-2021, 07:37 PM   #19
Piper1
Piper1's Avatar
Drives: E85
I'm on eibach/koni combo on my non M and do rub a little (apex ec7 et31 18x9 toyo r1r 255/35/18), not as much as you see in this thread but in a slightly different location at full lock. M vs non M sit different in caster due least in part by the offset on the LCAB. Even stock height with camber plates with the M more aggressive caster on 255 I'd be surprised if you didn't rub least a touch.
      01-03-2021, 02:36 PM   #20
filtercoffee
106
Drives: 2007 Z4MC
I'm lowered so I can't say for sure about stock ride height. I am living with a reduced turning radius for now.
      01-03-2021, 11:59 PM   #21
TheMetrologist
Drives: 2008 Z4M
That's a bummer to hear. My goal was to run a square setup.
Looks like it's back to the drawing board.
      01-04-2021, 11:23 AM   #22
Piper1
Piper1's Avatar
Drives: E85
Well guess depends on point of view LOL better handling is the trade off.
Though it'd probably be harder to tell, but I've been curious how in a controlled situation these two would be, 225 or even 235 width fronts with the M caster vs 255 width fronts on non m caster. When I was deciding on power flex bush for my fcab you can pick either from power flex, but with already being my current stance I was figuring it'd be even more rubbing on the fenders than I already am so decided to stay with oe placement for the non m. I doubt it but wonder if anyone's put the non M bush to the M to reduce caster as they went wider.
