      05-07-2020, 07:04 AM   #1
Cuervo1416
Cuervo1416's Avatar
Drives: Z4MR
Z4 black housing headlight (driver side only)
USD 110.00
I bought this headlight thinking I wanted the black housing then I changed my mind. It is in really good condition with no broken tabs. Only selling the driver's side
and looking to get $110.
      05-07-2020, 11:42 AM   #2
SunUpTopDown3
Backroad Warrior
SunUpTopDown3's Avatar
Drives: Z4MR
This is off the 3.0Si, right? do these fit properly on Z4MR?
      05-07-2020, 01:43 PM   #3
maupineda
Drives: E86 Z4MC
I believe that is a halogen lamp, so it would not be a direct fit to the Z4M
      05-07-2020, 01:51 PM   #4
Cuervo1416
Cuervo1416's Avatar
Drives: Z4MR
I bought it for my Z4MR but never installed it so I can't confirm. How certain are you maupineda? I was told it did fit.
      05-07-2020, 01:57 PM   #5
maupineda
Drives: E86 Z4MC
If you check ECS, they have some photos, at the bottom of the lamp you see the embossments and connector plug for the ballast. also, the xenon lamp has two projectors (one does nothing), and the halogens have one outboard projector and the inboard reflector for the high beam.
      05-07-2020, 10:23 PM   #6
Cuervo1416
Cuervo1416's Avatar
Drives: Z4MR
Interesting. Thanks for the info.
      05-08-2020, 12:58 PM   #7
KevinC
your average JAMF
KevinC's Avatar
AFAIK, black headlamps were never available on any Z4M, which are all xenon. All black ones are halogen from what I've gathered in the past.
'21 M2 Comp
'19 Golf R
      06-01-2020, 07:11 PM   #8
fryh1n
fryh1n's Avatar
Drives: 2007 Z4M Coupe
2020 BMW X3MC  [0.00]
2008 BMW Z4MC  [0.00]
there are black ones with HID.
63127162728 and 63128162727.
https://www.ecstuning.com/b-genuine-...t/63127162728/
      06-06-2020, 12:06 AM   #9
Alaberti
And yet
Alaberti's Avatar
Drives: Jaguar F-Type V6 S BDE
Thanks for the model numbers; know if anyone has already tried fitting these to a Z4M? Should just be a direct swap I assume.
      06-06-2020, 06:26 AM   #10
jteran5
Drives: 2007 AW Z4M
Yes. These model numbers are a direct fit for the Z4M as I have done it.
For 06-08, M and SI got the chrome housings and the 3.0I got the black one.
