      04-14-2020, 05:12 PM   #1
jns_e85
jns_e85's Avatar
81
Drives: '05 X3 2.5i, '06 z4M, '17 M2
WTB: 996/Boxter S caliper conversion for Z4M
As title says, looking for a 996/Boxster s conversion. Ideally, looking for a kit ready to go with front calipers already modified along with needed RallyRoad lines and brackets, but will consider partial kits. Don't need rotors or pads. Shipping would be to Chicago area. PM me if looking to sell!
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      04-20-2020, 12:45 AM   #2
3002 tii
3002 tii's Avatar
2961
FWIW I spent a lot of time researching this when I pieced together my kit. But for the rears, while the p/n you typically see quoted are correct (996.352.421 / 422), you need to make sure they indeed came off a 996 c2 base or 986/7s. Reason being I found out the non-s 986/987 rear calipers also have the same p/n in the casting. The (non-S) base and S calipers actually look identical but the key difference is the pins that hold the brake pads stick out are longer on the non-S (i.e. less clearance) to accommodate a thinner rotor (24mm). The S models use a 28mm rotor in the rear so those pins are ‘shorter’ and offer more rotor clearance.
If you search hard enough you’ll find instances of owners unable to install rear calipers and blame faulty brackets not realizing they bought the right p/n caliper off the wrong car.
Follow for latest mods
Vanne1765.00
jns_e8581.00
      05-21-2020, 08:29 AM   #3
jns_e85
jns_e85's Avatar
81
