      05-30-2019, 06:02 PM   #1
txguy1986
Drives: 2004 Z4 E85
255/50/19's fit on Z4?
I have a 2004 E85 with sport suspension. Will 255/50/19's fit. I have read the tire forums for hours and am more confused than when I started.
      05-30-2019, 07:54 PM   #2
HausM6
No_Country
Drives: M6
Why do you want 50 on this car? It's generally a 30/35mm height !
      05-30-2019, 08:31 PM   #3
txguy1986
Drives: 2004 Z4 E85
Found a set of takeoffs with practically new tires and BMW wheels.
      05-31-2019, 07:26 AM   #4
kyriian
kyriian's Avatar
891
Drives: 06 Black Sapphire Z4MR
2014 BMW X5  [0.00]
2011 Scion tC  [0.00]
Your gearing will be off, rolling diameter is about 3" bigger, imagine filling your wheel well with another 1.5" of rubber you probably already understand this is not going to work
Revolution of our Times
I will return to the track, one day.
      05-31-2019, 09:54 AM   #5
txguy1986
Drives: 2004 Z4 E85
[QUOTE=kyriian;24853769]Your gearing will be off, rolling diameter is about 3" bigger, imagine filling your wheel well with another 1.5" of rubber you probably already understand this is not going to work[/QUO
Thanks for the info. Didn't think it would be that big of a difference. What about 225/45/18 on 18x8 wheels with a 34mm offset? These came off a 335i.
