01-07-2019, 07:44 PM | #1 |
Rep 382
Z4m Bilstein Pss10
Getting closer to install! Will be paired with Vorshlag camber/caster/spring perch combo, new factory LCABs, Meyle HD sway bar end links, rouge engineering RSMs, Meyle HD RTABs, ECS limiters and Super Pro purple rear upper spring pads. I can't wrap my head around how it good it will handle because it already handles so good!
01-08-2019, 12:38 AM | #2 |
Rep 115
As someone installing new coilovers too (H&R for me), what's the purpose for the ECS limiters and super pro spring pads?
I ordered the Rogue rear shock mounts as well, and new OEM front shock mounts. |
JimBob0047272.50 |
01-08-2019, 07:06 AM | #3 | |
Rep 382
"Factory rear trailing arm bushings allow for two undesirable scenarios: premature failure and unexpected changes in toe. Limiting side-to-side deflection of the rear trailing arm, limiters surround the rear trailing arm bushing, maximizing bushing life while eliminating undesired rear toe changes. This alignment retention allows for more predictable handling in corners and over bumps, without a loss of ride quality. Manufactured of wear resistant, noise resistant delrin, ECS RTAB limiters offer a solution to an inferior factory design. Meyle HD bushings offer an OE-style performance upgrade without adding any unwanted harshness to your ride. Coupled with ECS RTAB limiters they make an almost perfect upgrade for a daily car or one that sees time on the track." Spring pads: (why not while I'm there mod) "Polyurethane for a more rigid and reactive suspension." |
01-08-2019, 05:34 PM | #4 |
Rep 705
I know nothing about this PSS10 coilover setup but RTAB limiters are a bandaid fix. You should have used a true monoball bearing in this area as it has ZERO unwanted deflection and gives better articulation in their three axis of rotation.
Mix and matching bushing types is a sub-optimum way to go as far as handling is concerned as there is a lack of consistency between the different suspension components. You are using monoball camber plates and RSM anyway, I don't know why you would skimp on the RTAB's.
JimBob0047272.50 |
01-08-2019, 08:59 PM | #5 | |
Rep 382
I don't plan on tracking it and wanted to keep a factory looking bushing Incase I ever decide to sell it which is why I went with the myle HD. Also I was trying to minimize the increase in NVH. Now you have me thinking! |
01-08-2019, 09:28 PM | #6 |
Rep 705
I am not sure how much NVH just a set of monoball RTAB's would add just on their own because I did EVERY monoball/spherical bushing all at once.
However, there is no way in hell any potential buyer would be able to see what RTAB is in there just by looking without taking the carrier out. Where they live is not a place that can easily be seen. Limiters are probably a good compromise for the street, so probably just forget what I just said. Although, you will definitely get clunking noises when you go over sharp road divisions anyway with those monoball Camber and RSM plates. Don't ask me how I know this. Does that make them a bad choice...., no it is just part and parcel of going down this route. So my reasoning was you might as well go all the way because the NVH will be increased by this setup so you might as well get the full benefit. Just had a quick look for you. I am not sure that Vorshlag make them as all their top plates are monoball both front and rear, which in my opinion is the right way to do things. But you can get 'street' camber and RSM for the PSS10's that use rubber to maintain a stock level of comfort. My ride is so far past that stage already I don't worry anymore about NVH but I understand that for many it is a real concern.
kaybat127.50 |
01-08-2019, 09:32 PM | #7 | |
Rep 382
Im about to order these. Good choice? |
01-08-2019, 09:47 PM | #8 |
Rep 705
They are the same ones that I got from TMS, I think they are excellent. Except these are the updated model that is fully sealed, which is a good thing.
Just a word about pricing, they have been on special with 10% discount for around $250 but appear to be back to normal pricing now. I am the same, whenever I want something stuff is never on special If you subscribe to Turner's newsletter and register on their website you will definitely know when the specials are on as they email me almost daily! Or maybe if you ask real nice they may give you a special discount for these. Just depends how quick you need them I guess. I will say that I can hear a definite clunk from them when I cross a road division or on a sharp bump but this is with all brands of monoball RTAB's, not TMS specifically. On smooth to moderate roads they are fine.
JimBob0047272.50 |
01-08-2019, 10:35 PM | #9 | |
Rep 382
Ordered and I had to pay for two day shipping to make the install date! Thank you and damn you! |
01-08-2019, 11:15 PM | #10 |
Rep 705
Good stuff, I am sure you will love them.
How long do you think before you get everything installed? I would really be interested to see the install pictures as well as your review and driving impressions when this whole project finally comes together. Promise you will update this thread? I remember a while ago the PSS10's were unavailable for ages or something. Don't know why. Solid mounts and monoballs make such a difference you will be surprised at how much deflection is in the stock rubber components when you take your first drive. After my upgrade HERE I would never go back to standard rubber mounts on a performance car. The floating feeling you sometimes get with stock bushings is totally gone and you don't have any roll or bounce.
01-08-2019, 11:22 PM | #11 | |
Rep 382
I can't promise pictures as I will not be present during install but I can guarantee a solid review once I get some good seat time, weather permitting. Apparently they were on national backorder for 18months. I got lucky and caught the last set on ECS for $1900. I'm guessing they had canceled orders from people that got tired of waiting to long and needed to move the product. Luckily I stalk car sites daily! I had full suspension and bushings on my 350z. Significantly improved handling but also significantly increased NVH. I appreciate the quite refinement of the M and hope this doesn't ruin that too much. |
01-16-2019, 08:16 PM | #14 |
Rep 3,004
YAY!!!!
What front and rear drop did you set?? Can't wait to hear the seat-time comments.
Racerbruce
JimBob0047272.50 |
01-16-2019, 08:22 PM | #15 | |
Rep 382
Not quite sure but I'd guess about 3/4 inch front and rear. It's too bad we're supposed to get snow again this weekend. It absolutely killed me driving it on treated roads this morning to the shop. Looks like it's gonna be a long winter |
01-16-2019, 08:35 PM | #16 |
Rep 115
Looks great
JimBob0047272.50 |
01-26-2019, 03:59 PM | #17 |
Rep 382
Got a chance to really push it today on some technical and tight back roads. Still some sand on the roads and it was below 40 so I took it "easy". Throughly impressed. I have it set on 5/6 F/R. It handles and rides miles ahead of the factory suspension. You really begin to appreciate the rigidity of this chassis. This is the way to go for a street setup.
01-30-2019, 12:54 AM | #18 |
Rep 12,635
Garage List E86 Z4 M [10.00]
Did you cut any of the trim to adjust the rear shocks?
01-30-2019, 07:51 AM | #19 |
Rep 382
The adjustment knobs are on the bottom. Big selling point on these vs everything else. You don't even need to lift the car. For the front you turn the wheel to access the knob and the rear you reach behind the tire. |
01-30-2019, 07:17 PM | #20 |
Rep 12,635
That’s the one thing I overlooked when buying my GC kit!
01-30-2019, 07:24 PM | #21 | |
Rep 382
08-23-2021, 01:54 PM | #22 |
I like Coffee & Z4s.
110
Rep 366
Drives: 2007 Z4MC
Curious how you like the setup now with more seat time.
